Kobo instructions books are on it but cannot turn it on says sleeping
    Master:
  • 796 Answers
Take the books off it. Can you turn it on now?
Posted on Dec 28, 2013
2 Suggested Answers
  • 1575 Answers
SOURCE: kobo - instructions for set up
Click on the link for the detailed User Guider downloads.
download.kobobooks.com/learnmore/touch_userguides/Kobo_eReader_Touch_User_Guide_110610.pdf
Hope this helps.Thanks!
Ken.
Posted on Jan 18, 2012
Kobo frozen. Willl not respond to touching button
Performing a basic reset A basic reset will force your eReader to restart properly. In many cases, this is enough to restore your eReader to normal.
  1. If possible, turn off your eReader.
  2. Locate the small hole on the bottom of your eReader.
  3. Unfold a paperclip and slide an end into the hole.
  4. Press gently until you feel a click. Your eReader should restart.
Performing a factory reset If a basic reset doesn't work, you can perform a factory reset to restore your eReader to its original settings. After a factory reset, you'll have to set up and sync your eReader again.
If you perform a factory reset on your eReader, you'll:
  • Remove all books from your eReader. Any books you purchased from Kobo can be re-downloaded from the Kobo Cloud after a factory reset.
  • Lose any bookmarks and annotations you made in your books since you last synced your eReader.
  • Sign out of your account on your eReader.
  • Reset all of your settings and preferences.
  • Return your eReader to its original settings.
  1. If possible, back up any books or documents that you added to your eReader using Adobe Digital Editions, or that you manually added using your computer. You do not need to back up any books you bought from Kobo. Any books you purchased from Kobo can be re-downloaded from the Kobo Cloud after a factory reset.
  2. Go to your Home screen.
  3. Tap the ios-menu.svg Menu icon at the top of the screen.
    The Quick Settings panel will appear.
  4. Tap Settings.
  5. Tap Device information.
  6. Tap Factory Reset under Advanced.
  7. Performing a factory reset If a basic reset doesn't work, you can perform a factory reset to restore your eReader to its original settings. After a factory reset, you'll have to set up and sync your eReader again.
    4. Tap Settings.
kobo com help Resetting your Kobo Glo HD
Jun 30, 2016 | Kobo eReader
My kobo is frozen on starting sync won't turn on or off
Note: If your Kobo device has been physically damaged, it is no longer covered by Kobo's limited warranty. On a Kobo eReader, a physically damaged screen will look like it's been shattered, or you may see vertical or horizontal lines on the screen with a frozen image. If you haven't dropped or damaged your Kobo eReader, but are experiencing issues, try the steps below in the order suggested.
  • Turn your eReader off and then on again.
  • If your screen is frozen, slide the power button to the right and hold it for 10 seconds. Your eReader should turn off.
  • Turn your eReader off and charge it for at least four hours. Note: Your computer should be turned on while you are charging your Kobo eReader.
  • If your eReader isn't charging, try using a different Micro USB cable or a different USB port on your computer. Note: If your eReader's battery is completely drained it can take up to 15 minutes before it reacts to being plugged into power.
  • If you're having trouble while reading a book on your Kobo Aura H2O, Kobo Aura, Kobo Aura HD, Kobo Glo, or Kobo Mini: tap the centre of the screen to bring up the Reading Menu, tap the > Home icon to return to your Home screen, then open your book again.
  • If you're having trouble while reading a book on your Kobo Touch: press the Home button and open your book again.
  • Try a basic reset.
  • If you're still having issues, consider a factory reset.
  • If you're unable to reset your device, please contact Kobo Customer Care
Mar 14, 2015 | Kobo 6" eReader Touch Edition
Kobo reader stuck in sleep mode
Try resetting the kobo reader by turning it off and back on again
Sep 30, 2014 | Kobo eBooks by Kobo
I cannot find how to delete an individual book. The answer is there as to how to delete all the books but not an individual book.
One way is to use a program like Calibre on your computer. When the Kobo is connected, you have access to the books on it and can individually delete them.
Aug 19, 2014 | Kobo Glo E-Reader
How to turn off kobo aura and not leave it sleeping
Move the on/off slider to the right and hold it there for at least 10 seconds before releasing it will turn the Kobo off. Any less than that and it goes to sleep.
Aug 12, 2014 | Kobo Aura E-Reader
How do i download books onto my kobo ereader
You should have first of all downloaded Kobo desk top apps on to your computer - after which you can buy book....then syncing ...once the book has been loaded to your library you plug your e-reader in and syncing, this loads the book on to your e-reader..
Good luck
Jun 29, 2014 | Kobo eBooks by Kobo
New books downloaded are not showing up on my kobo
When you have downloaded - and payed for the books, you must click on up date to library, after which you can plug in your e-reader and down load to it
hope this helps
Apr 06, 2014 | Kobo eBooks by Kobo
My kobo wont open the book, keeps loading but does not open
Does your Kobo turn off and on normally? Or is it stuck loading the book and totally not responding? If so, reset your Kobo. Look on the bottom edge of the Kobo - see the little pinhole? Stick a paper clip into there until you feel it push against a little switch. Remove the paper clip.
Is the Kobo working, but simply can't open a book? If it's only affecting a particular book, try deleting it and downloading it again.
Dec 27, 2013 | Kobo Arc
My touch screen kobo reader has stopped working
Make sure the Kobo is fully charged and switched off. Hold down the 'HOME' key while turning the Kobo on. When you see the power light release the 'HOME' key. The lights will flash. Follow the onscreen prompts.
Jan 06, 2012 | Kobo eBooks by Kobo
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
