Question about Insignia Televison & Video
Auto channel search
How do I run auto channel search?
    Top Expert:
  • Insignia Master
  • 74,198 Answers
Refer its user manual for details.
Posted on Dec 28, 2013
falspet
  • 438 Answers
SOURCE: Auto Channel Search places all channels in Skip
check the agc line from the tuner is functioning properly, if the agc signal , is not reaching the processor it will register that channel as being inactive and lock it out, there is not much circuit to contend with so a multimeter should do the trick to trace down the fault, you should find AGC marked on the board where the tuner modual is mounted.. i suggest obtaining a service manual to do the job good luck
Posted on Jan 28, 2010
  • 8 Answers
sounds like the tuner section of the main pcb isn't working properly.
Posted on Aug 21, 2008
Danmart
  • 291 Answers
SOURCE: auto channel search.
Check the r/c[remote control] for ' fresh ' batterys.
Do you have " air wave " reception? or cable connection?
air wave reception will scan but cable reception can't scan because the channel is 'fixed' at ch.3 or ch.4.
Posted on Nov 30, 2008
SOURCE: No digital channels after running auto search
Same thing with my vizio vx37l tv. Did you fix the problem bpakja? If so please let me know how.
Posted on Dec 10, 2009
  • 1779 Answers
SOURCE: user manual auto search for channel
You can find the user manual at www.retrevo.com
Posted on Dec 26, 2010
How to run a n auto channel search?
stop pushing buttons your not sure of.
To perform a channel scan using the coaxial input:
Press the INPUT button on your remote to view your current input source. ...
If the TV input is not selected, press INPUT until the TV input mode is selected.
Open the on-screen menu and select TV or Tuner option. ...
Highlight Tuner Mode and select the correct option:
Dec 26, 2015 | Insignia Televison & Video
Auto Channel Search, how do you accomplish this.
Use your Insignia remote to select the initial set up procedure and run auto channel search.
Mar 03, 2015 | Insignia Solutions NS-24E200NA14 24" LED...
How do i finde auto chanel seargh
Auto channel search is how your tv finds channels that are available. Under settings in the menu should be initial set up. There you will find channel search.
Feb 20, 2015 | Insignia Televison & Video
How do i tune the channels on a toshiba rc3910
Hi
Before tuning the set to auto tune mode, make sure the antenna or cable, whatever may, connected to its appropriate sockets at the back of the set firmly. To make it autotune:
As new services are broadcast, it will be necessary to
re-tune the television in order to view them.
Auto Tuning will completely re-tune the television
and can be used to update the channel list. It is
recommended that Auto Tuning is run periodically to
ensure that all new services are added. All current
channels and settings, i.e. locked channels, will be
lost.
[1] Select the SETUP from the main menu by using
Up or Down buttons. Press OK and Setup menu
will be displayed.
[2] Select the Installation from the Setup menu
by using Up or Down buttons. Press OK and
Installation menu will be displayed.
]3] Select Automatic Channel Scan from the Installation
menu by using Up or Down buttons and press OK.
A screen will appear warning that previous digital
programmes and settings will be deleted. Select Yes
and press OK to continue with the Auto tuning.
The television will start to search for all available
stations.You must allow the television to complete
the search. When the search is complete the Auto
tuning screen will display the total number of
services found.
* After search is completed for digital channels, a
message asking whether to search for analogue
channels appears on the screen
** Press the OK button to search for analogue
channels. The following menu appears on the screen
for analogue channel search
OK.
Jul 10, 2011 | Toshiba Televison & Video
Someone tried changing channel manually. Now I get a message that says "run auto channel search' but I don't know how to do this, please advise
you have to be on the Cable/Antenna Input. Then you can access the menu option to auto search for you channels again.
Mar 21, 2010 | Insignia 37" LCD Flat-Panel HDTV
Sep 30, 2009 | Vizio VX37L Television
Auto search through
Tested and verified solution:
  1. Set Tuner Mode to "antenna".
  2. Run a channel scan. Should get zero channels found.
  3. Set Tuner Mode to "cable".
  4. Run another channel scan.
  5. Celebrate!
Aug 16, 2009 | Vizio VX37L Television
New ariel installed on communal roof, have tried auto store, some channels now missing, samsung 23" LCD TV LE23R8
 you must run "auto program search"/"auto store" again and let the TV find the programs. then put them in order and store.
If you feel some channels are missing, try to find them manually. The auto store function sometimes skips programmes with less tolerant range, even if they are watchable in a fairly good quality. And search slowly and pay attention and go back if you feel you just skipped something. Good luck and lots of patience!
A new aerial sometimes might mean loss of some channels.
I hope it was helpful
Apr 17, 2009 | Samsung Televison & Video
Auto Channel Search
Jul 28, 2008 | Dynex 32 in. LCD Flat-Panel HDTV
Channels not changing
Auto search button might be stuck/ jamed in cabinet. release it and Prog. buttons will be work.
Jun 12, 2008 | Televison & Video
Televison & Video Logo
82 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
