Question about Carrier Heating & Cooling
Thermostat reads critical malfunction. - Carrier Heating & Cooling
Aquastat relay
It may be, the best way to check a line voltage thermostat like the aqua stat is take a multi-meter on AC volts (120), when the thermostat is or should be demanding heat put the meter across the screws, if you read more than 20-30 volts for certain the stat is worn out. A functioning aqua stat when checking across the terminals should read but a few volts whether the system is 120 or 24 volts, on low voltage it's even more critical to limit voltage drop through a set of contacts.
Oct 11, 2017 | Heating & Cooling
Reading codes check engine light 87
Error code 87, Cooling system malfunction.
Fault:
Coolant Thermostat - Coolant Temperature below Thermostat
Regulating Temperature
Cause:
Mechanical fault.
Jul 22, 2013 | 2002 Honda Accord
Water won't heat
It could be a malfunction heating element, thermostat or both.
In most cases it's the heating element.
Check with a multi-meter for 115/220V on the heater tags.
In case you get this voltage there, you should replace the heating element.
In case you can't read the 115/220V on the heater tags, check thermostat's for continuity (you should read a low resistance). In case you can't get any measurement. You should replace the thermostat.
Good luck
Source:http://www.fixya.com/support/t188408-dishwasher_not_heating
Apr 18, 2012 | Dishwashers
Temp is reading -76 on the refrid side and won't reset
I think that this can be a problem out of the malfunctioning of the thermostat of the refrigerator. You can do one thing. Try to remember the temperature you did set prior to the problem. With the help of a thermometer, evaluate if the temperature is the same as it was set. If yes, there is something wrong with the display mechanism. If not, surely the thermostat is malfunctioning.
Thank You.
Mar 06, 2011 | Jenn-Air JSD2789GES Side by Side...
What is wrong when a malfunction indicator light comes on is it serious ?
It is only serious if you think that potentially getting stranded on the highway or damaging expensive parts of your car is serious. The light is what it is...a malfunction indicator light. It is telling you that one or more of the critical systems that your vehicle is equipped with is malfunctioning.
Jan 23, 2011 | Hyundai Accent Cars & Trucks
Dryer had built up lint,blew fuse,now will blow fuse after cleaning and replacing vent hose
if its heated electrically, not by gas,then it sounds like the heating element has shorted to the case and this would blow the breaker
Jul 28, 2010 | Amana NDE2335AY Electric Dryer
What can keep causing Check engine code P0128
CODE P0128- THERMOSTAT MALFUNCTION. POSSIBLE CAUSES 1. ECT SENSOR IS OUT OF CALIBRATION. 2. CHECK THE OPERATION OF THE THERMOSTAT IT MAY BE STUCK OPEN.3.INSPECT FOR LOW COOLANT LEVEL OR FOR AN INCORRECT COOLANT MIXTURE.
Jan 06, 2010 | 2004 Kia Spectra
Engine not getting hot check engine light is always on 2002 grand prix. Had intake manifold gaskets replaced 1 month ago
check or change the thermostat it could be stuck open thats why its all ways running cold
Oct 30, 2009 | 2003 Pontiac Grand Am
Indicator Lamp Warning
could be but it comes up for a reason
I suspect a cat converter malfunction and the explanation to keep the rpms lower indicates that it is not functioning properly or has failed and could be blocking the exhaust system
It could be a simple O2 sensor ( one after te cat converter) that has malfunctioned
don't wiat for the next service but have it checked out by an accredited service center and have the fault codes read
May 23, 2017 | 2002 Mini Cooper
Microwave oven dead
If the fuse is good, it may be an open thermostat or thermal cutout on or near the magnetron or on top of the cavity / body of the oven.
If it has a hood thermostat, that should read open, as opposed to the others, which should read closed.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Apr 22, 2008 | Panasonic NN-S254BF Microwave Oven
Heating & Cooling Logo
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
