Question about Refrigerators
Downdraft fan will not turn off - Refrigerators
    Habit-Forming:
  • 21 Answers
I would need the model number to look for a wiring diagram to know for sure, but it could be a sensor that is stuck closed. A lot of these have a thermodisc that turns the unit on when it gets too hot and will not allow you to turn it off until the temp goes down.
Posted on Dec 28, 2013
How do I stop downdrafting? Is there a damper that could be installed? We live off grid and power consumption is a consideration for us.
Downdraft will extinguish the pilot light flame too. there are flue fans that run off solar. You might want to look into one
Mar 09, 2016 | Water Water Heaters
KitchenAid Retractable Exhaust Fan problem when rising. When button is pushed, unit rises up about an inch. Requires 10 or more presses to extend fully. Otherwise fan and retraction is normal.
Kitchen Ventilation ' Kitchen Hoods and Fans ' KitchenAid
www.kitchenaid.com/major-appliances/hoods-and-vents/
KitchenAidShop and find how our hoods and ventilation systems clear the air in your ...Retractable Downdraft Design ... Telescopic Downdraft System in Stainless Steel.
30" Retractable Downdraft System, 600 CFM (KXD4630YSS ...
www.kitchenaid.com/shop/-[KXD4630YSS].../KXD4630YSS...
KitchenAidLearn about features and specifications for the KitchenAid 30" Retractable ... This 30-inch retractable downdraft vent rises 14 inches to help filter steam from ... 14" Rise. Enhances overall capture above the cooktop for more effective ... Makes it easy to select and adjust fan speed depending on your ventilation requirements.
KitchenAid® 36" Retractable Downdraft System, 600-1200 ...
Jan 10, 2016 | KitchenAid Dishwashers
Jenn air downdraft fan 2e speed doesn't work
Probably the switch or a burnt out resistor.
Mar 18, 2014 | Cooktops
Downdraft fan switch
please go to web page and fix it:
http://www.ehow.com/how_8733070_troubleshoot-ge-gas-downdraft-cooktop.html
God bless you
Jul 14, 2012 | Cooktops
I used my grill for the first time, & the downdraft didn't work we'll, the house filled with smoke & eventually the downdraft shut off and I had to finish cooking in a pan. My Jenn-Air is...
The downdraft is electric so there must be something malfunctioning with it. It is a high volume downdraft fan that is to be vented to the outside. Could it be that something has clogged the vent hole up, not allowing the fan to evacuate the smoke?
While I am not a big fan of Jenn-Air, their fans are usually high quality if they are installed correctly, with the proper vent lines.
Jul 06, 2011 | Jenn-Air JGD8345 Gas Cooktop
We have a tempstar down draft furnace. 2 years ago the heat exchangers where replace because we were told they were cracked. This year the downdraft motor was makikg a lot of noise & we were told the...
Sounds like the low limit or high limit is out these control the fan motor.They are usually set to kick on around 150 degrees and set to go off around 95 to 100 degrees. Over heating does happen with cracked heat exchangers and it can possibly take these two items out. Normally your furnace should run approximately five minutes or a little less then your fan motor comes on and then for cooling down burners should drop and the fan motor should run again roughly five minutes or so then shut down. Times may vary as to your settings.
Dec 20, 2010 | Heating & Cooling
Is there a vent cover for the downdraft vent. The
not that I know of but the fans on these ranges usually have multiple speeds. Try using the lowest. The fans are very strong on them. Hope this helps. good luck.
Nov 26, 2009 | Jenn-Air SCE30600 Slide-In Electric...
Grill Element
I believe this is working as designed! The downdraft fan always turns on when I run my own grill!
Oct 20, 2008 | Jenn-Air JES9860 Electric Kitchen Range
Fan has difficulty turning, buzzes
Hi
Tha model is a Maytag.
There are a few things to check here, and it's best always to use the proces of elimination.
These are the things you need to check:
1.MOTOR, DOWNDRAFT
2.BLOWER ASSEMBLY
3.SCROLL, BLOWER ASSY.
4.CORD, POWER (MOTOR)
as you mention before sometime run and sometimes do not run.
youll have to start by checking those items and make sure they are not damage or obstructed. I have some wiring diagrams for that model, if you would like for me to email them to you, please let me know.
I hope that will help you
Eddie Rentas
Tupper Lake NY
Jun 22, 2008 | Jenn-Air JED8430 Electric Cooktop
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
