Question about Proscan Televison & Video
Tablet screen turns off when hdmi hooked up
When I plug in my HDMI cable the screen on my tablet turns off I can see picture on TV but nothing on tablet
  • 4 Answers
If running Windows 7:
Right click on the desktop
Screen Resolution
Right click on the screen that is not activated
Choose activate.
Keep in mind that if you want to see the same display on both screen ie dual display then it will set the resolution to the screen with the smallest resolution, which may look a little sucky if you are running 1080p TV with lower resolution laptop screen, the other option is to choose extend screen
Posted on Dec 28, 2013
SOURCE: HDMI audio problems with my sharp LC42D64U
the problem is that your cable box is putting out too low of a bandwidth to your tv and is cutting out completely. Since its all digital either its there or not. try switching to componant cables. Cable boxes only support up to 720p anyway so you wont sacrafice any quality.
Hope this helps
Posted on Mar 24, 2008
gymhasafit
  • 31 Answers
SOURCE: Sharp Aquos LC-46d65U HDMI connect
First off a little tip that manufacturers don't tell you is that you HAVE to TURN OFF the POWER to ANY UNITS that you are Connecting to via HDMI!!!!!!! If not you can short out the Inputs!!!!!!!! HDMI is usually Automatic, But sometimes you need to go into the Menus on all Devices to the HDMI section and write down their settings and compare them. Any definition that you are not sure of check the Manual or Google it! Match all the Settings (there won't be Much!) Hopefully the Inputs were not Damaged it only takes one time to short it out and then the Repairman makes a few bucks! Good Luck!
Posted on Apr 29, 2009
  • 453 Answers
SOURCE: HDMI outlet seems to be bad/ no picture
u need a main signal board replacement
Posted on May 08, 2009
zlittell
  • 30 Answers
SOURCE: Television is not recognizing HDMI inputs
there is a possibility that there might have been a power surge sent over hdmi into the hdmi board on the tv. if on your model the hdmi board is seperate from the sine board then youll have a cheap replacement if not its gonna cost you roughly 300-400 is my guess.
call your repair guy
Posted on Aug 03, 2009
SOURCE: panasonic th-50pz80 10 flashing blinking red lights
The way to solve the problem with the TH-50PZ80U blinking light problem is to not buy Panasonic Products. I have had my TV about 21 months and it has started with the blinking light problem, just out of warranty. Panasonic is aware of this problem and refuses to do recall or fix the tv unless you are within the warranty or have bought the extended warranty. Legally they are within their rights, but I am also within my rights to air my complaint and inform others of this below par product. Who wants a TV that they have to unplug for a while and pug it in again for it to work. I want to push the power button and it come's on. I will never purchase another PANASONIC PRODUCT.
Posted on Oct 25, 2010
Rca 10" tablet need to connect to my phillips tv.Plug up nothing happens,Took a hdmi/rca cable from camera, hooked tablet to tv that made my tablets screen go black until unpluged from the tablet.
Screen going black usually means it is connected to another screen. Is there a setting on the tablet to enable output settings and a setting on the TV to enable input settings.
Jul 19, 2015 | Tablets & eReaders
How can i connect my tablet
Just going to go through steps.
1. mIni hdmi to to tablet
2. hdmi on other end of cable to a hdmi input on tv.
3. go to input on tv and change input where you plugged in hdmi.
4. start your tablet. what ever is on your tablet will now show up on tv. (home screen, movies, e-mail, etc.)
Just a reminder, you have to switch input on tv each time.
GOOD LUCK
Apr 19, 2014 | Acer Iconia A1-810-L888 7.9 inch MediaTek...
How do I hook up my acer iconia tab a500 to the tv?
Hi Cari,
There is a micro HDMI port on your tablet.
You can connect an HDMI cable to hook it to your TV.
Make sure that the one end of the cable should be a micro HDMI plug and the other end a normal one.
Also you must make sure that your TV supports HDMI connection.
Hope that helps.
Nov 18, 2011 | Acer Iconia Tab A50010S32u Notebook
When i go to hook up a hdmi cable to my philips flat screen it wont recognize that i have a hdmi plugged into it. so what could that be the tv? the hdmi works with my other tv though
This model has 4 HDMI inputs, do you get same problem in each HDMI input?
Did you checked HDMI input with any other video source like dvd player or PS3 etc instead of cable box?
Below are few helpful tips to connect HDMI input..
1. Ensure that your HDMI cable is certified.
2. Press SOURCE on the remote control to switch to another source and then switch back to the HDMI source.
3. Reset the accessory device and the TV.
• Turn on the TV
• Select the HDMI channel
• Turn on the accessory device
4. While the TV and the accessory device are powered on, unplug either end of the HDMI cable and then reinsert the cable.
Try above options and if tv still does not show picture of any video source through HDMI then it seems problem of HDMI processor located on main board, visual check is needed by qualified tech or call Philips if tv is under warranty.
Hope these info will help you.
Thanks.
Nov 26, 2010 | Philips 42PFL7403D/27 42 in. LCD TV
Sony 60 in LCD edge LED TV: Hooked up new TV to a cable box - have HD picture but no sound. TV speakers say on. Makes sound when TV channel is changed (static). But nothing when input cable (via HDMI) is...
Your cable box most likely has a setting for audio HDMI such that HDMI sound is turned ON etc. rather than standard audio. Also check the TV settings for HDMI audio being set to ON. This should be a simple fix. HDMI audio usually is just a user setting adjustment and nothing more. Somewhere in your on-screen menus you should find the place to adjust HDMI audio.
Aug 12, 2010 | Sony XBR60LX900 60 in LED TV
DVD hooked up to sony bravia tv: have dvd power on, but can not get any set up menus (or anything) from dvd to show on tv screen.Unable to set up remote as menu does not appear on tv screen.
Hook up the player with RGB (Red-Green-Blue or component) cables and try the picture. If everything works OK, then go to the menu and turn on the HDMI output and set the resolution (if needed).
Not every HDMI unit works with every HDMI TV. You may also have a bad HDMI cable. On a DVD recorder, you may have your HDMI cable connected to HDMI IN. You must use HDMI out.
Mar 28, 2010 | Sony RDR-GX7 DVD Recorder
Sold as HD Ready, but hopw do I connect HDMI to it to get HD picture ?
to hook hdmi to it you need to purchase a hdmi cable and plug it into the tv and then into what ever you want for example like your cable box,dvd player,etc.once hooked up turn tv to hdmi input
May 31, 2009 | Panasonic Televison & Video
Samsung HDMI issue
Have you try to replace your HDMI cable?I recommend you to pick up a good Monster HD700 HDMI cable from a local retail store like best buy or circuit city.In case it isn't the cable problem,you could return it.
However,when you are a using the HDMI cable,it is normally either have both picture and sound or nothing at all.Are you sure you didn't hook up the audio OUTPUT from your TV back to a receiver input?
Or even an optical output from the TV to the receiver?
solutiondoct
Sep 24, 2008 | Samsung SPN4235 42 in. Plasma HDTV
Televison & Video Logo
54 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
