Question about V, Inc. Vizio P50HD Plasma Television
No color,,checked all settings , all I have is black and white
How do I get color?
    Problem Solver:
  • 6 Answers
Try viewing a source such as your cable box or computer on your TV. With this source playing, open the TV menu option. If the TV menu is also in black and white then there are a few components inside a plasma TV that can be causing your problem. If the menu appears in color but the video source your watching is in black and white the problem is probably with the source, such as your cable box or computer, rather than your TV. If the video and menu are in pure grayscale and the image is still clear the problem is likely the main board.
Posted on Jan 27, 2014
Color pictures in color come from the printer in black and white
u need to change settings on the printer from black n white or printer settings in windows is set to black n white. even your graphics software could be set to black n white. normally its windows or on printer itself in configuration settings
Oct 19, 2014 | Kodak Office Equipment & Supplies
JVC 32" D series TV is suddenly black and white
Wow that's interesting, was there anybody watching your home while you were gone? There is a possibility that someone simply turned down the color level with the color control? Check that first. It's an unusual symptom. With composite video, component video or HDMI it's not usually possible to experience that defect. Since the color (chrominance signal) is usually inseparable from the luminance (black and white signal) I would check the color setting first. Other wise your set has become unable to detect that color signal... I bet it's a setting rather than a defect.
Happy Viewing
Zashiban
Jun 28, 2010 | JVC AV-32260 32" TV
Printer A10922 will only print in black. Color cartridge renewed 1 year ago and has been working well.
  1. Check that your color cartridge/toner is not empty or blocked.
    This is the least likely cause of the problem, but an important check to make. Most color printer drivers and/or software provide functions to verify alignment and color output. Consult your manual or open your printer driver by clicking Start : Settings : Printers and right-click on your printer's icon and select Properties. 'Browse' the Properties dialog for options that perform system checks.
  2. Look for a 'Print only Black and White' option.
    Open your printer driver's Properties dialog (see above) and look for a color option that uses black only. Uncheck it or select an option that enables color. Some color printers have different resolutions for color and black-and-white (usually higher resolution in black-and-white). Some applications (not Origin) will force a printer to use a quality mode that affects this option, and if the resolution is forced to its highest the color output may be disabled.
  3. Enable gray scale printing.
    Some combinations of printers and operating system versions can lead to a miscommunication between Origin and a printer driver. Under these circumstances, Origin may 'think' it is dealing with a black-and-white printer when it is actually using a color printer. Beginning with 6.1, the Origin Print dialog displayed one of two messages depending on the print capabilities read by Origin:
    1. Enable color as gray scale
      This check box displays for color printers
    2. Use simplified colors
      This check box displays for black-and-white printers
    If you are seeing the first checkbox and you are using a color printer, then checking the box should tell Origin to send all color information and let the printer handle any conversions that may come up. In earlier versions of Origin there was a rather cryptic "Print color on black and white printers" checkbox which did the same thing.
Apr 30, 2010 | Dell 922 All-In-One InkJet Printer
I have a Kodak Easy Share 5300. Just changed both
Apr 30, 2010 | Kodak EASYSHARE 5300 All-In-One InkJet...
Can i print black and white text only when colour cartridges are empty but black is full on an ip14300?
you can make a selection from the File->Print option of your word processor or whatever package you are using. it is your command that sets the printer to B&W or color. If your Black ink finishes then the printer even if set to color will print black as near black with color inks.
Sep 14, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
My printer copy's in color but prints photos in black and white,
Check your settings for your printer software program, change it to black and white, and then you will need to change it back to color, if you want to print in color.
Aug 10, 2009 | Office Equipment & Supplies
My printer has an almost full black cartridge but will not print.
Check the ink lines, the printer head might be clogged, If thats not fixing anything then check your printer settings on the computer and remove the color option. Changing it to black and white can somtimes just be from color, not just black.
May 31, 2009 | HP DeskJet 932c InkJet Printer
Scanned image only prints in black and white
it's tricky / annoying:
you have a preview ...
you have some of the (3) images checked
but also you have some of these images selected (blue outline)
now:
when you select (I don't mean the checking) an image you'll have to set the scanning params
again - or check them ...
if you select an image, and then set the params (like "color"), your scanned image will be in color
also resolution is the same way ..
especially after crating preview .. it'll be set to 300 Dpi
so after seecting one for scanning - check the resolution too :)
jepe
Sep 03, 2008 | Canon CanoScan 5000F Flatbed Scanner
I want to print in black and white only
Dear "mmmom" if your OS is Windows go to control panel, click on printers and fax icon, now go to setting of your printer (right mouse key on it) and set it to black and white. Now your printer is always set to black and white and for color printing you have to set printer to color from application (word, excel,...) you are using.
May 21, 2008 | Xerox Phaser 7300DN Laser Printer
Prints only in black and white
Windows 2000 / XP:
Go to Start, Settings, Printers. (Windows XP: Start, Control Panel, Printers and Faxes).
Right click on the printer icon and select Properties.
Click Printing Preferences.
Click on the Quality/Copies tab.
un check mark Print Color images in black and white.
Click Apply and then OK.
This start ur printer to printer to print in colour
Dec 21, 2007 | Lexmark JetPrinter X1185 All-In-One InkJet
V, Inc. Vizio P50HD Plasma Television Logo
88 people viewed this question
Top V, Inc. Televison & Video Experts
aron5566
aron5566
Are you a V, Inc. Televison and Video Expert? Answer questions, earn points and help others
