Question about Convair Portable Air Conditioner
Water leaking from ky 32 xc
How do I fix this
Hi dear
call this company technician because this company technician is good in suggestion and working
Air conditioner
Posted on Dec 28, 2013
Coolant leak barina xc
Water pumps do this.
Mar 21, 2014 | 1992 Holden Barina
Amway e-84 leak
hi , here ya go. good luck and get a spare for future needs as well as apply some o ring lubrication water bases in a clinch ky personal lube works fine.
http://www.freshwatersystems.com/p-5833-o-ring-for-amway-am101-e84-e-85-gen-iv-water-treatment.aspx
Oct 23, 2013 | Amway A101, E84, E-85, E-9225 Compatible...
How to fix onan 4000 that will not stay running
Check the slips rings and brushes, check the stator and rotor windings for continuity and for shorts to ground. Check PCB plug connections. After that you need a new control board
Jan 07, 2013 | Onan Cummins 4.0 KY-FA/26100 RV QG 4000...
Water is over flowing and coming out over the top of my hot water heater, i shut the water off and turned the temp down and turned the water back on after a few hours and water still is over flowing over...
If pipes are leaking, then that can be repaired.
If tank is rusted out and water escaping from the tank, then turn off the water plus power to the heater for safety, and then replace water heater.
Rusted water heater can be welded for repair, but remember that hot water is under pressure and tank can rupture any time.
Safest course if to replace heater.
Open following link for leaking water heater checklist:
http://waterheatertimer.org/Leaking-water-heater.html
Jul 27, 2011 | Whirlpool Water Heaters
Hi I have a convair ky-41/xc (b02) portable airconditioner which has no power. I am an electrician and have found the unit was fitted with a T5 ceremic fuse element whereas the circuit diagram states that...
Dear Electrician! Any electrical appliance the starting current will be 2 to 3 times of running amps. In your unit if it mentioned 8.5 amps, it's better to fix 15 to 25 amps fuse.Helpful"
Jan 04, 2011 | Convair Heating & Cooling
We have a ice maker and water dispenser on our magic chef refrigerator. Water has been turned off due to leakage on floor under unit. what is the problem?The unit is a side by side.
I see a lot of cracked lines and cracked inlet valves take back off turn water on and find leak dont be scared just unplug it 1st any questions we are here for you Allbrand appliance lou,ky
Jan 29, 2010 | Refrigerators
Oil Leak
Need model and serial number off this unit in order to proceed.
However, if it is a KY model, with an about 2" cover underneath. That cover is blocking the oil drain plug. It is possible that the oil drain plug is leaking. Remove and drain oil into pan. Clean the plug and add plumbers tape to the plug and install. Then fill the unit back up with oil.
Mar 14, 2009 | Watts Onan Portable Generator - 4000 ,...
My KY yellow light is blinking. What should I do?
The k5400 is not recognizing that the ink cartridge is installed. Clean the contacts on the back of the ink cartridge and also the contacts in the K5400 printer. I always use 91% isopropyl alcohol, Hp says to use distilled water. Do let the contacts completely dry before reinstalling.
Feb 24, 2009 | HP Officejet Pro K5400 All-In-One InkJet...
Convair  Portable Air Conditioner Logo
99 people viewed this question
Top Convair Heating & Cooling Experts
Donni Steen
richie46
ray gallant
Are you a Convair Heating and Cooling Expert? Answer questions, earn points and help others
