Question about Lands Phones
Yamaha stratoliner headlight
The head won't come on after the motor is running checked the fuse and it was ok
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,727 Answers
Did you check the bulb ???.
Posted on Dec 28, 2013
2005 1700 warrior has no power to headlight or dimmer fuse good, new light
Hi, Warren if your headlight is not working, only one beam works, keeps burning out, blinking, or is dim the first thing you need to check is the headlight bulb for damaged filaments then check your light circuit fuse, then check your head light bulb socket ground wire for a clean tight connection, that being said the usual suspects are:
1. Faulty ground or power supply wire to headlight bulb socket.
2. Worn down solder contacts or loose fit of the bulb base in the socket due to vibration.
3. Worn, chaffed, or broken wires in the light circuit.
4. Corroded, broken, or loose pins/sockets in wire connectors.
5. Faulty hi/lo beam switch.
6. Faulty ignition switch.
7. Fuse is good but no continuity on both sides.
8. Faulty wiring between battery positive and headlight bulb socket.
9. Weak charging alternator/generator.
10. Faulty voltage regulator/rectifier ground or overcharging.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Headlight Won Light
Headlight stopped working
Yamaha XV1700PCRC Service Manual
OEM parts for Yamaha
Yamaha XV1700PCR Road Star Warrior Owner Manual
Jan 31, 2013 | 2002 Yamaha Road Star Warrior
Replaced headlight bulb, still won't work
Hi, Vlelkins if your headlight is not working, keeps burning out, blinking, or is dim the first thing you need to check is the headlight bulb for damaged filaments then check your light circuit fuse, that being said the usual suspects are:
2. Worn, chaffed, or broken wires in the light circuit.
3. Corroded, broken, or loose pins/sockets in wire connectors.
4. Faulty hi/lo beam switch.
5. Faulty ignition switch.
6. Fuse is good but no continuity on both sides.
7. Faulty wiring between battery positive and headlight bulb socket.
8. Weak charging alternator/generator.
9. Faulty voltage regulator/rectifier, overcharging.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
03 Star 1100 headlight running lights not working
http://www.sloneservices.com/SilverBack/Other-Stuff/V-StarShopManual99-07.pdf
http://www.starmotorcycles.com/assets/service/manuals/2000/LIT-11626-13-36_96.pdf
Jul 28, 2012 | 2001 Yamaha V Star 1100 Classic
Remove headlight bezel 2006 stratoliner
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Headlight bucket removal
2006 stratoliner hid install
Yamaha XV19SW Service Manual
Yamaha ROADLINER XV19SW Owner Manual
Apr 28, 2012 | 2006 Yamaha Stratoliner S
Headlight switch on yamaha r6 won't work lights
Hi, Anonymous if your headlight is not working, only one beam works, keeps burning out, blinking, or is dim the first thing you need to check is the headlight bulb for damaged filaments then check your light circuit fuse, then check your head light bulb socket ground wire for a clean tight connection, that being said the usual suspects are:
http://www.r6messagenet.com/forums/r6-maintenance-technical/102278-headlight-wont-turn-electrical-problem.html
http://www.r6-forum.com/forums/57-garage-mechanical-help/95665-03-r6-headlight-problem.html
2003 2004 Yamaha YZF R6 Service Manual R6 Moto Data Project
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
Mar 18, 2012 | 2003 Yamaha YZF-R6
My running lights stopped working on my 2006 stratoliner fuses are not blown and bulbs are good. Is there an inline fuse somewhere
Hi, Mrsman1 and the usual suspects are:
1. Bulbs are burnt out.
2. Light circuit fuse was blown.
3. Faulty ignition switch.
4. Faulty, corroded or cut wire connector, pins, sockets etc. in the running light circuit.
5. Loose, broken or corroded common ground.
Driving Light Fuse
Review Electrical Connection Running Lights
Aug 17, 2011 | 2006 Yamaha Stratoliner
I have a 2005 yamaha yzf r1 and it says the brights are on but the headlights won't come on. I have checked the fuse and changed the bulbs and they still won't work.
Hi, Tom if your headlight is not working, keeps burning out, blinking, or is dim the first thing you need to check is the headlight bulb for damaged filaments then check your light circuit fuse, then check your head light bulb socket ground wire for a clean tight connection, that being said the usual suspects are:
04 R1 Headlight Problem
http://www.r6messagenet.com/forums/r6-maintenance-technical/123412-headlight-not-working-bulbs-fuse-good.html
2004 2005 Yamaha YZF R1 Service Manual R1 Moto Data Project
Jul 15, 2011 | 2005 Yamaha YZF-R1
2001 yamaha R1... head lights not working low beam or high beam....replaced bulbs and fuses and check the switch and all is good plus check power to fuse and all was ok,,,no power at head lights... I can...
headlights not working
2000 2001 Yamaha YZF R1 Service Manual R1 Moto Data Project
Apr 07, 2011 | 2001 Yamaha YZF-R1
I blew the fuse for the running lights front...can't find the fuse. there are a series of 3 to 25 amp fuses just below the oil cap but they are all in working order. also need to get an owners manual Vince
There is as fusaeable link in the main headlight compartment bucket, you have to take it apart to get to the fuse. There is likley a short in the running light housing which causes it.
May 11, 2009 | 2006 Yamaha Stratoliner S
Passing lamps won't come on
Passing lights. check all of the fuses, replace any fuse that's burned or cut in the middle. Flasher relay could also be the problem.
Mar 15, 2009 | 2007 Yamaha Stratoliner S
Lands Phones Logo
16 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
