Question about Kenmore Refrigerators
My refrigerator door does not come up high enough to push in the button when it closes, so the alarm keeps beeping to signal that the door is not shut. I thought if I removed everything from the door, that would make it lighter and it would shut properly. It only worked for a short time. I know if I could raise the door about one eighth of an inch, the door would hit the button and the beeping would stop. Any idea how to raise the door an eigth of an inch...
You may have one of two problems, you either have too many spacers on the top hinge or not enough spacers on the bottom hinge. With the door on, measure the amout of of distance the door has to come up in order to close properly, say it's 1/4". That being the case, remove door from fridge and install a 1/4" plastic washer over the bottom hinge pin which holds the door in place. It may be necessary to remove a spacer from the top hinge in order for the door to close properly after installing the new bottom spacer, or you may get lucky enough to just take one from the top hinge and put in to the existing hinge spacers on the bottom. Reinstall door and check for proper closure and allignment. Hope this solves the problem.
Kenny
Posted on Dec 28, 2013
dcp2
  • 63 Answers
SOURCE: Samsung Refrigerator SR-608EV with water dispenser
There is another sensor in the door that senses how far open the door is. look for this and see if its disconnected or broke
Posted on Jan 28, 2008
IFIXALL
  • 868 Answers
SOURCE: Freezer Door Won't Stay Shut
OK LOOSEN THE HINGE THAT SUPPORTS THE FREEZER DOOR.IT'S ON TOP AND HAS 3 SCREWS .JUST LOOSEN AND NOT REMOVE THEM.NOW LIFT UP THE DOOR UNTIL IT LINES UP EVEN WITH THE OTHER DOOR.AT THE SAME TIME TIGHTEN ALL 3 SCREWS. YOUR DONE!!!
PLEASE RATE THIS. THANX!!
Posted on Jun 06, 2008
huuum
  • 750 Answers
SOURCE: FPCE19TR frigidaire refrigerator/freezer door beeping at odd times
Hello delgrandma
Welcome to fixya.
I'm Huuum and happy to assist you,
You said, your refrigerator has a sensor for when the door is not closed but lately the beeper goes off at various times and the door is shut. Your husband has tried to level up the door and you don't see anything keeping the door from shutting securely. The beeper even goes off in the middle of the night.
This sounds like the alarm switch or sensor is malfunctioning.
Do you have a refrigerator thermometer? You can buy one in the hardware store pretty cheap.
If so put it into the fridge and make sure the temperature is steady and not fluctuating.
If it fluctuating this may set off the alarm if it is a sensor that triggers the alarm due to temperature drop..
Rather than a mercury switch will only signal the false door opening if it is faulted, rather than a warm temperature!
How old is the fridge?
Here is an interesting report I just read!
Repair or replace?
When to pull the plug on your old refrigerator
It nearly always makes sense to undertake simple do-it-yourself repairs,
such as replacing a gasket on a refrigerator or a freezer.
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your refrigerator,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your refrigerator is under warranty or less than four years old (three years for top-freezers),
paying for a repair makes sense.
Note that refrigerators under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your refrigerator is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models are quieter and have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new refrigerator.
Data also shows that it doesn't pay to fix a less-expensive top-freezer refrigerator
six or more years old or a bottom-freezer or side-by-side eight or more years old.
Thanks to better recycling programs, less than 10 percent
of a refrigerator you replace is likely to end up in a landfill.
Let me know what you decide!
Please do not for get to give a rating before you sign off!
Thank You, HUUUM
Please remember to leave a rating before you go!
Thank you
Posted on Sep 29, 2008
  • 10 Answers
SOURCE: sub-zero 500 series refrigerator door wont stay closed
If Your Refrigerator's Freezer Door Pops Open When You Close the Fresh Food Door... If a 'top-freezer' refrigerator's freezer door pops open when the larger fresh food door's closed, it's actually a good thing. That tells us the seals are in great shape, sealing well.
Some freezer door 'pop' is unavoidable bc the bottom door's so much larger than the top one and the hydraulic effect of compressing all that air kicks in. The two compartments share the same air via a duct between them, and that compressed air rushes up into the freezer compartment and can 'pop' the door.
To improve the situation, apply a few drops of oil (sewing machine oil or 'three in one' - NOT WD-40) to each freezer door hinge pin. (Even better: if you can, pull the doors and coat the hinge pins with petroleum jelly). This will help the freezer door swing back closed by itself. The freezer door usually stays ajar because it's binding a bit, and that's usually caused by it's swinging 'dry', with no lubrication.
It’s also a good idea to ‘kick’ the habit of letting the refrig door close hard.
Posted on Feb 11, 2009
SOURCE: kitchen aid open door sensor alarm keeps going off door is closed
Open door and turn power off then on twice. Then press the Overtemp reset.
Posted on Aug 08, 2009
E240B Fridge Freezer door open alarm goes even when door closed.
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
Cause of Beeping Noise in Frigidaire Refrigerator eHow
Dec 22, 2016 | Fisher Refrigerators
The alert ding goes constantly and no doors are ajar
How do I use the digital control panel on my Samsung fridge ...
www.samsung.com/uk/support/skp/faq/1023129
Samsung ElectronicsFeb 17, 2015 - Energy Saver Button. For better energy efficiency press the Energy Saver button. If condensation occurs on the doors turn the Energy Saver ...
Support - 4-Door Flex Refrigerator ... - Samsung
www.samsung.com > ... > French Door
Samsung Electronics4-Door French Door Chef Collection Refrigerator. 4-Door ... Will the Water Dispenser on the French Door Refrigerator Work Without a Water Filter Installed?
My New Samsung Fridge Won't Quit Beeping - eHow
www.ehow.com > Home
Remove bulky food items that might keep the door ajar. ... Samsung refrigeratorsfeature an internal door alarm system to alert you when a door ... The alarm turns off and the beeping stops no matter how long the doors remain ... Therefore you hear thedoor alarm go off in intervals, even though the door is actually closed.
Jan 19, 2016 | Samsung RF4287HARS French Door...
I have a Kenmore refrigerator top mount freezer, which quite often starts sounding 3 beeps.
This refrigerator should have an alarm for an open door.
If the beeping is indicating a fault code, you should see this indicated on the display.
If no fault code is indicated and the alarm is due to an open door even with the switches pushed in, then you could have a bad door switch or a failed control board.
Oct 19, 2015 | Kenmore Refrigerators
Stop alarm beeping
If you had a model number (on a sticker inside the fridge), there's probably a manual online that tells how to adjust the door.
Dec 28, 2013 | Kenmore Refrigerators
Beeping & not cooling
Hi Hope, usually when the door(s) have been opened for longer than 10 minutes, an audio alarm sounds and the interior lights shut OFF. This protects the liner from melting due to the heat produced by the light bulbs. The alarm will sound every two minutes until the doors are closed. Once the doors are closed, the alarm is reset.
The refrigerator will also beep on some models to inform the user that the door has been left open and the cool air is escaping.
If the alarm keeps on going off after the doors have been closed and unit has been reset, I recommend contacting a professional technician so they can diagnose and repair your refrigerator.
Sep 10, 2012 | Frigidaire FRS3R5EMB Side by Side...
Whenever I open the door the beeper starts beeping and continues for 19 beeps regardless of whether I leave the door open or close it again. The beeps are at approx 1 second intervels
Whenever the fridge is open it gives 19 beeps actually.In your case even when it is closed it is giving 19 beeps.This is the problem with control board.The control receives the signal when closing the door and stops the sound.Check the wiring connection to and fro the control board to the door.Control board costs high.This is small problem you can just unplug the wiring connection to the door to the board instead of spending more.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Feb 01, 2011 | Refrigerators
Beeping from refrigerator about once a minute.
If this is listed under the right model, then the only thing it could be is some models have a
door alarm,that will beep if the door is not closed. You could check and clean the gasket.
Or it the switch that tells the fridg that the door is closed. Check if there is a top door adjustment to bring the door closer to the fridge where the door hinge is. This might apply or push on the switch more.
Mar 29, 2009 | Samsung RF265AA Bottom Freezer French Door...
Kitchen aid open door sensor alarm keeps going off door is closed
Dec 21, 2008 | KitchenAid Architect KBFA20ERSS Stainless...
Door alarm keeps sounding even though doors aren't ajar
The problem is the doorswitch of the freezer door. The door 'bump' which has to push in the swich doesn't push it in far enough. You can try and hold the switch an dpush it in with your finger and see if the sound continues. You can try to adjust the door, but easier is to glue or tape something to the door 'bump' so it pushes the switch further in. Hope this was the issue.
Jan 04, 2008 | Refrigerators
Refrigerators Logo
65 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
