SOURCE: Power Led Flashing red 6 times....
the thermocoupler fuse is what it is called by the way. i also saw that it could be the "power board" which could or could not be synonymous with the thermocoupler. anyway, again it is a common problem with these models. Scott Jackson, MS
SOURCE: akai lct3201 ad power supply
Hi doonz75
I got same problem with MLT169A power supply it wont power on. but i found service tech who fixed my power supply. but he stays in toronto, canada. only thing is you have to pull power supply out and mail it to him. his email is [email protected]
SOURCE: Olevia Kolin PT-501 LCOS TV Screen remains black and lights flutuate
I have the same TV and had the exact same problem. I had to replace the lamp and power supply in mine to get it to work. Unfortunately...its next to impossible to find the parts, at least the power supply. I found the lamp online and I was lucky to get the online store I purchased the TV from to send me a power supply from one of thier stocked models, but only after I turned them into the FTC Consumer Protection. The TV was sold to me as a closeout but new, as it turned out the tv was a refurb, thats the only way I could get the parts I needed.
Hope this helps and if you need any other information please let me know.
T
SOURCE: TV will not power up. red LED blinking 5 times
I always found the problem to be either a combo of the x-sus printed circuit board and the y-sus printed circuit board. It is also very worth checking out your poer supply circuitry as well. Good Luck.
SOURCE: My Sceptre LCD TV Power turns on briefly (blue
Power supply is the place to look, look for bulging on top of the capacitors in the secondary side of the main power supply.
LED Indications
The front panel Status LED provides an indication of
the set's operation and the possible cause of a malfunction.
If an abnormal condition is indicated, perform the
Self Diagnostics procedure.
Self Diagnostics
To activate, press the front panel <ACTIVITY> &<CH
??> buttons at the same time and hold for 5 seconds.
The STATUS LED will then flash denoting a two digit
code.
• The number of flashes indicates the value of the
MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2
second.
• The LED then flashes indicating the value of the
(ones digit) of the Error Code.
• The Error Code is repeated a total of 5 times.
Example: If the Error Code is "23", the LED
will flash two times, pause, and then flash three
times.
Table 2-2: LED Indications
Error Codes, descriiptions and the most likely cause of
the error are listed in Table 2-3.
Note: The TV must be in "Shut Down." The LED
will probably be indicating an abnormal
condition. If the TV is switched Off, AC is
removed, or a System Reset is performed, the
code automatically resets to "12" No Error.
See the Error Code Log to retrieve a history of
errors.
Note: Use the front panel buttons, not the remote
control.
Note: If there is no response, the front panel may be
locked by a V-Chip setting. To unlock, press
and hold <ACTIVITY> on the front panel for
8 seconds.
LED Indication Condition
Off Off (standby)
Green Power On
Slow Blink Green Power Off with Timer Set
Fast Blink Green (80 seconds) > Off Power Off (Cooling fan still working, 80 sec)
Red Lamp Failure
Yellow TV Too Hot
Slow Blink Red TV May Require Service
Slow Blink Yellow Lamp Door Open or No Lamp Installed
NORMAL INDICATIONS
ABNORMAL INDICATIONS (For details perform Self Diagnostics Procedure.)
