Question about Stanley Air Tools & Compressors
The trip will not compress so the tool will not fire.
Bostitch SX1838K stapler tip (trip) will not compress so the tool will not fire. It's brand new, just out of the box. It's the second one after returning the first to Lowes because it did the same thing and they said it was defective. Is it possible that both are defective or could I be doing something wrong. If I take the front apart and hold the tip in, put it back together and carefully use it, it works. As soon as the tip pops out all the way, it will not fire again.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,727 Answers
Check for a screw in the lock. they do this for shipping procedures maybe ???
Posted on Dec 28, 2013
  • 3 Answers
SOURCE: Stanley bostitch coil nailer gun
check the safty shaft and see if something could be under trigger safty causeing it to fire.
Posted on Feb 20, 2009
  • 3 Answers
SOURCE: nail gun won't fire
Try this. Take the handle off the tool per the cleaning instructions. Install the battery and push down on the roller lever in the upper handle. It's located close to the fan blade. (Item 27 on the tool schematic.) Keep your finger out of the way or the fan will bite you.
If the fan goes on, then the roller lever is bent and needs replacing or adjusting.
If the fan does not go on, release the lever and pull the trigger. If the fan works, then the molded circuit board needs to be replaced.
Posted on Apr 09, 2009
  • 24 Answers
SOURCE: wanted to unplug my plunger to my s32 sx bostitch
The spring is located under the head valve.Turn the head upside down put in the spring and than the head valve
Posted on Apr 14, 2009
comax
  • 154 Answers
SOURCE: Firing Pin doesn't return
The piston is returned to its firing position by air from the trigger valve after the piston has fired. It relys on the piston sealing against the bumper at the bottom of its stroke, if the bumper was damaged when the driver shattered or it was put in upside down the piston will not return. Also the piston uses air fed into the return chamber from the little holes in the cylinder, if the seal over these holes is damaged the piston may not return. Basically change the bumper and the check seal on the cylinder.
Posted on Aug 05, 2009
  • 131 Answers
SOURCE: bostitch s32 stapler. slight air bypass on trigger, will not fire
You need a new trigger valve TVA6.
Posted on Sep 04, 2009
Does anyone know where to get Bostitch T26 stapler parts. I contacted Bostitch directly and they couldnt help me. Also looked at several online parts houses.
Bostitch is not known for great, long-term product support. Your best bet would be to take your stapler to an air-tool repair center (check Google for your area) to see if they can make it work. Otherwise, consider replacing the tool with a higher-grade brand such as Senco.
Nov 22, 2017 | Tools & Hardware - Others
Bostitch stapler stuck
Hello, Go here to download the operators manual to help you with troubleshooting this stapler. It also will have a number for tech support so you can call for help. Bostitch Office Products Staplers Pencil Sharpeners Hole Punchers Tools...
Jun 06, 2014 | Stanley Bostitch B8 Electric Stapler
Bostitch electric stapler wont open
Hello, Go to this website for support number and downloading of the operators manual for the model of stapler. Bostitch Office Products Staplers Pencil Sharpeners Hole Punchers Tools...
May 01, 2014 | Stanley Bostitch B8 Electric Stapler
Door springs, part no. H286, for a Bostitch H2B stapler
Parts for the Bostitch H2B Hammer Stapler can be purchase from MJS Floorcoverings Manfield Brisbane
Dec 16, 2009 | Stanley Hand Tools
Air Tools & Compressors Logo
Top Stanley Air Tools & Compressors Experts
John Trevino
yoopertech
Joe Garcia
Joe Garcia
Are you a Stanley Air Tool and Compressor Expert? Answer questions, earn points and help others
