Question about Euro-Pro Dressmaker 998B
Needle will not pick up the bobbin thread, gets tangled when stitching. My user manual shows a little clip/rod to hold bobbin thread in place, my bobbin holder does not have one. It is brand new, dressmaker hot pink color machine. Model is 998H. Please help.
    New Friend:
  • 23 Answers
Oh boy! I've worked on industrial sewing machines for over 30 years, but the home sewing machines are like comparing cadillacs to mopeds. No offense, but if you want performance out of a machine try an industrial. It will shock you with the difference. Be glad to help you find the right one.
Anyway, the problem you are having is quite common. First, make sure it is threaded right especially the moving spring on the needle thread tension) and the needle is new. This generally covers 75% of the problem. Make sure the bobbin thread is threaded correctly.
If you are still having the problem remove the bobbin/bobbin case and observe the needle/hook point relationship as you turn the handwheel. The hook point should pass behind the needle at the scarf of the needle (indention just above eye of needle) If it is not so the needle bar may have moved up on you. Did the machine get jammed?
I'm not sure about the rod you're talking about but lets try this first.
Posted on May 18, 2009
Hello, I recently purchased a brother lx3817 sewing machine and it works but doesn’t stitch, what could be the problem
hi Desiree.
this is all i could find out.
There could be several things that could cause the machine not to pick up the bobbin thread.
  • The upper thread could be tangled.
    Remove the thread completely from the machine.
    The correct size spool cap should be used for the size of the thread spool.
    Re-thread the machine according to the directions in the manual.
One Point Advice Place a spool of thread on a spool pin.
One Point Advice Upper threading
  • Remove the bobbin and make sure the bobbin is threaded properly in the shuttle race.
    Remove any loose threads or lint in the shuttle race.
One Point Advice Installing a bobbin into a bobbin case
  • You could be holding the needle thread too tight.
    Hold the thread lightly to keep the end from going down into the shuttle.
  • The needle could be thread incorrectly.
    Thread the needle eye from the front to the back.
  • The needle could be bent or improperly inserted.
    Install a new needle with the flat side of the needle facing the back.
or this link might help you out some more.
Why won the machine pick up the bobbin thread Brother
or this one.
brother lx3817 sewing machine doesnt stitch Google Search
Dec 06, 2017 | Brother Sewing Machines
When I press the pedal the string get tangled and I also have problems with the bobbin thread not being picked up! Please help! Thanks margaret
thread the machine correctly( follow the operators manual)
wind the bobbin properly and when placing the bobbin in the bobbin carrier pull the thread down the small slot and under the spring plate
thread for the needle always comes in from the left (The side of the groove in the needle ) and out the cut away side
pull a long piece of thread for the needle out and hold it while you turn the machine over
after 1 or 2 revolutions the needle thread will bring up the bobbin thread and you then pull both threads out a bit
if you don't have a user/operators manual there are 2 options
one is to go google and type in --user manual for bernina bernette model 65 sewing machine and down load the pdf version
the other option is to visit manchester shops ( cloth and fabric shops ) and talk with the sales people as may of these places have a sewing circle of people who will be only to willing to help you.
Feb 25, 2016 | Bernina BERNETTE 65 Mechanical Sewing...
How do I reassemble drop-in bobbin case for Brothers XL 2600 free arm?
Do you have some pictures of the area involved. I know how to put these things back but I can't think how to explain it to you.. pics might help me show you.
Brother has an outstanding service department, and if you don't have a manual, they should have one. Should have a pic of how it goes together.
Aug 02, 2014 | Brother XL-2600
Tangled thread on wrong side of fabric, I did the remedy as per manual but problem still exist
Unthread the machine fully. Remove the bobbin. Is the bobbin thread the same as the top thread? Is it a Quality thread (yes, cheapie thread can give big issues!!) Do you have several different threads wound onto the bobbin?? Is the bobbin thread wound on quite tight? If you push your finger nail into the thread wound onto the bobbin, it must not feel soft or spongy. Check if there is any roughness / burr on the any part of the shuttle hook. If so, remove it with 800 grade wet and dry abrasive or similar. Put in a NEW needle as per user manual specs (not a 'new' one you used before 'just for a little bit'.!) REPEAT - put in a NEW needle - amuse me!!. Place the bobbin into the bobbin holder (the CORRECT direction - yes there is a Right and a Wrong direction!), thread it ready to put back into the machine. BEFORE you do, hold onto the thread tail and let the bobbin and bobbin case dangle. Thread should slip thru when you give a gentle pull upwards. If no slip, loosen the tension on the tension finger a LITTLE. If it slides down easy, tighten it a little. Fit the bobbin into the machine. Lift the presser foot (this releases the top thread tension discs) Check there are no bits of thread or fluff between the tension discs Rethread the top thread - check the thread path is 100% correct. Hold onto the end of the needle thread and draw up the bobbin thread. Hold both threads, start to sew - check the result. Tip : If you use a different color bobbin thread (same brand etc etc) it will help you to see more easily what is going on. You should be seeing some of the bobbin thread color on the top side of the sewing. If not, INCREASE top tension a little - retry.If there is a lot showing, decrease top tension. Good luck
Dec 14, 2012 | Sewing Machines
When I push the needle up / down button, it does not work., and the machine just squeeks.
Hello
some thread might have caught in the metal case on which the bobbin rests. There is a tiny hook in the center that the thread travels around before being picked up by the needle thread to form the stitch. Also, check your bobbin itself. Feel around the outside. If you feel any nicks or burrs, throw that bobbin away and get a new one as the thread is catching on the bobbin itself and throwing the timing off.
Check your needle to be sure there are no burrs or nicks on it. Always use a new needle with each project and if the project is a large one, you will have to change your needle a few times. Needles are not that expensive and make a world of difference in sewing.
One more thing. If your machine manual shows a small "arm" that fits over the bobbin to hold it in place, and that you can remove for cleaning, be sure that it is inserted all the way in and holds the bobbin securely as this will cause the bobbin to "bounce" inside its metal bed and cause the thread to tangle up in the machine.
Jul 20, 2011 | Singer Quantum 9910 Computerized Sewing...
When i start to sew on my Janome sewing machine model Sewist 525S it does a couple of stitches on any stitch type then bangs then sews then bangs then stops. I look to see the problem and the bobbin and...
There has to be a problem in your threading or your needle. You may have the needle inserted backwards, flat side has to face rear or the needle is bent. Totally unthread your machine and make sure that there are no tangles and that it feeding the right way. Watch how they show your for threading and winding the bobbin, plus threading the bobbin. Good luck, but I truly think it is in your threading.
Sep 25, 2010 | Brother LS-1217 Mechanical Sewing Machine
The bobbin thread will not pick up. The machine had jammed and I forced the wheel and can't get bobbin thread to pick up. When I thread manually, I only get holes, no stitches. Is it a timing belt?
check your needle to see if it's bent---roll on flat surface to see if it roll correctly
on some sewing machines when the thread comes off the thread take up lever it can cause the machine to jam
also if the bobbin thread becomes tangled it can jam
check the bobbin area for lint or loose threads
try having a top thread tail & bobbin thread tail of 3-4 inches
try holding the top thread tail & turn the handwheel on the right side on the machine manually & put the needle down into the bobbin area & see if the bobbin thread will pick up that way
Sep 24, 2010 | White Sewing 2037 Mechanical Sewing...
Thread jams in bobbin case
Open the bobbin area and make sure it is clean.
Change to a new needle.
Thread the machine with the presser foot up.
Make sure the bobbin thread is feeding in the correct direction from the bobbin spool and through the guide on the bobbin case.
Take hold of the end of the top thread and lower, then raise the needle to pull the bobbin thread up.
Take hold of both thead ends and pull them under the presser foot and to the back of the machine.
Place fabric under the presser foot. Lower and hand walk the first couple of stitches.
When sewing, and you need to stop to adjust the fabric, make sure the needle is down into the fabric. This will keep the stitch from malformation and causing a possible tangle.
If you need a manual, you can download one free at the Brother website.
Mar 20, 2010 | Singer 3116 Simple
Needle's thread gets tangled in bobbin
First, open the needle plate and make sure the bobbin area is clean and free of lint and thread.
Check the needle to make sure it is not bent and is properly inserted into the holder - usually with the flat side facing to the back of the machine.
Refer to your manual for bobbin insertion to be sure the thread is feeding from the bobbin in the correct direction and through the proper guides.
Always thread a sewing machine with the presser foot up. This opens the tension control and allows the thread to properly enter.
When the foot is down, the tension control closes to the sewing setting and if the thread is not in place, there is no tension on the thread and it gets loopy.
After threading, lower and raise the needle while holding onto the thread tail. This will pull the bobbin thread up through the needle plate. Take hold of both threads and take them under the presser foot and to the back of the machine.
Hand walk the first stitch when sewing and this should keep the top and bottom thread from tangling.
When stopping to change the position of the fabric (turning a corner, sewing a curved seam for example), do so with the needle down into the fabric. This not only anchors the fabric so it does not slip, but prevents mis-stitching.
If you are doing everything according to the manual and are still having a problem, the machine may need to be professionally serviced.
Feb 23, 2010 | Elna 1010
Upper thread getting tangled in the bobbin
Always remember T-N-T. Thread, Needle, Tension. Assuming its threaded properly, is the needle all the way in and facing the right direction? These symptoms also suggest the bobbin may be in the bobbincase upside down thus turning in the wrong direction. Hope this helps.
Aug 21, 2007 | Euro-Pro 416 Mechanical Sewing Machine
Euro-Pro Dressmaker 998B Logo
930 people viewed this question
Top Euro-Pro Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
