Question about Kocaso M1050
My kacaso portable charger will not charge my tablet
I let it charge all day then tryed to use it and it only charged my tablet for a few moments how do i fix it?
The charger no longer charging the tablet all the home outlets have been checked, & working with my other tablet. What could be the issue I received this as Mothers day gift
the charging circuit does not charge or the batteries need replacement ....IT is probably the batter. Try new batteries, if they work the problem lies elsewhere
Also, try a different charger, and the tablets charger on something else...if the tablet's carger charges other batteries that can be discounted as the problem.
May 26, 2015 | Nextbook Premium 8 Se Android
Wont charge ,tries to come on while plugged in but shuts right back off?
Allow the charger to charge the battery with the tablet OFF over night. The tablet requires MORE power than the charger can provide - but the charger provides enough power to slow charge the battery. In the morning it should be fine - unless the battery no longer can support a charge.
May 18, 2015 | Maylong Android Tablet M-250
My tablet was in use, needed charging, it shut off. Now it won't charge or come on
It sounds like there's a problem with the charger. The wire on the charger is rather delicate. So is the port on your tablet where the wire plugs in. There may be a break inside the wire. If you dropped your tablet while the wire was plugged in and it hit the floor on the charger plug, the charger plug could have damaged the charging port in the tablet or the wire itself could be damaged.
Find someone else who has the same tablet and ask to switch chargers to see if either of them still work on the other tablet. If your friend's charger starts charging your tablet without a problem, then the problem is a a broken wire in your charger. If neither charger will charge your tablet but both chargers charge your friends tablet without a problem, then the problem is with the charging port on your tablet.
Mar 17, 2015 | Tablets & eReaders
My tablet will not turn on
Maybe the charging cable doesn't work?
Oct 11, 2014 | Tablets & eReaders
We got a RULU in 12/2013. It worked for 3 months and now can not charge i
Some tablet brands will not recognize certain charger brands or connections.
First, try all available connections-USB-wall inverter, and direct computer connection (making sure the computer is awake and logged in). Second, try restarting your tablet. Third, try gently wiggling the connections on both ends, to see if it recognizes a charge. Finally, leave it plugged in for a few hours, even if it says it isn't charging. You may have a trickle charge-to put it simply, the cord is not giving the device enough power to qualify as a charge, but there is power traveling through the cord. If the charge level goes up a little over that time span, you have a trickle.
If these don't work, just purchase a new charger. They're sold everywhere-Wal-Mart, Target, Best Buy, 7-Eleven, name a store and they probably sell USB charger cords.
I hope I helped.
Jul 08, 2014 | Irulu 10.1"tft Wifi 3g Android 2.2 Tablet...
Safari is consistently buggy and laggy for me when I'm browing the web, and I'm getting this weird light gold tint on the upper right hand portion of my screen whenever I boot it up.
I recently bought an iPad Air, and I'd like to use Kinkoo portable charger which I bought from: http://www.ikinkoo.com/shop/portable-charger/kinkoo-infinite-one-8000mah.html to charge it. I found Kinkoo can charge my iPad rapidly, only cost a few hours to charge it from 5% to 100%. Works perfectly than I expected.
Dec 17, 2013 | Apple iPad HD
Battery not charging
Is it loose connection. or any problem with charger or tablet. give it to any service centres
May 24, 2013 | Samsung Tablets & eReaders
Repair for Zeepad Allwiner
Is there a charging indication? if so, keep it off, and leave it plugged in, for a long time. I'd say a few hours to a day. Then try to turn it on.
May 02, 2013 | ZEEPAD 7" 7.0 Allwinnwer A13 Boxchip...
Kocaso M1050 Logo
71 people viewed this question
Top Kocaso Tablets & eReaders Experts
CrisO
Pieter Vleeshouwers
Pieter Vleeshouwers
Lawrence Oravetz
Are you a Kocaso Tablet and eReader Expert? Answer questions, earn points and help others
