My heater stop working today
No heat is coming from it
  • 20 Answers
Is it electric heat or gas heat
Posted on Dec 28, 2013
Heat problem
They are called blend door motors and if I am not mistaken that car has one on the drivers side and one on the passenger side. The way you tell if they are working is gain access under the dash to them and turn the temperature nob from cold to hot and watch to see if the actuator moves and then back. It could be stuff clogging the vents too. Or possibly a clogged heater core.
Nov 18, 2014 | 2005 Toyota Corolla
Why would water come out of the air blower on my pentair master temp 400
take off top[ and see if coming from heat exchange or pressure switch leaking
Jun 27, 2014 | Teledyne Laars Laars Lite 2 Pool Heater...
My heater model number 36j24 just stop working today any solution?
The heating element is not powering on; either it is open and needs to be replaced or the thermostatic mechanism that feeds power to the element is not functioning.
Dec 28, 2013 | Water Heaters
2003 mazda 6 heater has stopped working
Air Temperature Control Blend Door Failure No Heat or no AC (dependes on where door sticks)
In all modern cars there is a tiny DC electric motor driven gear drive that moves a plastic door that blends heated and cooled air from the AC and the heater core, this is called (interestedly enough) the air temperature control blend door actuator. The motor that moves this door fails because the door starts sticking from warping, most common complaint is no heat but it can be no AC as well. To replace these parts (blend door and blend door actuator) you must remove the entire dash from the car. Always have this problem confirmed by a dealer or qualified repair shop as it is a very expensive repair.
Other causes of no heat in the cabin are engine thermostats that are stuck open (engine runs cold) or air bubbles in the cooling system.
Dec 19, 2012 | Mazda MAZDA6 Cars & Trucks
2006 kia sedona today the heat and a/c just stopped working. There was no loud noise or anything to signal it was breaking. No fan comes on, no compressor kicks in, the lights on the dash don't
Check fuses end relays. Fuse could be blowin. If the lights don,t come on on the heater control panel for the different funtions, Mostly the fuse has (Blowin)
Oct 16, 2012 | 2006 Kia Sedona
Water not heating wha to do
First thing is to look at label on side of unit.
This will show what brand, type and model water heater you have.
Then repost question with that information so expert can access correct information.
Also include if this is a new water heater, or old water heater that stopped working, and approximate age of unit since models change very quickly today.
Aug 26, 2012 | Water Heaters
2002 taurus, power windows all stopped working at once along with lighted window switches. Drivers window stuck down. Relay was hot! Also heater blows cool air, started doing this after I added radiator...
LOOK FOR BLOWN WINDOW CIRCUIT BREAKER.YOU HAVE A SHORT IN WINDOW SWITCH OR BAD WINDOW ELECTRIC MOTOR.YOUR HEAT PROBLEM IS A STOPPED UP HEATER CORES.THE STOP LEAK STOP ITS HEAT.THE STOP LEAK HAS STOPPED OR PLUGGED YOUR HEATER CORE SO COOLANT CANT PASS THROUGH IT.YOU GOING HAVE TO FIX RADIATOR LEAK AND REPLACE HEATER CORE TO GET HEAT AGAIN.
Jan 28, 2010 | 2002 Ford Taurus
My truck seid it was over heating when i turned on the heater it stopped.then the next day i turned on the heater it would only blow cold air and then it went hot and then it went cold again
Check you coolant level could be low or your thermstat could be messed up or your water pump could be going out. Worst case blown headgasket or cracked heads. On most cars when you turn the heat on it pulls heat out of the radiator. On most cars when you turn the cold ac on it pulls cold coolant from the radiator to use. Many cars today are coming with systems that are separate.
Oct 17, 2009 | 1994 Chevrolet S-10 Blazer
2005 GMC Sierra 1500 heated mirror stopped heating
I do not see a separate fuse for the heaters, so you have power thru the 25 amp breaker. You will, have to pull the panel up or access the mirror connector to trace power to the elements. Not sure which is easier. I have pasted all of the relevant diagrams.
Likely failure modes are open heating element and failed heater switch.
Jul 23, 2017 | 2003 GMC Sierra 1500
Heating & Cooling Logo
15 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
