Question about eMachines Computers & Internet
Fuzzy screen with lines on desktop computer
My screen is fuzzy and has lines going through it like it isnt recieving a full signal or something is wrong with the computer. it is only clear for a few minutes and then gets fuzzy again. sometimes it only stays on fuzzy and lines and never appears to be clear.
    New Friend:
  • 38 Answers
Dear Debbie,
Greetings from New Zealand! Try a different monitor & see if fault still exists...If not the monitor, then could be fault in box...either hardware or software....(???maybe interference from other devices in home/nearby???) Your may need to install/replace video card - if you have one? (I THINK that if it is a fault in the all-in-one motherboard type of video that a separate "PCI" video card MAY solve it?) I hope that these suggestions help?! 'b'ye - Bruce.
Posted on Apr 28, 2014
SOURCE: PACKARD BELL COMPUTER TOWER
Hi, sounds like your hard drive is going/gone flaky...  & if so ya gonna haveta get a new hard drive & a Windows Operating System.
Or take it to a good PC repairer, and get a quote and  explanation.
Posted on Oct 15, 2007
Benimur
  • 6966 Answers
SOURCE: edited boot config now computer beeps three times fans turn on high and screen stays black
You can restore the "menu" of the "startup" to how it was before.
The idea is to reset the CMOS/BIOS to the original factory settings.  There are 2 ways of doing this:
1. Is to hit F2 again and look for Default Settings, click on that, save and exit; or
2. (Preferably), open your PC and look for the reset jumper (3 terminal with 2 shorted via a jumper). This is normally located very near the backup Lithium battery. Temporarily, move the jumper to the opposite pair and replace back to original position after a couple of seconds.
Hope this be of some help/idea. Post back how things turn up or should you need additional information..
Good luck and kind regards.
Posted on Nov 01, 2007
  • 85 Answers
SOURCE: Black screen
unplug evry thing and check out the cmos battery on *********** board .remove that cmos battery and reinsert that.also remove the ram (the memory)from the mother board and refit it properly and then reconnect every thing as it was and start the pc it will work.
Posted on Feb 26, 2009
  • 277 Answers
SOURCE: gateway desktop computer boots up stays on for a
check the heatsinks fan is working
Posted on Dec 11, 2009
  • 1768 Answers
SOURCE: the monitor on my computer screen is fuzzy and
With out seeing the screen and the connections to the video card I can assume that
it is the cable that is loose but it may also be the video card itself and or the LCD
monitor.
1. check the video cable from the monitor to the video card port
2. check the cabinet (PC) for accumulated dust around the mother board or the video
card and the CPU ( central processing unit). Dust is a heat collector and may render the
mother board and component to act erratic or fail all together. check all connectors
I hope this helps. Have a great day!
Posted on Oct 08, 2010
I have a Sony FD Trinitron 27' Model # KV-27FV310. It is approx 8 years old. After turning it on and watching a full screen for a few minutes; all of a sudden, a line came across half the screen;
top half missing is in vertical circuit of set---if it is a 27 inch and this old consider retiring it and replacing----other option is consider having a shop repair it--a rough guess would be as high as 150 dollars parts and labor is possible for your problems.
May 01, 2012 | Televison & Video
Horizontal lines across screen picture going fuzzy in and out and then no picture at all
A horizontal line that rolls from the bottom to the top of the tv could be a Hum Bar. This is from a bad ground either for the house electric system or for the cable system. By code, these grounds are supposed to be connected (bonded) together. In other words, the electrical interference is going through your tv instead of into the ground. Fuzzy picture is usually from low cable signal. This can be due to bad cables, connections, or splitters or problems outside with the drop (cable line outside that runs to the house). Splitters, by design, lower the cable signal (i.e. a 2 way splitter cuts the signal in half). If you have unnecessary splitters you should remove them. If you have more than about 6 or 7 tvs, you may need to add an amplifier.
Jun 25, 2010 | Vizio VF551XVT 55 in. HDTV
No signal to monitor
Hi, Have u tried removing the RAM and CMOS battery and then again put it.
Jan 25, 2010 | eMachines T6534 PC Desktop
I HAVE DISH NETWORK HOOKED UP IN LIVING ROOM, I WOULD LIKE TO ADD IT IN BEDROOM OFF OF THE SAME RECIEVER. I USED A SPLITTER, THE PICTURE IN LIVING ROOM IS CLEAR, BUT REALLY FUZZY IN BEDROOM. I KNOW THEY...
You will need to split the signal with a 900mgz splitter between the living room and other room. if your pic is fuzzy you have a bad splitter or bad cable, try replacing these one at a time and it should clear up. If your getting a sat pic but ti is fuzzy its for sure in the line somewhere fro teh splitter.
Nov 16, 2009 | DISH Network ViP 612
Fuzzy Screen Then No Screen
This can mean that the artifacts are problems with the lead free solder and in my experience it will get worse, its usually on games that require heavy graphics then its definately the lead free solder problem and will lead to either 3rrod, e73 or e74 etc etc.
my advice is dont play it to death, keep it cool and if you want it to be ok i would do the x-clamp replacement and possibly re-solder the whole board. this is done by the use of an IR oven similar to what we use, OR you can use a normal heatgun but i dont recommend it because it can cause damage and knock fuses off the mainboard if not used properly.
in the meantime id play it for an hour a time and make sure its not in any cupboard or anything. getting something like an intercooler can help. We use something called SystemX which cures this type of problem.
See how you go.
Linda
www.xboxrepairkit.co.uk
Sep 16, 2009 | Microsoft Xbox 360 Console
My plasma sometimes turns on and sometimes it dosen't
Here are two things to look for.
1. the on indicator, Is it green or yellow?..
2.What is the teprature of the room the screen is in. They don't like the heat.
If it is yellow you are not recieving signal from the computer either by a faulty connection or the high memory is full. Go to start then right click on my computer, scroll down to .properties and click. The computer will display your high memory or RAM. In most cases you will need to increase your ram size. Good luck..take care... Mark
Jun 28, 2008 | Computers & Internet
Teac rw-cd22 burning problem
You were right! I changed the cd and it does not do DA:D2
Feb 13, 2008 | Audio Players & Recorders
Nvidia GeForce FX 5200 (gateway) graphics card
run cc cleaner great free tool and dl latest nvidia drivers hows your screen lcd or crt is it old ? does it do it on anther computer your screen ? can u reseat the video card is your case full dust hot ? blow it out
Jan 11, 2008 | Computers & Internet
Fuzzy screen
You have a defective Hyper Board......call a pro
Jan 01, 2008 | Toshiba 57H81 57" Rear Projection...
Computers & Internet Logo
64 people viewed this question
Top eMachines Computers & Internet Experts
Michael Vincent Cruz
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
