Question about Garden
Stihl weedeater 250 FS
I need to replace the fuel line inside the tank. Is there a parts list and procedure to do this?
    Top Expert:
  • Garden Master
  • 43,151 Answers
Check with Stihl for the information you need.
Posted on Dec 28, 2013
  • 3600 Answers
SOURCE: Weedeater XT 85T trimmer fuel lines rotted
it's in the fuel tank it goes from the carburator into the fuel tank and replace the fuel filter while you have the tank off.
Posted on Jun 21, 2009
lemmingleejn
  • 173 Answers
SOURCE: Stihl weedeater starts but won't run at high speed
This sounds like a timing problem.
It is too far retarded, and needs advancing a couple of thou.
There you go:)
Posted on Jul 25, 2009
SOURCE: Replacing trimmer line with blade for stihl fs 90r trimmer
If you bought the trimmer new there should be a rod about 6" long and 1/8" thick. Above the trimmer head below the trimmer gearbox there is a hole. You have to put the rod in that hole and turn the head until that locks it from turning.
From there you can screw the trimmer head off by hand, or a strap wrench if it's really tight. It may be left hand threads.
Posted on May 24, 2010
rycgl
  • 1545 Answers
SOURCE: Craftsman 32cc Weedeater -- need fuel line diagram
The smaller diameter line (fuel supply) goes from the fuel tank (w/filter) to the carb body. Another larger line (purge line) goes from carb body to the right nipple on the primer bulb. Another large line (return line) goes from the left nipple of the primer bulb into the fuel tank. co0mpleting the purge circuit. This info pertains to my 2006 Craftsman 32cc with Zama carb.
Posted on Jun 01, 2010
  • 20 Answers
SOURCE: Poulan PPB200. There are
The small one has the fuel filter. The other one is the return line to the tank. The return line is larger and usually have a fitting at the end of the hose and is inside the tank. Thread the new line ( large hose ) Through the hole on the right side. Thread until you can pull it out the filler hole. Install the fitting on the hose and pull it back up until the fitting hits the roof of the fuel tank (on inside of tank ) then that hose goes to the short fitting on the primer bulb. Then thread the small hose through the left hole going into the tank and pull it out the filler hole until you can install the fuel filter. Install fuel filter and pull it back until the filter rests on the edge of the filler hole. That hose goes to the right side of the carburetor. This is if you have a walbro carb. Zama also uses the right side for this hose. Hope my explanation helps. I'm working on one as well.
Posted on Oct 16, 2010
How do I remove the fuel tank from my Stihl fs 280 brush cutter?
You must remove
1) the air filter and housing related parts.
2) Carburetor and related fastening hardware and lines
3) 2 screws on the bottom
Dec 06, 2016 | Stihl Garden
Wher can I find a free shop manual for stihl fs 110 r
Do you mean the operators manual, or the parts manual.?
http://www.mediafire.com/download/crnkf8e983bccx5
If you find this is what you're after, please click the 'helpful' tab
If its the owners manual you require, please get back to me.
May 21, 2016 | Stihl Garden
HOW DO REPLACE TRIGGER ON STIHL WEEDEATER
Im figuring the FS85 has the cow horn bars,of which there are 3 types of controls. Here's the Illustrated parts list diagram. If you would like the full IPL please contact me further and i will send it to you.
091def0c-1a1d-477c-8225-a6693552ec07.jpga3d9b8d2-2c74-41bd-b2ce-7b7b04029ad1.jpg2b7c3b7f-fa69-4d03-9e02-cad641715bf7.jpg
Apr 17, 2013 | Stihl FS 85 Weed Eater
Need repair manual for stihl ts350 super
Download Link:
This service manual contains detailed descriptions of all the repair and servicing procedures specific to this power tool series.
1.stihl ts350 parts manual
There are separate handbooks for servicing procedures for standardized parts and assemblies that are installed in several STIHL power tool models. Reference is made to these handbooks in the appropriate chapters in this manual. As the design concept of models FS 120 FS 200 FS 300 FS 350 FS 400 FS 450 and FR 350, FR 450 is almost identical, the descriptions and servicing procedures in this manual generally apply to all models.
2.stihl ts350 parts service manual
Jul 05, 2012 | Saws
I have a weedeater xt 200 trimmer. The parts in
The tube in the tank is the fuel pickup line and goes directly to the carburetor. You will need to get NEW fuel lines. Fish or shake the old parts out of the fuel tank after draining. Inside the tank will be a small length of smaller diameter fuel line that connects to the small fuel filter and there will be a small nylon line connector that is plugged into the end of the larger diameter fuel line which is the fuel return line from the primer bulb back to the fuel tank. That line ends just inside the fuel tank and is held there by the small nylon line connector. The other line (smaller diameter) needs some length inside the tank so it can flop around as you move the machine enabling it to always pick up fuel. 6" or so is about right from the hole in the bottom (or top) of the tank to the fuel filter. Buy long enough lengths of fuel line that they can be inserted into the tank and pulled thru the fill cap area and then have the parts put back on them and then cut to the correct length from the fuel tank to the carburetor and/or primer bulb. Buy about 1 foot of each size line needed. Small engine repair shops have it and sell it..not expensive.
Jul 18, 2010 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
I have a Stihl FS 90 Weedeater and the gas will not prime on the plastic bubble. The plastic bubble is in excellent condition. It may be missing a seal but I can't find a parts list online that gets into...
Had the same problem, dealer replaced the carburator, and claimed it's because of the gas. Only a year and a half old, and used less than a dozen times. Will not buy Stihl again!
Jun 09, 2010 | Garden
Replaced Poulan 25cc weedeater fuel lines/Now no start
You have/had a fuel filter in the tank.The connector goes to that filter, I think. The length does mean something but I don't know any way to figure it without a manual. You could try to figure from the total length. The fuel filter hold the line toward the bottom. Good luck.
Jul 11, 2009 | Poulan 25cc 2-Cycle Gas Powered String...
My stihl weedeater starts and idles fine but does not get power.
I have a Stihl FS 45 and have had problems with it running for a short time then cutting out. The problem is like to be either- the filter attached to end end of the fuel pick hose that goes down into the fuel tank is blocked or- there is a crack or split in the corrugated section of the fuel pick up hose between the fuel tank and the carburettor. If such a crack or split exists it will cause air to be sucked in with the fuel upsetting the fuel/air ratio. A new hose not adjustment is the only cure
Jul 07, 2009 | Worx 12" 4.5 Amp 2 In 1 Grass Trimmer/In...
My fs 45 whipper snipper is starting but running
I have a Stihl FS 45 and have had problems with it running for a short time then cutting out. The problem is like to be either- the filter attached to end end of the fuel pick hose that goes down into the fuel tank is blocked or- there is a crackor split in the corrugated section of the fuel pick up hose between the fuel tank and the carburettor. If such a crack or split exists it will cause air to be sucked in with the fuel upsetting the fuel/air ratio. A new hose not adjustment is the only cure
Jun 28, 2009 | Worx 12" 4.5 Amp 2 In 1 Grass Trimmer/In...
Stihl carb
Try this link. It has the carby settings on page 26 & 27 of the Stihl FS 45 manual.
http://www.mccoyslawn.com/parts-manuals/Stihl/FS45_46_Manual.pdf
Apr 17, 2009 | Worx 12" 4.5 Amp 2 In 1 Grass Trimmer/In...
Garden Logo
193 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
