Question about LG Electronics 47LS4600 47" LED HDTV
Lg led tv has sound but no picture
All of the sudden my LG LED 47LS4600 tv has no picture, just a really dark blue screen. the sound is fine. the tv is only a year old. what could it possibly be? I did notice that the red standby light blinks twice when its trying to turn on.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,727 Answers
Suspect either a back light power board issue or main power board to back light board issue...also, is it under warranty ?
Posted on Dec 28, 2013
SOURCE: LG 1715S faulty
I can confirm the number 3 solution. I have fixed a bunch of these now.
Replace capacitor C202, 680uf 25V. It is usually visibly damaged. It should be a low impedance type, often known as "suitable for switch mode power supply".
Posted on Oct 28, 2008
ginko
  • 19396 Answers
SOURCE: LG 700E monitor's power LED blinking continueously, no display
The monitor is probably on protection.
To start unplug monitor from power and from computer and test computer with different monitor to find out if it is monitor or computer fault.
If it is computer fault and no video signal , then test:
  • Video cable.
  • Video adapter on PC (sometimes integrated on motherboard)
  • Motherboard.
If it is monitor fault , then the monitor is on protection.
When on protection you keep having a flashing led on front of the monitor , and monitor turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the Monitor goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or a broken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the monitor will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occurr are a blown capacitor on power board, faulty inverter board, faulty input board, or a fault on LCD Digital Controller board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
Try moving the video cable, and if the cable is not built in, then also try a replacement cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on Apr 22, 2009
ginko
  • 19396 Answers
SOURCE: monitor light blinking
  • Video cable.
  • Motherboard.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing statebecause of the video cable.
SOURCE: LG Computer Half Light, Half dark?!?!!?
Install the forteManager software that comes with your LG LCD monitor. Go to the Options tab and choose Restore which will set it back to factory settings. For some reason some monitors come this way out of the box and this was the only way I was able to solve the problem with mine.
Posted on Jan 06, 2010
  • 3 Answers
SOURCE: LG Flatron L193ST. Relatively old model. The
L193ST common problem!! solution is only by replacing 2 capacitors 470uf 25v located on the power supply pcb inside the lcd they are neer the long cable connector
remove the 8 screws from the lcd back panel including the holder screws,
use a thin metal stick like a knife and insert it between the back pannel and the front black panel but slowly remove the black panel not to scratch it
remove the metal protection panel 4 screws
the power pcb becomes visible
remove all connected plugs and the 3 screws
desolder the 2 capacitors and replace them
assemble back your lcd and enjoy
30min time of work 5$ cost
Posted on Dec 09, 2010
Testimonial: "Thanks mate! I'll try that once I have some time. "
My LG tv (Model number: 32LS3410-UB) has sound, but no picture. When I do the flashlight test I can see a very dark image on the screen. Will replacing the LED driver fix this problem?
If you already tested with the flashlight which is the first step in the blank screen with sound fault then you have to test the LED Backlight supply voltages if you are familiar and good in the electronic repair. First you have to check if bulging capacitors for the LED Backlight drive voltage circuit, replace them. If capacitors are good then you have check the backlight LEDs. The flashlight test proves that the power supply is good and TV is working fine because the sound is ok and picture is fine. Attached videos and links may help you for the repair and replacement of backlight LED strips or LEDs itself depending on the type of LED strips used in your model.
https://www.youtube.com/watch?v=Z1DEkSguWtg
https://www.youtube.com/watch?v=YgaL6X6eSaU
https://www.youtube.com/watch?v=EZVQKEp6jxk
https://www.youtube.com/watch?v=T2FboV-1PJg
https://www.youtube.com/watch?v=2pyuXwNkBMA
May 08, 2017 | LG Televison & Video
Audio is fine. Why did picture suddenly go black?
The board that controls the back light for the screen is called an inverter board. Sometimes, depending on the model , the inverter is combined with the power supply board. Go here to find the parts :www.shopjimmy.com
Feb 02, 2016 | LG 47LN5400 47" LED TV 1920x1080, 120 Hz....
The tv has sound but no picture. For
LG LED TV has no picture (black screen) but still sound ...
www.tomsguide.com/answers/.../led-picture-black-screen-sound-fixed.ht...
My 32' LG LED TV has suddenly lost picture! The sound is all right but the Screen is pitch black. After switching it on the picture flashes for a second and then the screen goes completely black.
LCD Easy Fix (sound but no picture) - YouTube
? 4:52
https://www.youtube.com/watch?v=IBRE1Dcyxp4
Jan 13, 2012 - Uploaded by Clay Whitehead
TV Has Sound But No Picture Troubleshooting Guide - Duration: 2:30. by Repair.com 472,733 views. 2:30. LG LCD TV REPAIR -NO PICTURE ...
Dec 21, 2015 | LG 47LN5400 47" LED TV 1920x1080, 120 Hz....
My LG tv will go on then after a few seconds the screen goes from black back to picture of and on a few times then shuts off. Help!
7 days ago - My 32' LG LED TV has suddenly lost picture! The sound is all right but theScreen is pitch black. After switching it on the picture flashes for a second and thenthe ... LG LED TV has no picture (black screen) but still sound - can it be fixed? Tags: ... a touch on the screen reveals nothing so it's not the back light.
Monitor going black after 2 seconds [Solved] - CCM.net
ccm.net > Forum > Hardware
Oct 9, 2012 - Brightness goes down, display draws less juice, and you can at least use .... it's the LCD's Inverter ... you have to replace it for it to go back to ... If the screen is turning off every two seconds or so and then it comes ... i turn my tv on it comes right on, but then after a few minutes turns off, .... Digital Trends for LG. No display in monitor
Jan 11, 2013
Ps3 and hdmi cable
Oct 8, 2012
More results from ccm.net
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
Dec 20, 2015 | LG Televison & Video
LED screen comes on and goes black
LG LCD TV REPAIR - NO PICTURE SCREEN FIX REVIEW ...
? 5:29
https://www.youtube.com/watch?v=PWoz_-3OHIM
Jan 25, 2013 - Uploaded by Tampatec
Common LG LCD TV REPAIR - NO PICTURE OR BLACK SCREEN FIX ... I have a LG 42PM4700-UB plasma tv that justwent black. The red ... I had to keep turning on and off the TVseveral times for the screen to come back.
LCD & LED TV Repair - No Image & Blank Black Screen ...
? 5:56
https://www.youtube.com/watch?v=xUzCLgoSPGM
Sep 15, 2014 - Uploaded by ShopJimmy.com
LED & LCD TV How to Diagnose Symptom of No Image on theScreen CLICK ... Tv was working fine when left to go to store and came back to blank picture and ... my samsung tv it turns on but its completely black and no sound at all ... LG LCD TV REPAIR - NO PICTURE SCREEN FIX REVIEW - Duration: ...
Dec 09, 2015 | LG 47LS4500
I have no light on my led tv
The most likely problem is the Backlight Inverter. It supplies the power to the LED array which illuminates the screen. If you are brave and also technically able, it can be replaced at home. Here is a video to help. LCD TV Repair Tutorial How to Replace the Backlight Inverter Board in LG...
Oct 27, 2015 | LG 50" 5400 Series LED HDTV - 50LN5400
Lg model 47ln5750 screen went black
That model is an LED Backlit unit. The LED driver could be bad or there could be a power supply problem. Sometimes the problem is a cable connection. Is there an picture that you can see in a dark room? If you can see a faint picture, the problem is probably the LED back light.
May 18, 2015 | LG 47LN5700 47" LED TV 1920x1080, 120 Hz,...
47" Lg led TV black screen
are you getting audio?.if so you need to remove the back cover and look at the t-con board.
Jan 02, 2014 | LG 47ls4600 47" 1080p Led Lcd Flat Screen...
LG Electronics 47LS4600 47" LED HDTV Logo
465 people viewed this question
Computer Repairing
Computer Repairing
