Question about Hisense Televison & Video
32D20 connection problems
I am connecting the above Hisense TV to a Motorola DSR505 receiver from Shaw direct satalite provider.When I plug in the HDMI cable to any of the HDMI ports 1,2 or 3 and select that inpup I get good picture but no sound.I have reverted to the component in cable set up and everything works fine. Quality is probably not as goos so I want to use the HDMI cable. When i first turned the TV on a message"not HDCP compliant." . Help !!
  • 794 Answers
You could have a HDMI cable that has gone bad; FYI, HDMI cables carry both audio and video signals.
Regarding the "Not HDCP Compliant" message: http://en.wikipedia.org/wiki/High-bandwidth_Digital_Content_Protection
Posted on Dec 28, 2013
SOURCE: HDMi ( no signal, not supported) doesn't work with Dmr-Ez47v
Return set!
Akai Tv is not HDCP compatible. Nothing worked akai was not very helpful. This model , a 2006. aparently will not communicate will the newer HDMI devices.
RETURN SET IF POSSIBLE. NO SOLUTION FOR THIS PROBLEM!
Posted on Jan 04, 2008
SOURCE: Zenith Z42P3 "Invalid Format" message from upconverter DVD
Ran into the same problem with this DVD player and my LG tv. Try this:
Open the DVD tray, with the DVD tray open press the HDMI select button until the proper resolution for your tv is illuminated, put the DVD back in, close the tray and try again. Simple fix -- worked beautifully for me.
Good luck
Posted on Jul 11, 2008
phongnv
  • 56 Answers
SOURCE: Vizio Model#:L37HDTV10A
Is the HDMI port 2 work? Try to turn it off and turn it back on. If it is still not working then the HDMI ports have gone bad. You will need to replace the main board.
Posted on May 12, 2009
  • 4 Answers
SOURCE: "Display connected non-HDCP compliant" error
The HDMI cable was causing "Display connected non-HDCP compliant" error message to appear.
When I reconnected my DVD to TV using regular cable with 3 color connectors(i don't know what is the proper name for that cable) that error message no longer appears on my screen and I was able to watch my movie normally.
Posted on May 18, 2009
  • 668 Answers
SOURCE: Motorola DSR505 HDMI problem
Check to see if input 5 has a audio in source via RCA jacks. Many times manufactures will give you multi HDMI inputs but only one that has RCA jacks in case you are running a DVI/HDMI cable. If input 5 does not have those RCA jacks you will not have sound. I know this unit has multiple HDMI inputs. Look to see if any of the other HDMI inputs also have RCA jacks.
I hope this helps,
Skyassoc
Posted on Jun 22, 2009
Can not get my shaw remote to work for on /off or volume on my hisense tv
Take your Shaw remote control, and follow the instructions on the back. If that does not work, telephone Shaw, and ask for technical support for TV.
Dec 08, 2013 | Televison & Video
Cannot connect to the interent with Shaw Cable. Problem just occured today. When I hook my internet directly to my computer it works fine. Shaw tells me this is a global problem with alot of their...
I had the same problem and got the same answer from Shaw when I called. Fortunately my D-Link 655 modem was less than a year old so I called D-Link support. They said Shaw made a change to their system yesterday which caused the problem.
The solution they provided was to log into the modem then go into setup, manual setup. Make sure the connection is Dynamic IP (DHCP), then at the bottom press the button Clone your PC's MAC address, then save the settings. I then had to unplug the power from my cable modem and router and wait 1 minute. Plugged in the cable modem first, once all the lights have gone through the cycle plug in the router. This fixed my problem so far.
Good Luck...
Jan 28, 2011 | D-Link DIR-628 Wireless Router
How to connect sound system to Hisense LCD tv
I phoned the help line at Hisense, they stepped through the set-up - its all good now
Dec 30, 2009 | Hisense TL3000 30 in. HD-Ready LCD...
Our Shaw cable box,Pace PVR,continously BLANKS out for no reason,When it does the guide on the tv says to be anounced for a minute or more! Changing the channel or hitting the channel guide up usually sets...
I have had the same problem and I spoke to a tech at one of the tv repair shops in Edmonton. He says it is a long standing generic problem that Shaw is having with the HDMI connection between the pvr and tv's, I have a pvr replaced twice and the problem remains. The last Shaw tech says to use component cables and it will solve the problem which I believe is an admission that the problem identified by the tv tech is true. Doesn't help with 4 hdmi.and two component inputs
Dec 30, 2009 | Televison & Video
Ac#13-0120-2171. We have no picture on shaw cable TV
Try checking the A/V Cables. They could be Defective or loose.
Dec 01, 2009 | Motorola HDT101 DTV Receiver
I have a motorolla DSR505 sattelite receiver that I want to connect to my Pioneer VSX-1019AH-K audio/video receiver. The sattelite receiver has a DVI output jack so I have a DVI to HDMI cable to connect it...
The DVI output usually transmits only video (I'm almost 90% sure about this). It would be better if you did not use the DVI to HDMI cable. Receivers and displays can be very picky when it comes to using HDMI. Your Motorola DSR505 has other output options on its rear. I would suggest using the Component out for video (the 3 outputs colored green, blue and red) and either an optical or coaxial for the audio. The Pioneer VSX 1019 AH-K has the required inputs. Of course, you would require new component and coaxial/optical cables to do the job.
Hope this helps. If you're still in a tangle, you can consult the Official Thread on the Pioneer VSX 1019 AH-K on avsforum. There are a lot of helpful people out there.
Sep 18, 2009 | Pioneer VSX-1019AHK A/V receiver
Used receiver at different location for 3 months.
Had repair man come. The coax connection going to TV from receiver had went bad in the receiver. The other connectors in box worked but not the coax anymore that is why the box worked on other TV since using video and sound cables. Got new box for signing up for another 18 months with Direct TV. Didn't have to have splitter to just get Satalite so that wasn't the problem at all. Any of the splitters I had would have worked.
Apr 17, 2009 | RCA R10 DIRECTV
Televison & Video Logo
213 people viewed this question
Top Hisense Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
