Question about GE PFCS1RKZSS Bottom Freezer French Door Refrirator
The water dispenser is not working. I here a click but the water is not being pumped. It is making ice. I have replaced the filter. I have confirmed the reserve the line is not frozen.
What could be the problem?
  • Bonita
    Bonita Dec 28, 2013
    I was able to fix the problem. I replaced the Dual Inlet Water Valve. GE Part #WR57X10032. Very easy to do. Takes less than 15 mins. On You Tube there is a video.
    Problem Solver:
  • 6 Answers
I often find this if I put my ice compartment onto high setting that the feed line freezes quickly. If you are sure this is clear (you can get water through the entire length via other means) then I would trace back to the start of your pipes look for leaks at joins from source to outlet, blockages/crimps etc. I also found on one of my lines that the transition near the door hinge was both leaking and crimped.
Remedy = I bought a larger bore plastic tube that would not quite press fit over it and bored it out lengthways with a drill bit the same diameter as the outer diameter of the pipe to perform a splice. The reaming leaves some debris which helps seal everything and if you get a good 3" overlap you will be water tight. I recommend to use an elbow rather than an in-line connection if your pipes change direction but be careful where you choose to put it. other than that if your model uses a pump? Beyond that, I am stumped.
Posted on Dec 28, 2013
2 Suggested Answers
woodchuck789
  • 4070 Answers
SOURCE: Water is not dispensed but icemaker is working
It's more common to be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws
If it doesn't come out then disconnect the line to the water dispenser at the water inlet valve on the back where the water supply comes in and try the dispenser. if you hear the valve work but water doesn't come out, the valve is bad. If the water comes out then check the reservoir.It's behind the crispers in the fridge.
Posted on Sep 07, 2009
Testimonial: "As I posted, I'm not sure what the problem/solution was, but its working now. Thanks a lot for pointing me to the crisper!"
No Water going in to the fridge
Hi Norm,
Most fridges don't need a motor to run in order to dispense water. A simple on / off solenoid on the water line (same for the ice maker) that makes a click when changing from off to on and on to off is usually all anyone hears (the ice maker makes rumbling sounds and you can hear ice falling into the bin - too).
Check for ice. If it has a maker and it is making ice, the problem could be a defective water dispenser switch, solenoid or other circuit component or wire. If no ice, I'd suspect a filter or water supply issue.
Make sure the filter is fully inserted and twisted into place. Many filters have marks to align when 1) inserting and 2) to let you know when it is installed correctly. When sure it is installed correctly - try to dispense water again. Many fridges will dispense water without a filter. Check your manual before trying this though! If not working still, remove the filter and try to dispense water. If you're able to dispense water, the problem is either the installation of the filter or the filter itself. Try to re-install it correctly. Try to dispense water again.
If it still doesn't work - call the plumber back and ask why there's no water. Or - try this yourself:
Locate the point of attachment to the domestic water supply that the plumber used. There should be a valve to turn the water on and off. If off, turn ON. Try to dispense water again.
If that doesn't work - check to see if the fridge has pinched, kinked or crushed the water supply line. You may need to move the fridge forward to gain access to the water line and connection point on the fridge. Repair or replace the line as needed and route in such a way that moving the fridge in or out will not cause it to damage the line again.
Nov 06, 2015 | Refrigerators
Ice maker not making ice, water dispenser makes a loud clicking sound when filter is in.I already replaced the dual water valve and tried a new water filter.
The gear that drives the mechanism that moves the ice out and allows fresh water to come in is damaged. In some cases the ice tray needs to come out so the ice cubes in the system can be removed by letting them actually turn back to water. Once you have cleaned it of old ice, try it again. Most likely a waste of time though.
What I have done to save money is find an old refrigerator someone wants to toss and pull the ice maker out. Chances are they have the same plug and wiring. Better if you just go get a new ice maker unit from where they sell parts for your refrigerator. It is easy to remove. usually about three screws or so. about two on top and one or more on the bottom side.
Jul 09, 2012 | Maytag MSD2652KES Stainless Steel
In door water dispenser of ED25QF will not dispense water. New filter, cannot detect kink in supply line, pump does not sound, still making ice, light in door works, dispenses/crushes ice. What is the...
The pump motor on the dispensing water is the problem. Pump motor problem is cause by no voltage power to motor, burnt motor winding, switch faucet on dispensing water, water supply line has jam, check it if you can if not, call a refrigerator service technician to do the job.
I hope I help you with your problem. Thanks!
Jun 11, 2011 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
Ice maker and water dispenser do not work. is there a switch or did something shut off?
  1. check water comming to fridg
  2. check filter(if you got one) new
  3. check if water come out of pump when you press water switch
  4. check voltage get to pump when you press for water.
  5. most likely the water got stuck and you need to replace : pump , filter
Jan 01, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water dispenser not working. Ice dispenser works
There should be a water filter inside the water lines to the water spout. This filter could be clogged, or the water lines themselves may still be somewhat frozen and not allowing flow to the dispenser itself.
You can also test the power to the dispensor to make sure it is drawing water. Can you hear the pump trying to pump water to dispenser? The water valve should also be opening. You can test power to the valve that draws in water from the external water lines.
Nov 25, 2009 | GE GSH25JFR Side by Side Refrigerator
I get water from the dispenser but no ice
As you open the freezer door you will se a wire on the side of the ice maker. It is there to stop the machine from making ice like a float in the toilet. It may have been bumped move it up or down until it clicks. it should go to work making ice now if not the valve in the back of the frig is pluged or bad. If you do not have a water filter it is pluged. The filter is cheep and easy to replace so I would turn the water off to it and replace the filter any way most are neglected.
Aug 12, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Kitchenaid model ksrs25ilss02 water filter
Are you saying water is dripping out the ice dispenser or the water dispenser, a water filter would have nothing to do with this, it only filters water, it does not pump water nor does it shut it off. If water
is dripping from the ice dispenser, it is because the rubber gasket
is bad on the flap that seals after ice is dispensed. If water is dripping
from the water dispenser, it is the shut off for the water, you can put a glass under it and push for water a few times,on and off and see if this makes it stop, if not you would need to have this replaced. Any questions please post back.
Mar 27, 2009 | LG LRSC26940ST 36" Side-by-Side...
No water from the dispenser
You need to replace the dual solenoid one side is for the water the other is for the ice.
Jan 18, 2009 | Amana SXD524VW Side by Side Refrigerator
Ice and Water not dispensing. Light button not working
INSIDE THE DISPENSER ASSEMBLY IS A SEPARATE ELECTRONIC BOARD THAT CONTROLS THE DISPENSER.
OCCASIONALLY, THE DOOR SOLENOID OR THE CUBE ICE SOLENOID WILL SHORT OUT CAUSING A BURNOUT OF THE DISPENSER CONTROL BOARD. CHECK FOR A BURNT SMELL COMING FROM THE DISPENSER HOUSING. IF YOU SMELL IT, THE BOARD AND/OR SOLENOID NEED TO BE REPLACED.
Apr 10, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice/water dispenser not lit or working
I think this is probably just a coincidence that you changed the water filter and a couple of weeks later the dispenser doesnt work. If it failed the same or next day then possibly related but unlikely. The water filter purely affects the water supply line. Does the dispenser (water) make a noise (clicking) when activated. If it does then I would check the incoming water supply. If it makes no noise then you possibly have an electrical fault not providing power down to the water solenoid valve. The way to check the ice dispenser is to see if you first have any ice production if you do then again it could be an electrical control fault. You could check the underneath of the cabinet low level for the wiring connection from the door to see if it is dislodged or damaged however if it is a control issue then I would suggest contacting a good fridge tech. Hope this helps.
Sep 05, 2007 | Amana ACD2232HR Side by Side Refrigerator
GE PFCS1RKZSS Bottom Freezer French Door Refrirator Logo
99 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
