Question about Honeywell RTH6350D1000 5/2Day Prog Thermostat
Need help replacing Janitrol HPT-1860 thermostat with a Honeywell model RTH6350D
I am not sure where all the wires should go. On the existing Janitrol HPT-1860 thermostat, the wiring configuration is as followed: Y=Yellow G=Green R=Red O= Orange W2= Whie E= Black C= Blue The Honeywell RTH6350D has the following listed for a heat pump system: L, Aux/E, G, O/B, Not Used, Y, R, RC. FYI, I have a 2 stage heating and a single stage cooling system.
4 Suggested Answers
  • 68 Answers
SOURCE: replacement of heating programmer
yea you should be able to just when you remove the old one mark witch wire went to witch connection by marking it some how i personaly take one wire at a time wrap it with a small piece of white tape and write the letters on the piece of tape then when i replace with the new one i cant mess it up also look for any of the wire connections to see if any have to be or have been jumped out
Posted on Dec 14, 2008
garypetterss
  • 15 Answers
SOURCE: how to program my honeywell thermostats? program
pick the right model from this list http://yourhome.honeywell.com/home/Products/Thermostats/ click on detail and it will offer you downloadable manual.
Posted on Apr 11, 2010
  • 5089 Answers
SOURCE: Light stays on
Question posted under Honeywell thermostat.
If you have honeywell thermostat, then model number is located on back of device.
Google that model number in following format: Honeywell xxxxx4 .pdf
That will give you on-line pdf manual that is downloadable and searchable.
Then re-post question with exact model number and include what you are operating so expert can access and read manual alongside you.
If you have some other device, then post the brand and model number, and include what voltage, and what you are controlling for best possible solution.
If you have a timer or a switch, it is possible that more information is available on following links:
http://waterheatertimer.org/How-to-wire-switches.html
http://waterheatertimer.org/How-to-wire-timers.html
Posted on Aug 28, 2012
I have a honeywell T87K round thermostat (2-wires R and W). I just purchased a honeywell WIF 7-day programmable thermostat RTH6580WF. How do I install the new thermostat? Is it even possible?
Programmable is in unit nothing to do wire fto urnace two wires cut furnace on and off you should have instructions to use two wires with your instructions
Aug 18, 2015 | Honeywell T87K1007 Mechanical Thermostat...
How can I make a thermostat connection?
Good morning Yakup.
The best way is to write down how the old t-stat was wired. If that's not available, the only way to determine for certain where each wire goes, is to check what the installer did at the terminals in your home comfort system. Please note the there is high voltage electric in each piece of equipment so if you decide to open up panels, there is always the risk of damaging the equipment or worse, injury or death if you are not a qualified service technician. However, typical color assignments are as follows:
R= (24v from heating appliance) Red
RC= (24v from cooling appliance) Red
These two are only separated when you have two different appliances providing seasonal comfort, like a boiler and an air handler. If you have a warm air furnace with an air conditioner or a heat pump attached then R+RC will have a jumper across them and only one RED wire will be landed there
W= (heat) White
Y= (cool) Yellow
G= (fan) Green
Those colors are pretty standard
The rest of the colors depend on availability in the jacket and are really up to the installer. You mentioned 7 wires but 8 conductors is more likely so I'm assuming the remaining colors are black, brown, blue, and orange.
I always use the following:
C= (common) Black
O/B= (reversing valve for a heat pump) Orange if the valve is energized for heat and Blue if the valve is energized for a/c.
Aux/E= (auxiliary or electric heat) Brown
L= I believe this is a diagnostic terminal for some systems with feedback data and is not used frequently.
After wiring there is some programing to do to set up your new thermostat to your type of system.
Hope that helps. God bless and be careful.
Aug 06, 2014 | Honeywell RTH6350D1000 5/2Day Prog...
How do I change Honeywell RTH6350D thermostat from Celcius to farenheit?
yourhome.honeywell.com/home/Products/.../RTH6350D.ht
Operating manual.
May 27, 2014 | Honeywell RTH6350D1000 5/2Day Prog...
How to reset thermostat
as it is a honeywell product and the new second one didn't work it is not for fixya site to fix but as the new part is still under warranty then it is up to honeywell agents to come and fix under warranty
if push comes to shove talk legal,action as it is the company's responsibility to fix faults of new products under warranty
It was not even up to you to buy a new part as it should have been replaced free
May 28, 2017 | Water Heaters
Replacing a janitrol hpt 18-60 with a Filtrete 3m-22
What is the question that you have about this? What is the make and model of the hvac unit that it is running?
Apr 21, 2013 | Filtrete Thermostat. 7-Day Digital...
How do I connect the two thermostat wires from a Honeywell R8184G4009 to a programable thermostat. My old thermostat is not marked.
On the Protectorelay Oil Burner Control R8184G4009, you connect the two thermostat wires @ "T" and the other "T". On the ACE Smart Temp Universal programable therostat, connect one wire to "Rh" and the other wire to " "W". Be careful if you are using this thermostat for A/C. In that case, make sure there is no jumper between "Rh" to "Rc".
Feb 02, 2013 | Honeywell Protectorelay Oil Burner Control...
Light stays on
Aug 27, 2012 | Honeywell T6360b1028 Room Thermostat
Honeywell RTH6350D1000 5/2Day Prog Thermostat Logo
257 people viewed this question
Top Honeywell Water Heaters Experts
paulcarew
Lawrence Oravetz
Steve
Are you a Honeywell Water Heater Expert? Answer questions, earn points and help others
