Question about Kitchen Ranges
Frigidaire professional series range
My oven turns off after being on for 2 seconds and the clock goes back to 12:00 like it has lost all power
5 Suggested Answers
  • 11 Answers
SOURCE: Frigidaire Gallery Professional Series Oven Won't Turn On
Suspect a bad oven element. Worse case is a bad oven relay on the clock control board.
Posted on Sep 20, 2009
blueextc3221
  • 15935 Answers
SOURCE: Frigidaire range CFEF357BC2
The F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Oct 01, 2010
taran_2005
  • 10515 Answers
SOURCE: Electric Range Frigidaire Professional Series
The last expert is correct.
According to the Frigidaire technical documentation, most likely the cause of the problem is a bad Electronic Oven Control (EOC).
Check the wire harness and the P4 connector at the EOC. If the wire harness and the connector are fine, replace the EOC
You could try to disconnect the power supply for few minutes, say 15 minutes and see, if that could help the situation unless you need to replace EOC/Clock/Control board.
I don't think it is sensor as this is a common problem on these units and 99% it is faulty EOC.
Let me know,if needed further assistance.
Note - Kindly perform the repair, if you have prior appliance repair experience. These ovens are quite dangerous to work. It could not only damage the oven but could also harm you,if done in an appropriate way.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Dec 18, 2010
SOURCE: Frigidaire Professional Series Range - F30 ERR
door will not unlock after cleaning
Posted on Jan 22, 2011
GE Spacemaker XL 1800 turns on for 1 second and then resets. The display shows PRESS CLOCK.
Sounds like your losing power, have you tried it on a completely Different circuit??? Either that or bad fuse or connections inside of microwave.
Sep 08, 2017 | GE Microwave Ovens
My frigidaire professional series showing error code F 30 and oven not turning on
Good Morning Friend,
I understand you are receiving an F30 code on your Frigidaire range, model# PLEF398AC, and it will not turn on. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power, set the clock, and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 08, 2014 | Frigidaire PLEF398AC Electric Kitchen...
40 duel fuel frigidaire/electrolux convection oven doesnot work self cleaner doesnot work .
Hello Walter Buford - Try resetting the range by either unplugging it or flipping the household circuit breaker off. Wait approximately 30 seconds and turn on the unit. Select the self-clean option or bake/broil option. If it does not turn on, then the temperature may have tripped the internal sensor of the unit and needs to be reset. This usually has to be done by a professional since the back panel needs to be taken off and the power reset inside. Possibly the unit may have a communication problem with the EOC (Electronic Oven Control) or faulty element(s). Personally, I would recommend contacting a professional for further evaluation.
Apr 14, 2013 | Electrolux Frigidaire Professional Series...
Sometimes oven does not work. when ya hit start it just clicks - the screen looks normal for about 2seconds & then shows the clock time.
Sounds like is what's happening:
Put in time, push start and unit runs for 2 seconds, relay clicks, unit goes off. Cook time on display goes off and clock time comes back.
That would be a bad upper interlock switch and charred connector. If so, see:
http://031d26d.namesecurehost.com/mwd/safety.txt
http://031d26d.namesecurehost.com/mwd/disassembly.txt
http://031d26d.namesecurehost.com/mwd/doorsw.txt
Dec 11, 2012 | Panasonic NNSN797S Microwave Oven
Wolf ovens getting err message after power outage
I had a Wolf 30F wall oven with a similar problem
after power outage. It wouldnt stop beeping with error message related
to temperature control. My solution was to turn power of at circuit
panel, then reset by pressing and holding the clear button for 5
seconds.
Also note: in my case I had to close the display
before switching the panel off. When I tried to the reset process with
the panel showing, it wouldn\'t reset.
To reset other
various parts of the control panel Instructions said:
Time-of-Day Clock
Immediately after the oven is installed, set
the 12-hour clock to the current time of day. It may need to be reset
after a prolonged power failure. The clock is visible on the control
panel during all modes. If the upper oven timer is set, the clock will
not be visible in the upper oven control panel display.
SETTING CLOCK
1) Touch CLOCK.
2) Touch number pads to
set current time of day.
3) Touch CLOCK or ENTER to start
clock.
24-HOUR CLOCK
The time-of-day clock can be
changed from a 12-hour clock to a 24-hour clock. After the clock has
been set, touch TEMPERATURE for three seconds, touch CLOCK, and then
touch ENTER. Follow the same sequence to change back to the standard
12-hour clock setting.
Fahrenheit to Celsius
The
oven can be changed from Fahrenheit (°F) temperature to Celsius
(°C).
Oct 26, 2012 | Wolf Range Ovens
APPEAR THE LETTERS PF IN THECLOCK CONTROL
usually, just reset clock..it stands for power failure..if power goes out. they all do this...
Feb 16, 2011 | Ovens
Kitchen Ranges Logo
35 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
