Question about Pyle Pbt30m Ergonomic Wireless Bluetooth Headset Ear-piece
How do you connect a 'Rockcandy' bluetooth headset to a PS3
I am needing a key code for my RockCandy Bluetooth Communicator. Can someone please help me?
Default code is usually 1111 or 0000. Check the box, or call the manufacturer.
Dec 23, 2014 | Video Game Consoles & Games
How do you connect to the ps3?
*NB: it will ONLY work for communications, NOT for game audio. (lame az, I know!)
  1. hold in the headset's power-on button until it flashes red/blue for pairing.
  2. Next make the ps3 scan: settings> accessories settings> manage bluetooth devices> register device (yes)> scan and add. (probably passkey 0000)
How to connect any Bluetooth headset to your PS3
Dec 25, 2013 | Creative WP-350 Headset
Recently when i try to connect the bluetooth to my ps3 it says that a connection could not be established.Howq do i fix this?
If the Headset has been paired with another Bluetooth device, the PS3 will have trouble finding the Headset. Either remove the Headset from the paired device or turn off the Bluetooth power on the paired device.
Aug 18, 2010 | Mad Catz PS3 Bluetooth® Headset Wireless...
How to connect to my ps3
You may want to review this guide for connecting a bluetooth headset to a PS3:
(Click here)
http://boardsus.playstation.com/playstation/board/message?message.uid=26900460
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thanks!!
Jan 11, 2010 | Plantronics Explorer 220 Bluetooth Headset...
Can Nokia Bluetooth Headset BH-207 Wireless Headset connected to ps3?
I believe it will work. Let me know...
(Click here)
Dec 11, 2009 | Nokia Bluetooth Headset BH-207 Wireless...
The ps3 keeps scanning and wont pair with the headset
BELIEVE IT OR NOT, SOME HEADSETS ARE NOT COMPATIBLE WITH PS3. I HAD SOME PROBLEMS WITH MY PLANTRONICS 3XXX. I FOUND THE SOLUTION WAS THAT I WASN''T HOLDING DOWN THE BIG BUTTON ON THE FRONT LONG ENOUGH. WHEN I WOULD PRESS THE BUTTON, WHILE PS3 SEARCHED, I WOULD ACCIDENTALLY TURN OFF THE BLUETOOTH.
BE SURE THE BLUETOOTH IS POWERED ON. ONE TAP SHOULD DO.
WHEN PS3 BEGINS TO SEARCH, HOLD DOWN BIG BUTTON, AND DO NOT RELEASE UNTIL PS3 FINDS.
IF THERE IS A LIGHT ON THE BLUETOOTH, IT WILL PROBABLY BLINK A COUPLE TIMES WHEN FOUND. THE NAME OF THE BLUETOOTH WILL ALSO SHOW ON THE TV.
OH YEA, BE SURE TO CHECK YOUR PS3 SETTINGS.MAKE SURE IT IS SET TO ACCEPT BLUETOOTH HEADSET CONNECTION.
Dec 09, 2009 | Mad Catz PS3 Bluetooth® Headset Wireless...
No sound from bluetooth headset when paired w/ ps3 and audio set
the bluetooth headset is not compatible.get a compatible headset for ps3
Dec 03, 2009 | Sony Playstation 3 (PS3) Console
I can not get my mad catz bluetooth connected to my ps3.... I also do not have the instructions but i do have the pass code
A Bluetooth headset has to be registered, or "paired", with your PS3 before it can be used.
  • Make sure your Bluetooth headset is fully charged before you begin.
  • Check your headset instructions for entering "pairing mode". Activate your headsets' "pairing mode" so it can be recognized by the PS3.
  • On the Cross Media Bar (or XMB) of the PS3 go to the "Settings" tab, then down into "Accessory Settings", then down into "Manage Bluetooth Devices".
  • With your headset in pairing mode, follow the onscreen instructions and let the PS3 scan for your headset. When your headset is found, follow the prompts and enter a pass key (if necessary- the default is usually 0000 for all brands). The pairing should now be complete.
Hope this helped.
Nov 18, 2009 | Mad Catz Bluetooth Headset for PS3
How doi connect my headset to my ps3
We've just received some new information about pairing a bluetooth headset to a PS3.
(Click here)
Oct 21, 2009 | Plantronics Explorer 220 Bluetooth Headset...
I cant get my plantronics ex 233 bluetooth to connect to my ps3
when i charge my bluetooth, the light is red for a few minutes but it goes out and its not charging anymore. Please help
Mar 04, 2009 | Plantronics Stereo Earbud Headset for Use...
Pyle Pbt30m Ergonomic Wireless Bluetooth Headset Ear-piece Logo
727 people viewed this question
Top Pyle Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Pyle Radio Communication Expert? Answer questions, earn points and help others
