Question about Sharp AL 1631 Copier
Striped copies. A week or so ago I used the charger cleaner and the problem was fixed. Now the problem has returned and cleaning the charger does not seem to be of any help.
    President:
  • Sharp Master
  • 990 Answers
Hello sir; Tell me when the sreak line come out, is using doccument feeder or leave on the glass, if using feeder, just need to clean out the glass( narrow strip) otherwise you have to change drum cleaning blade. p.s. also need to clean white reference on the cover( when you lift up the cover on the lefthand side.)
Posted on May 18, 2009
When did the men 's diamond ring arrived back?
Fixya has nothing to do with your ring, it's not "our" company. Fixya is a Q/A forum. Sen your messages to your provider
Aug 09, 2015 | Watches
Hp psc 1210 will print but not copy
Symtom that scan head might be faulty, remove four screws located at corners, take out flat glass unit, remove scan head, check any damages in driving mechanism, clean reading head, fix it back and check.. If no result replace scan head unit..
acsn head snap shot:
Feb 03, 2012 | HP PSC 1210 All-In-One InkJet Printer
I need an instruction manual for a EUROLAB robot vacuum cleaner Auto Cleaner Intelligent Floor Vac please
I have a Eurolab and I can give you a couple of tips...
Spot = concentric circles from a start point and will continue for 4mins
Clean = will clean until battery runs out then go to base.
Max = will clean until battery runs out and then return to base, charge and go again.
If you interupt any of the settings you will need to manually return unit to charger (either by picking it up- or turning it off on the unit - then turning it on again while holding down "Max" on the unit). It will then find its way home. The two different settings on the seperate little room divider are about how big the doorway distance is ie 1 metre or 4-7 metres (somethinig like that) to prevent it going into a sep room. There is a little filter that needes to be cleaned 1 or twice a fortnight - just to help with suction. The auto settings on the charger unit should be self explainatory but I just set mine off in the morning while I am doing other things and haven't go around to setting it yet. I am very happy with mine and my floor has all of those loose bits gone. I empty the pod weekly.
You can't make it go back with the remote - or if you can it is not mentioned in the manual and I haven't worked it out yet.
I hope this helps.
Cheers
Brittany
Nov 22, 2011 | Vacuums
Black line on print-outs
When u found any extra black or white vertical line, we can check 3 possibility:
1) check the toner container. U may have to replace a new 1 if necessary.
2) clean the charger wire. Just slide the Charger Cleaner (green color) backward and forward 3-4 times to clean the charger wire, then return to its original position.
3) check the charger cleaner is it in its original position or not?
YBC (/\)
Jan 21, 2009 | Kyocera FS-920 Laser Printer
Lexmark X-4270 all in one won't copy
try cleaning the heads with the fix on the printer help screen.go to-- help--type in printer copier won't copy- look for how to clean the heads of the ink pores. or try align cartridges. when you install new printe ink or the cartridges come with the machine you have to aline to keep the ink flowing right.
Oct 12, 2008 | Lexmark X4270 All-In-One InkJet Printer
Motorola z8
for bpo solutions surf www.lexicon.com
Jun 13, 2008 | Motorola Lands Phones
When I fax docs, it is received with stripes and stains
first check the printer by copying something,here u can see the problem that u r telling me,or check it by scanning something in ur computer,if u can see that problem,all u have to do is,open the top glass cover, under the top cover thers a scanning unit(lamp unit),in that scanning unit ther are some mirrors clean that mirrors with cotton bud,clean the top glass,n fix everything again,problem will be solved
thnx N
Jan 29, 2008 | Samsung SCX-4216F All-In-One Laser Printer
AL1631 Striped copies.
clean the scanner lens UNDER COrNER OF AUTO DOCUMENT FEEDER
Jan 24, 2008 | Sharp AL 1631 Copier
How Can I Fix My Laptop DVD/CD Player? It's Not Working Right Anymore
Provide a CD/DVD cleaner disc and clean it maybe it help;
I encoutered that problem 3 months ago, the DVD ROM recognized only few DVD disc, other DVD's won't even the windows is freshly installed. The laptop was return back to the store they replace it.
However, in your case; it work fine before so maybe i suggest you to clean your DVD rom using the cleaner, if not work then , scan your computer with a potent antivirus, if this not work also, maybe i recommend to format and reinstall the system,
If all of those are not working maybe its time for you to enjoy the warranty of your laptop if the laptop has a warranty. hope this help.
Jan 22, 2008 | Acer TravelMate 223X Notebook
Sharp AL 1631 Copier Logo
59 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
