Question about Metra 2006-2007 Volkswagen Rabbit 2.5 Antenna Cable Car Audio Radio Stereo
Speed signal this is not where the cable and that color is
    Master:
  • 796 Answers
So, this is not where the cable and that color is. I see.
The cable and that color is somewhere else. What has the location of them got to do with the speed signal? You reported this as a problem with an antenna cable, what is wrong with the antenna cable?
Posted on Dec 28, 2013
What network cable does a belkin N600 use RJ11or RJ12
Look again. Those "RJ11/RJ12" are not 2-pair/3-pair small Telco jacks but rather the 4-pair lager size found in Telco data com circuits (ancient DS0/T1 technology) and commonly now for Ethernet often referred as Local Area Network, LAN, data communications at 10 up to 1000 Mbps.
An RJ45 is larger and can not fit into an RJ11/RJ12 jack. The smaller RJ11/RJ11 will insert and make contact with the inner pins but if the line is active the Belkin device now has/will have a blown port. Don't!
Your Belkin N600 expects one Ethernet cable from a cable or DSL modem into the WAN or Internet port on the Belkin N600 for link through your carrier to Internet.
A four port gang of Ethernet RJ45 plugs is also present and is where your in-house PCs and Ethernet peripherals plug in. On the OEM website usually there is a colored quick setup guide to help you.
Some OEMs designate a yellow Ethernet wire from cable/DSL/satellite modem to WAN port and blue for internal LAN devices to try to reinforce outside verses after the NAT firewall inside the router for your internal LAN. The signal doesn't care about color it's for you.
The internally generated WiFi or WLAN (wireless LAN) is part of the LAN side but allows WiFi radio connection to client devices.
The 4-pair Ethernet cables have 8 conductors wIth the wire end of the plug to you and the contacts held upwards you will note the four pairs and their colors blue, orange, green and brown each with one conductor of the pair white with the color and then the color solid or more correctly the color with white stripe. Signals are on pins (left to right) 1&2, 3&6. On standard cable both ends are the same - a straight through, for hub to client. A cross-over cable takes 1&2 to 3 &6 on the opposite end and vice versa. This was for client to client or hub to hub connections before auto-sensing ports showed up to make the signals swap if needed automatically found in most equipment today. Some cables from OEMs have the correct physical size and pinouts, but only use the 2 signaling pairs. It is best to use these short distances and preferably away from rf noise like in modem to WAN port connections.
The twists per inch in the cable and interweave determines frequency response which defines CAT 3, CAT5, CAT5e and CAT6 level of Ethernet cables. CAT5 is fine else CAT5e/CAT6. CAT3 is generally considered now for telco use only, but can be pressed into into service short haul. (Won't get the 328 ft rated reliably above 10baseT speeds).
You may run across Ethernet with PoE this means on unused pairs a device like a video camera is fed power as well as data connectivity over its Ethernet connection. Follow directions to put power to the correct location as needed and look for any recommended grounding requirements, especially with antennas.
Prices vary widely depending upon bubble packaging and the store overhead generally $6-$12 for about 6 ft or 2 m.
If you want to make your own then RTFM and understand millage may vary until you get the right tools and parts and practice while adhering to standards. I find it more cost effective to use pre-made & tested cables except if failure at an end then I repair followed by testing to re-qualify the cable to not degrade its use.
OBTW - Generally the USB was for single computer use at lower speeds of earlier service speeds below 3-6 Mbps - usually don't.
Aug 27, 2012 | Belkin N600 DB Wireless Dual Band N Router
Loss Color
I get that there is no Chroma on something but not sure in what mode or source you are speaking about. Sometimes people have trouble due to a setting being wrong or they use a really cheap video cable which can strip the higher frequency Chroma signal off of the Baseband or Composite video signal. Try a higher grade of video cable- video signals at 10MHz bandwidth do not like to go through cheap audio cables. maybe you could clarify the problem more?
Aug 10, 2012 | LG 42 42PT350 42 Plasma TV
Can i use the same hdmi cable that already connects my dvr to my tv to connect my laptop to my tv
Short answer "Yes"
of course only if your Laptop has an HDMI output. The only possible hiccup
would be if the the source, in this case your Laptop, demands a certain speed cable.
HDMI cables have speed ratings...
  • Standard HDMI cables tested to perform at speeds of 75Mhz or up to 2.25Gbps, which is the equivalent of a 720p/1080i signal.
  • High Speed HDMI cables tested to perform at speeds of 340Mhz or up to 10.2Gbps can successfully handle 1080p signals
Aug 14, 2011 | Tivo R54040 140-Hours Video Recorder
The color on my tv is blue,green,yellow and orange. How do i get the original color back to my television?
Ur tv have no Red colors,might have bad incomming broadcasting signal cable plug to tv,tries tv with another incomming broadcasting signal cable.See,if the signal is good have no Red too,than ur tv Tuner signal board is probally dead.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish tv Tuner signal board for the replacement.
Feb 10, 2011 | Sharp Aquos LC-26SH20U 26 in. LCD...
Sony Bravia 40'' LCD 240Hz TV can't get video signal from DVD
Are you absolutely sure you have it wired up right? Are the Cable RIGHT wires color to color, is the "Correct Input" selected? Remember you do NOT use "Channels" but an AV, AUX, or External.input. Most DVD etc, use AV, IE: Yellow, (Video), Red, (Audio), White (Audio) for the OUT connections. These go color to color at TV end. And uses 3 Cables. The "Other" type of Output/Input is Component Video. This is ALL Video, Red, Blue, Green, these go color to color as well. BUT you MUST also send the Sound, Via the AV, IE: The Red & White, AV, Audio IN/OUT connections, So you in this case would have 5 cables/connections in all.
Feb 13, 2010 | Televison & Video
Connecting my TV and DVD player to a digital set top box
There are 4 different types of cables and they have to do with the quality and resolution of what they carry.
1) Coaxial or an RCA to RCA, 'Yellow colored connectors' - Composite video - Lowest quality of video you can get. Mostly what people hook up from their VCR's. '240 to 480 lines of interlaced resolution.
2) S-VHS cable - 4 pins - Carry Chroma 'Color' over the one set of two pins and Luminance 'B&W' signal over the other 2 pins. This is a higher resolution than the Composite video cable - 480 to 512 'still interlaced resolution' or ' i ' .
3) Component cables - RCA ends but there are 3 of them. Red colored 'for the Red video signal', Green colored connector 'for the Green video signal with Vertical sync laid on top of it,' and then Blue colored 'for the 'yep you guessed it' the Blue video signal with the horizontal carrier laid on top of the signal'.
This is the higher resolution of 720 ' i ' interlaced or even when selected by your piece of output equipment up to 1080p 'Progressive' resolution if your equipment can output this highest resolution.
4) HDMI - is a cable that not only carries the component but does it digitally along with audio and an ID bit that the Transmitting equipment 'STB' in this case should communicate with your 32" LCD HD-TV so that it will put out the maximum signal 'probably 1080P' that your TV will handle.
I would try to obtain an HDMI cable and use this to connect your STB to your LCD for the best connection between your two units.
Blessings,
A/V Media Guy
Nov 22, 2009 | Televison & Video
No color on my T.V., before when the T.V. would warm up it eventually came back. Now there is no color except when you press the Menu button the Menu showes color. What is the problem and what can we do to...
Sounds like the signal board may have a problemn OR If the signal to the set is low it could lose color burst. If you are using a cable box .. try removing it and hook the cable direct to the TV and see if any change. If the set works ok without the cable box that box may be the problem.
Nov 22, 2007 | Panasonic PT-61G54 61" Rear Projection...
No color
does the tv use Svideo as an input from whatever device you're using on the main screen? if so , try changing out the cable for a new one, svideo carries 2 signals, color and brightness (ie color and black signals) if your cable is bad or broken, you may only be getting one of those signals ( the black one) try a new cable if it's s-video. if it's not, get back to us.
Sep 13, 2007 | Hitachi 50SBX78B 50" Rear Projection...
Some channels have no color or sound
once a signal falls below a certain threshold the color will be lost.
some sets are more sensitive to this loss.
if you see static in the picture on any of the channels then the cable is leaking and needs replaced /tightened.
if a local air broadcast is leaking into a same cable channel on the cable you will get poor to no reception on that channel.
for example : he we have a local channel 7 on the air.
if i tune to cable 7 and see a weak or distorted pic then the cable is leaking and needs replaced.
May 04, 2007 | Philips Magnavox 15MF400T 15 in. LCD...
Metra 2006-2007 Volkswagen Rabbit 2.5 Antenna Cable Car Audio Radio Stereo Logo
24 people viewed this question
Top Metra Car Audio & Video Experts
xxxxxx xxx
Are you a Metra Car Audio and Video Expert? Answer questions, earn points and help others
