Question about Bissell 7901-1 ProHeat Scotchgard Upright Wet/Dry Vacuum
Water when I squeeze the handle no water comes out
  • Anonymous Nov 18, 2007
    When I squeeze the handle, no water comes out. And I accidentally broke the little red thing that is inside of the water tank
  • 1,673 Answers
Does water squirt out of the hose nozzle, if it does, then check the heater inside the handle asm. Make sure that where the tubes hook up to it are not clogged. If water doesn't squirt, check for the seal at the bottom of the tank, it needs to be on the tank, not in the hole. The flow indictor cap is leaking air or maybe is too tight. If you had the top cover off, make sure that the tubes are routed right so as not to get pinched when the cover is put back on, the smart mix knob should be in the water setting and that the piston is on the bottom of the smart mix know. Pump is bad.
That red thing is most likely the float asm Part #2140325 .
Posted on Jan 17, 2008
How to use bissell Ready clean
To operate you simply fill the water tank and the soap container and turn on the the switch. As you push the cleaner forward squeeze down on the handle, release the handle as you slowly pull back. Enusre you clean the filters after use.
Sep 29, 2015 | Bissell ReadyClean Deep Cleaner
Bissell instruction manuals
I think you are referring to the stair/upholstery tool. Attach the hose
to the machine...turn the pump and vacuum on and use....liquid is
dispensed when you squeeze the handle on the tool..
Aug 18, 2014 | Bissell 9500 ProHeat 2X CleanShot Upright...
When I put the clean water bottle on water pours out of the bottom. A little water has always come out but it is now pouring out. I tested my water bottle which seems to be okay. What is the problem?
I have the same problem with mine. I did the chat thing at the Eureka site, but the info wasn't helpful. There is a little part that opens the bottle to release the water when the handle is squeezed. I don't know if that needs replaced or if there is something stuck in the handle grip or ??? I am only putting 1 gallon of water in the tank, so it is not over-full. It is tap water. I live inside a city and have soft water. I don't think it has anything to do with the upper tank, though.
Mar 05, 2013 | Eureka 2576A Steam Vacuum
Clean water and solution will not dispense
This is an unusual problem. The most likely reason is that the supports inside the upper handle grip have broken, and when you squeeze the trigger, the rod that opens the reservoir assembly is not pushing open the valve. If you remove the upper tank, and look behind it, you should be able to see the end of the actuating rod sitting on top of a rubber valve assembly. Squeeze the trigger and watch the rod to see if it pushes down on the valve. If it doesn't, the upper handle grip will likely need replacement. If it does push down on the rubber seal, the reservoir assembly has probably failed and may need replacement.
Jun 07, 2011 | Hoover SteamVac F5914-900 SpinScrub...
Bissell Proheat Problem
Take the top part of the handle off, make sure that the rod in the handle is moving up and down when squeezing the trigger. The lower part of the handle has a valve that the handle rod pushes on, it make be stuck in the open position.
Jul 15, 2008 | Bissell 1699 ProHeat Clear View Upright...
Hoover steamvac won't spray water on carpet.
Check the ank valve to make sure when you push it in that water is coming out. The reservior asm, (the tank bottom sits on this)is bad or the rod in the handle isn't pushing the reservior asm when you squeeze the trigger.
May 15, 2008 | Hoover F6212-900 / F6215-900 SteamVac...
My Hoover floormate H3000 won't put out any solution.
Check the valve at the bottom of the tank, push it in to see if it releases the water ok. The tank sits on the reservior asm. the rod inside the handle hits this asm to release the water. Watch the rod as you squeeze the trigger to make sure it is hitting the asm. If it is then the reservior asm is bad, if not then a problem inside the handle.
Mar 07, 2008 | Vacuums
Clean water tank
Will the water come out of the tank when you depress the valve at the bottom og the tank? The tank sits on a resevroir asm., is the seal on it, black and round. Inside the handle is a rod, so when you squeeze the trigger, it pushes onto the reservoir to release the water, check to be sure it is, if not then you have a problem inside the handle or a bad reservoir asm. is bad.
Feb 26, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Either you have a pinched or clogged water line, or the rod in the handle is pushing down like it should. The drw back is Bissell has deemed this unit and its parts obsolete. So any parts are hard to find.
Nov 04, 2007 | Bissell 1950-3 Quicksteamer Plus Vacuum
Bissell 7901-1 ProHeat Scotchgard Upright Wet/Dry Vacuum Logo
69 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
