Question about Rinnai Toyostove Direct Vent Heater: Toyostove Laser 73 Shipping
Burns orange? Flame is orange not blue?
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 82 Answers
Could be orange for a few reasons could just be burning some dust or something in the air. if it keeps staying orange i would say that it has a cracked heat exchanger and the fan is disrupting the flame.
Posted on May 22, 2014
Why does my burners not ignite into a blue flame
The color of the flame can be affected by a few different things. here are three of them: 1. If there is a food substance contacting the burner where the flame comes out, this will give the flame an orange tint. 2. If the propane is being burned at a very high rate, the flame can become invisible in daylight-like conditions. 3. If the propane is being burned at a very low rate it can also have an orange tint. Hope this is clarifying.
May 24, 2014 | American Range AF45LP Deep Fryer
Flame burning too orange
You need to get a Plumber or Appliance Tech to come out immediately and check the fuel to air ratio. You are not burning your fuel at the proper mixture. A blue flame is good, yellow-orange is bad.
Normally this is because the burner area is dirty or the pressure regulator may be set too high/low. The black marks are a sure sign that your ratio is too rich and it's just going to build up more soot and become unhealthy and dangerous.
http://inspectapedia.com/plumbing/Gas_Flame_Noise_Defects.htm
Don't wait...
Mar 27, 2014 | Water Heaters
You must get more air to water heater, and check venting .... immediate CO poison danger.
Call qualified plumber immediately.... because deadly carbon monoxide is not being vented properly.
http://waterheatertimer.org/Water-heater-safety-precautions.html#soot
Gene h
Glo warm heater has an orange flame. It shouldn't, should it?
it should be blue , too much air or burner needs cleaning , how long since it was
serviced ? t
Oct 19, 2011 | Desa International Blower Glow Warm Wall...
I have an orange flame on the burner instead of blue
The difference between an orange flame and blue flame is the amount of air in the combustion process. SO if the flame is orange it is being starved of oxygen. The gas burns dirty and soot is generated.
Sometimes with an older heater the exhaust venturie becomes plugged and carbon monoxide is released into your home- in this case your heater would make a woof or poping sound when starting up or shutting off. This is a dangerous unsafe situation and professional help is needed.
What you can do is try to make adjustment yourself, if your confident the other situation does not exist. Your water heater should have a little deflector shield on the gas line between valve and burner (typically immediatly after the orfice). Sometimes these will have to be slide front or backwards or twisted. The adjustment of deflector shield must be opened more to make the blue hotter flame to mak eyour heater operate at peak efficiency.
Good Luck
Jan 03, 2011 | Whirlpool Water Heaters
Should it be an orange or a blue flame on my masterbuilt deep fryer
blue with just a small amount of orange flame flicker ervey now and then,if its orange more than blue your gas orfice is dirty or you need to open up the air shutter so you get more air to burn gas more completely
Nov 25, 2010 | Masterbuilt 20020507 Deep Fryer
On my gas fireplace, the pilot light used to burn blue. Now it's burning more of an orange color. How do I fix it?
needs blowing out remove pilot tube from pilot remove injector and clean it out then replace it all test joint with soapy water to check for leaks
Jan 21, 2010 | Vanguard International Blue Flame - Medium...
Side burner on propane gas grill burns with orange flame ratheer than blue
here is a link to a page that shows what the colors of the flame should look like and what causes the orange instead of the blue flame. http://www.appliance411.com/faq/gas_range_flames.shtml
I would begin by checking to be sure you do not have a spider or a cob web in the burner partially blocking the gas or the air intake.
May 12, 2009 | Weber Gas Go-Anywhere Grill
Kenmore range broiler burns orange not blue and leake gas
The only real important thing is blue flame with a orange tip,
also ranges have different nozzles for Natural Gas (NG) or propane(LPG)
he can check for leaks with soapy water at the flex line connection
Jan 05, 2009 | Kitchen Ranges
Rinnai Toyostove Direct Vent Heater: Toyostove Laser 73 Shipping Logo
159 people viewed this question
Top Rinnai Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Tim Whalen
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
