Question about Toys R Us Tabeo
I LOST THE APPS ON THE TADEO TABLET BY RESETING
HOW CAN I GET THE APPS BACK??? SPECIALLY FURBY BOOM.... MY SON IS GOING TO KILL ME!!!! PLEASE HELP!!!
My tablet keeps giving me error message. Insuficcant space on tablet to download apps
This means the internal memory is full and the only way to add apps is to uninstall other apps that you have installed. Check to see if you have apps you no longer use and uninstall them.
Jan 02, 2017 | Tablets & eReaders
Is there any way to find my stolen rca ****** tablet
2days ago I lost my phone, but I have LEO Privacy on my phone, so I used my preserved number to send the commands. Then I finally found my phone back. I'm so happy for that, so here I want to recommad this app to you all~ LEO Privacy Applock Boost Hide Android Apps on Google Play
Mar 18, 2016 | Tablets & eReaders
How do you do a Factory Reset on Proscan plt9602g tablet? I locked my self out and I need to get my tablet back because it's actually my mom's and she's going to kill me
get someone who knows what there doing if you do a factory rest you will lose all saved files and programes plus any apps downloaded after you purchase it you need to back up all to memory card or stick prior to doing any factory reset good luck with MUM
Aug 28, 2015 | Tablets & eReaders
My tablet won't let me download any apps. Says it's parsing??
Have you checked storage make sure you have room and, try reseting it. Or run back up, if you have it. Also connect to it to your pc and try manually to put apps on. Factory reset and use sd card when you load everything back if you can load the store app on sd, if it happens again you can remove sd delete store app of it and do it again good luck
Jul 04, 2015 | Tablets & eReaders
My trio tablet sudenly turned white please help my son was crying he barely got that tablet so please help
When the tablet is fairly new, just bring it back to the store. If you (or your son) did not drop the tablet, it will be a case of warranty.
Jul 09, 2014 | Tablets & eReaders
My son locked the tablet
Your son needs to tell you the code he used to lock the tablet. Alternately you may need to contact the manufacturer to see if there is a way to reset the tablet back to OEM config (this will erase the code and all apps installed).
Jun 22, 2014 | Kocaso M M9100 9-Inch 8 GB Tablet
Son forgot password
If you set a pass code (or pattern) that you cannot remember, please enter the wrong password (10-20 times) until you are prompted to sign in via your google account. Please note, this will only work if you have already setup your google account on the tablet. If you have not set up a Google (or Gmail) account on the tablet, you will have to perform a firmware install, which will revert the tablet back to factory settings. Support Troubleshooting Guide
Mar 23, 2014 | Kocaso M730W 1.2GHz 4GB 7 Capacitive...
Son forgot passcode for tablet
One opiton you have is to overwrite the current setup on the tablet. The download for the firmware file can be found at Proscan site here: http://www.curtisint.com/html/custservice/manuals/PRO_PLT7223G_FIRMWARE.ZIP Unzip the files on your computer and extract the contents to your desktop. Now, use the micro usb cable that came with your tablet and connect one end on your tablet first, leave the computer end open for now. Find the small pinhole next to your tablet`s usb port and use a small pin to press it, while plugging the cable to your computer. Your PC should now say finding a new USB device. From the list, select iRockusbDriver from the folder to install the driver. From here, run the RKbatchTookl.exe file that was extracted. On the choose file path screen, select Update.img and click on Upgrade. The process should only take a few minutes and your tablet will be reset when done.
Mar 20, 2014 | Proscan 7-Inch Android Internet Tablet,...
Klu LT1041 tablet by Curtis screen went black and now will not turn back on
My son put a 9 point lock on his tablet and does not know the unlock pattern. I have done the reset button so many times and need to get back to the factory settings. Can some one help me figure this out? It has been locked for 4 weeks and im loosing my mind trying to unlock it.
Apr 05, 2013 | Tablets & eReaders
Toys R Us Tabeo Logo
16 people viewed this question
Top Toys R Us Tablets & eReaders Experts
Bill Boyd
andrewcahoon
micky dee
Are you a Toys R Us Tablet and eReader Expert? Answer questions, earn points and help others
