Question about Apple iPod shuffle Second Gen. Silver (1 GB) MP3 Player (MA564LL/A)
I smashed an rca tube in my hand and glass is stuck in my hand, i am scared to go to the hospital so it is still there. it is painfull. is there any way to get it out?
  • youngtm Jun 20, 2009
    i have the same problem
    i have pliers in my other hand and a roats beef in my **** and both hands are stuck there and they are numb so i cant move them
  • 79 Answers
Pliers
Posted on May 18, 2009
Testimonial: "u r a god>>>>"
Obsolete large tv, hard to move.Can i smash it with crowbar? Any components explode or leak?
I would NOT suggest using a crowbar on it. Flying glass particles would cause a significant safety hazard.
May 03, 2016 | Hitachi Televison & Video
I have an very itchy painfull tounge, inside of my cheeks and lips also, gums and the roof of my mouth. now the back of my throat is itchy and painfull cant eat and also looks like I have three white small...
There are a multitude of things that could be diagnosed for your symptoms such as canker stores, some type of trauma (biting the tongue, scalding it, grinding or clinching teeth), I do not want to scare you but you should seek medical attention. Symptoms like yours can be a oral thrush or even cancer. I am no doctor. I read your symptoms that you provided and went online to a site called Web MD. You may find it kinda beneficial to read some of the things that I read on that particular site. I hope this helps
Mar 21, 2015 | Orajel Mouth Sore Pain Relief Medicine...
Mini one wing mirror
Most car breakers yards will have one,mirror included,an extra couple of quid and they will fit it for you. A lot cheaper than going to a dealer.
Jan 23, 2014 | Cars & Trucks
DEPROGRAM HOSPITALITY RCA TV
Download the user manual to this set by internet. It has all details. Try www.retrevo.com website.
Feb 28, 2013 | Hospitality Remote Control RRHRGP RCA...
Unable to remove oven Light glass cover.
Most oven lights will have a flat cover with 2 clips or a round glass knob. These sometimes become stuck in place due to the heat and fats from the food. Don't be scared to give the flat glass a tap with a blunt object. You can use multigrips on the glass knob but just be gentle.
Feb 13, 2011 | Maytag MER5770 Electric Kitchen Range
Broken glass AEG hob
If it is just the edge of the corner glass not a lot you can do if it is broken nearer the inside be very careful as the weight of pans can cause the break to spread.Check serial no. on base of hob body the first 2 digits are the year and 3rd digit is weeks in year.For example 92800055 that would be 2009 and 28th week equals july 2009.Any AEG unit has 2years full warranty.Check and you might be able to claim new glass.Hope this helped.
May 05, 2010 | AEG D2100-4 Electric Double Oven
Baffel removeal on Sportster
take a steel tube about 1/14 dia 18" long place in end of exhaust hold tube with right hand and large hammer in the other hand, call wife and get her to sit on bike holding front brake lever tight as if her life depended on now smash the end of the pipe until you feel it go you will know it has gone cause you can shine a torch in side and see that you have smashed a washer out of the way to reveal a nice open de-baffled pipe. wife was out when i did mine , so thick heavy duty zip ties round brake and throttle and front wheel in a corner.
Apr 25, 2010 | 2002 Harley Davidson XL Sportster 883
Seeing red !
I had a television that went to a bright shade of blue.A friends neighbor worked for sony television plant where the new tubes came down the assembly line.His job was to make sure tubes were working fine,if one color was dominant then his job was to smack the front center of the tube with a rubber mallot to fix the problem.He suggested i try that with my tube while the set was on.It worked and solved my blue problem.Apparently he explained,the gun connections in the tube came loose and to fix it was to smack it this caused the connection to reweld itself.For you I would use the palm of an open hand and smack the tube dead center with a good hard smack.Dont be afraid of breaking the glass because its very thick and strong.Give this a try.Hope it helps.Good luck!
Oct 31, 2008 | RCA F25442 25" TV
T.v. tube explosion
LOT OF PEOPLE DO THAT...I'M ALL FOR GREEN---THE ONLY DANGER IS THE PICTURE TUBE AND YOU NEED TO BE CAREFULL-- TAKE THE METAL CHASSIS OUT OF THE TV ,,YOU CAN USE WIRE CUTTERS TO REMOVE THE WIRES ETC...,AFTER THAT ..CAREFULLY LAY THE TV FACE DOWN ON A BLANKET,,REMOVE PROBABLY 4 SCREWS ON EACH CORNER OF THE PICTURE TUBE,,AFTER THAT ,YOU AND A FRIEND CAN LIFT THE TUBE OUT ....TUBES ARE MEANT TO "IMPLODE" NOT EXPLODE....ALWAYS WEAR SAFTY GLASSES AND BE CAREFULL...IF YOU DON'T FEEL COMFORTABLE ON THIS ---DON'T DO IT ....TUNICA
Sep 25, 2008 | RCA P52926 52" Rear Projection Television
How do i replace the tube in my projection tv
Good Day, pinky91,
Replacing a tube is easy, remove cabinet front and back, to get to top of crt's & cables, unplug all cables to defective tube, yoke, convergence cables, anode, crt socket.
The biggest concern should be installing the new tube. Ater replacing the tube it must aligned, not easy. It takes an experienced Tech about 2 to 2.5 hours to perform this repair.
Good Luck, big IRISH. P.S. I would recommend to have a professional to perform this.
Jul 15, 2008 | RCA P52926 52" Rear Projection Television
Apple iPod  shuffle Second Gen. Silver (1 GB) MP3 Player (MA564LL/A) Logo
52 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Parshiv Luthra
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
