Sharp xl es50 cd shelf system
CD stops when playing, display reads "Protect". What does this mean? how to fix?
    Problem Solver:
  • 6 Answers
Maybe the amplifier system is locked!!!
the means that you have to reset or restart it
Posted on Dec 29, 2013
SOURCE: won't play a cd
put a mp3 cd it will work worked for mine has truoble reading regualr cds
Posted on Feb 08, 2008
SOURCE: CD problem in Sharp Micro Component Shelf system XL-HP515
Compra un disco limpiador de lentes laser y puede que esto solucione tu problema ya que puede ser solo suciedad en el lente.
Posted on Apr 09, 2008
SOURCE: protect with xl-es50
the audio amplifier IC are damaged
Posted on Oct 12, 2009
toolkits
  • 1099 Answers
SOURCE: XL-MP60 Shelf System: stereo shuts down and reads protect...
Hello, the problem of you stereo appliances been shut down was as result of a mechanism jam of the system.
The way you could do this is to open the back cover of the appliances and check for the rubber attached to the motor of the appliances, also check and see if you can adjust the mechanism if it is a disorder manner, it require a careful approach.
This will require a skilled personnel to handle this
Posted on May 19, 2010
  • 6771 Answers
SOURCE: My Sharp XL-HP500 CD Shelf System turns on, but shuts off immediately.
No! you have short in the system, remove speaker wires from back and plug headphones in, if okay it means there is a short in the speaker wire or speaker, if no change the audio output ic's should be suspect.
Posted on Jun 17, 2012
The display just reads "protect"
Protect is bad. It means the amplifier thinks it is overloaded. Check the speaker wires to make sure there are no loose connections or shorts.
Mar 01, 2011 | Sharp CD-BA2600 CD Shelf System
Cd player say's protect and will not play cd
If protect is coming up on the display, it means the system is detecting a short somewhere on one of the speakers and so is turning the amp off to avoid damage.
Check all the connections at the back of the amp to ensure they are not shorting, and at the back of each speaker, if nothing is found there, check each wire for damage (like squashed or rodent damage).
Jan 27, 2010 | Sharp XL-ES50 CD Shelf System
Protect with xl-es50
Oct 12, 2009 | Audio Players & Recorders
Sharp Micro Component System XL-ES50 won't turn on
my copies sharp mx 2700n how to go SP mode and i get eroor code h5.01
Dec 22, 2008 | Sharp XL-ES50 CD Shelf System
Sharp XL-HP505 Not playing CDs
Hi try this.....
Put the system in standby (ie off but plugged in) then whilst pressing down the record button and the X-BASS/DEMO button, press the PRESET DOWN (i.e.left hand one) button until "CLEAR ALL" appears, then power on your system.
This gave me some functionality back i.e. i can play normal wave CD's but not mp3 ones....
Hope this helps
Sep 07, 2008 | Sharp XL-HP505 CD Shelf System
"NO DISC" reading
Try this CD realignment process built into the Sharp XL HP505: Have unit off.
Hol down the square (stop) button and the X-BASS button while pressing the ON button. This starts the CD TEST. press play, the memory, then memory, memory, memory, adjustment lights will come on the screen. FOF, TOF, TBAL, TGAN, FGAN, RFLS. press cd1 - track 4, press cd2 - track 9, press cd3 - track 15. Press square (Stop).
If all the cd trays are full, then will light up . This worked for me.
Aug 02, 2008 | Sharp XL-HP505 CD Shelf System
Power protect
The protect mesage indicates a problem with the final stage of the output amplifier. The unit shuts down to prevent further damage. Please update this with the make and model and I should be able to point you to the problem part(s).
Thanks,
Dan
May 26, 2008 | Sharp XL-ES50 CD Shelf System
Sharp-XLES50 Help...
If the unit stays on at a low volume and cuts off when volume is raised, then fan motor maybe defective. If it cuts off no matter what volume level it's on then output IC maybe at fault.
Nov 04, 2007 | Sharp XL-ES50 CD Shelf System
No disc displays
The laser needs to be cleaned or replaced (probaby replaced).
Sep 16, 2007 | Sharp XL-35 CD Shelf System
49 people viewed this question
 Grubhead
Grubhead
