Question about Uniden Bearcat BC125AT Scanner
Connect scanner to computer
My computer can't find drivers for the scanner
    New Friend:
I found out what the problem was. The antenna had broke away from the solder.
Posted on Dec 29, 2013
    New Friend:
  • 3 Answers
Need frequencies
This Scanner did not install driver. I need to install mustek scanner 1248ub driver. Software completely install but Driver didn't install.
Disconnect scanner from computer, uninstall the software you installed and restart the computer.
Download the latest driver software from: http://www.mustek.com/mustek/Support.php
Install the driver software but do not connect the scanner until the installation prompts you to connect it or when the installation is complete.
I hope this helps. Good luck!
Jan 30, 2011 | Mustek Scan Express 1248UB Flatbed Scanner
HAVE A REV SCAN 192001 BUT COMPUTER WILL NOT CONNECT TO SCANNER I DO NOT HAVE INSTALLATION DISC
Disconnect the scanner from your computer and go to Plustek's website (http://plustek.com/)
Download the driver that matches the scanner model and the version of Windows you are using.
Double click on the driver file you downloaded and connect the scanner when prompted or when the driver finishes installing.
If this helps please vote for my solution.
Nov 30, 2010 | Plustek OpticPro UT12 Flatbed Scanner
Scanner is not communicating with computer
Dear,
First of all, check All desire cable is connected to computer.
Power cable of Scanner and data cable (USB, COMM) connect to computer.
Install Driver of the Scanner,
if u not have a scanner driver, search on the Internet with the scanner model.
for further instruction
Contact with me.
Dec 11, 2009 | Symbol Office Equipment & Supplies
I try to scan a document and it says that I am not set up on pc. I use just the scan button and it still won't scan. Help please!!!
Verify cables connected properly to the back of the scanner
If the scanner is a parallel port scanner it is likely it has two available connections on the back of the scanner. Verify that the cable coming from the computer is connecting to the IN, Computer IN, computer, or similar connection.
Ensure that the scanner is getting power
If your scanner is not getting power it is recommended that you check the connections ensuring that they are connected properly to the back of the computer and from the scanner to the wall. If you have the scanner connected to a power strip and or surge protector it is temporarily recommended that you connect the scanner directly to the wall.
If the computer scanner is getting power, you should notice the inside light come on when the power is first received by the scanner.
After checking the connections you still get no power to the scanner, it is recommended you contact the manufacturer of the scanner.
Additional parallel port scanner troubleshooting
If you have another device connected in between the scanner and the computer, turn off the computer and temporally disconnect the devices connected to or from the scanner. If, after disconnecting these devices, the scanner works, it is likely that another device may have issues or may be unable to work with other parallel devices.
PC Windows users verify no TSRs are running in the background
Press CTRL + ALT + DEL and end task all currently running software except explorer and systray and attempt to scan again. If this resolves your issue it's a possibility that an application in the background such as a virus utility is preventing your scanner from scanning.
Verify the LPT port mode
PC users ensure that the LPT port mode within the computer BIOS is set to either EPP or bi-directional mode and/or try alternating between these two modes.
Update the drivers
Verify that the latest drivers are installed for the operating system being used on your computer. A listing of computer scanner manufacturers and links to the drivers pages can be found on our scanner drivers page.
Nov 19, 2009 | HP LaserJet 3055 All-In-One Printer
Printer works scanner does not
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
Scanner:
  • Unplug the Scanner cable from the computer.
  • Unistall the Scanner drivers from Device manager and also unistall the all the Scanner appications
  • after installing drivers and software it will ask you to connect the Scanner.
  • then you can connect the Scanner and and try to Scan.
Hope this help. Please Rate My Response! Thanks!
Aug 20, 2009 | HP OfficeJet 6110 All-In-One InkJet...
My printer doesn`t react
Hi there, " Unplug the printer cable from the computer. " Unistall the printer drivers from Device manager and also unistall the all the printer appications " restart the computer " try to download drivers from the website " after installing drivers and software it will ask you to connect the printer. " then you can connect the printer and and try to Print the test page.
Scanner: Hi there, " Unplug the Scanner cable from the computer. " Unistall the Scanner drivers from Device manager and also unistall the all the Scanner appications " restart the computer " try to download drivers from the website " after installing drivers and software it will ask you to connect the Scanner. " then you can connect the Scanner and and try to Scan.
Aug 19, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Won't scan photo to computer.
Aug 19, 2009 | HP Photosmart C4280 Aio Printer
Hp f340 will not scan
Aug 18, 2009 | HP Deskjet F340 All-In-One InkJet Printer
Its broken
Be sure you have installed all the drivers and softwared needed. Power the scanner off, then download and install the following from this website: http://panasonic.net/pcc/support/scanner/download.html
  • STI device driver
  • TWAIN driver
  • ISIS driver
  • User Utility
After all have been installed, reboot your computer. Once booted, power on your scanner and allow Windows to locate and finish installing the drivers.
Jul 21, 2009 | Panasonic KV-S3065CL Path-Through Scanner
Printer engine scanner error
PREM
Feb 14, 2009 | HP LaserJet 1020 Printer
Uniden Bearcat BC125AT Scanner Logo
56 people viewed this question
Top Uniden Radio Communications Experts
Jason
Steve
eradiostore
eradiostore
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
