Question about GE BOARD ASM, MAIN CONTROL - WR55X11098
What does this control on a refrigerator? How would you know if it needs to be replaced?
  • Bonita
    Bonita Dec 29, 2013
    I'm looking for symptoms that would warrant a possible problem related to this part. Thanks
farfield
  • 462 Answers
SOURCE: Defrost Heater or Main Control Board, Which one is at fault?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} To answer your question I know of no reason the electronic type of board would cause the heater to go out unless the defrost thermostat (or sensor) and board stuck in the defrost possession and did not stop the heater. Any time you replace the board and have had a defrost problem a check of the heater will either confirm or eliminate it but the defrost sensor should be replaced if the board is being blamed for non defrost. I cant rule out 100% that a bad board will not cause a heater problem but the high 99% range is most likely. If you have a volt ohm meter and can find the heater circuit on your board and the freezer has been running down to correct temp you can check the defrost circuit by ohming it out. Lower resistance of 10 to 60 ohms is common. Anything higher will require ohming the heater out directly and the defrost thermostat will be open if the temperature is above the stats range.
Common to all self defrosting refrigerators / freezers is the need to move air around to pickup heat inside the compartment. Common to all frost free refrigeration to maintain this feature are 3 items:
1 and initiator (defrost timer or circuit board),
2 A heat source for defrost (Usually an electric heat element but can be other types of heat sources)
3 A safety limit to stop the heat source, leaving it warm enough to defrost and keep the heat contained where it will not affect the compartment advisedly. In a standard type defrost (non - electronic) it is called a thermostat. In an electronic board defrost it is called a sensor.
The defrost timer / or board will never be in the Freezer. Other than that it could be in the refrigerator section behind a plastic cover or metal cover on the back outside. It could also be under Neath the front corners or center of the front kick plate.
A timer you can turn the cam clock wise till it clicks. A board will depend on the manufacturer as to how to send into defrost for a test. A sensor on the defrost type board may be required to by-pass into defrost or test mode.
The freezer section has the only cooling coil. It sounds like it is blocked with frost and thus won’t let the air circulate from freezer to refrigerator.
There is a defrost timer, (or board), a defrost heater, and a defrost safety thermostat. Any One of these or a combination of 2 can be your problem. If you have a energy efficient model that has electronic controls then you will have a board. The procedures for checking the circuit on a board vary by manufacturer of the board used and manufacturer of the appliance.
The defrost heater always has resistance and is attached to the freezer coil.
The defrost thermostat is also attached to the heater electrically, unless it is an electronic sensor type. Sensor types have a range of resistance that needs to be known to check and varies slightly with the temperature of the sensor.
If I haven't lost you here you maybe equipped with the life experiences that will allow you to do most of these checks. If its over your understanding I recommend you contact a reliable technician..
Posted on Apr 17, 2009
aasc
  • 1606 Answers
SOURCE: ice and water working intermittently, makes ice, Artica PSS 26NG
Go into the test mode and use 0 4 as the test code between the dispensor board and the main board .(communication test) Sounds like the main control board though .
Posted on Jul 19, 2009
Sea Breeze
  • 4655 Answers
SOURCE: evaporator coil freezing, replaced main control
It is possible you have a defective fan motor in the condenser area or evaporator area. Sometimes when they become defective they will run for a while and just warm up and stop while the compressor continues to run. I learned that one on four costly returns to the home. The cost was to me not the customer. Thanks, Sea Breeze
Posted on Aug 05, 2009
heatman101
  • 43501 Answers
SOURCE: GE profile bottom freezer unit
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Nov 21, 2010
bobicehouse
  • 1524 Answers
SOURCE: I have a GE refrigerator (model # GSH25SGRESS).
Change the control. GE has a number of problems with the original boards.
Posted on Dec 29, 2010
WHIRLPOOL SID BY SIDE FRIDGE MODEL GD5RHAXNT00 LIGHT HAS GONE OUT IN REFRIGERATOR AND TEMP GUAGE IS NOT SHOWING A READING
What youre experiencing is a common main control board failure.
The main control board for this model is no longer produced. But, don't scrap your refrigerator because new control boards are no longer available -- Save your appliance and high replacement costs and let us remanufacture the control board for you. This is a common control board failure that FixYourBoard.com can repair. We remanufacture the main control board in your model and back our work with an industry leading two year warranty. W10135090 Whirlpool ELECTRONIC CONTROL BOARD MAIN CIRCUIT BOARD
May 26, 2014 | Kenmore 57029 Side by Side Refrigerator
Control Board died
BOARD ASM MAIN CONTROL 801 WR55X10942
go here and in right top corner enter your mod number or this part number
https://www.geapplianceparts.com/GEApplianceParts/modelsectionsearch
Dec 10, 2013 | GE Refrigerators
My ge profile refrigerator temperature digital printout reads 999,888,777, etc. Is this a main control panel problem, thermostat or digital control itself?
This is just a bad display control board. You need to replace the actual display control board in order to correct the issue unfortunately. I'm not sure what shorted out both your main control and your display control board, but you will need to replace your display control now. hope this helps :)
Aug 04, 2013 | Refrigerators
I have a whirlpool side by side refrigerator model no GS5SHAXNB00 refrigerator light blew this morning i replaced the bulb no lights working on refrigerator side and temp control settings
you need to replace the main/board for sure located in the lower rear left hand wall of the unit in a plastic case, it will have 3 wire harnesses unplug the unit,undo the plastic container and unplug the the board and there will be a burned spot on the case and burned trace on the circuit board, reason being,this is very common on any of these sideXsides,if a light blows out in the refrige compartment it puts a surge on the board and burns the circuit trace open,this makes the digital temp read-out go dark and if the lamps light at all they "strobe" dimly or not at all,and you will hear a clicking of the relays in the rear area trying to latch the light bulb circuitry, but cant because the main/mother-board is defective now
Mar 02, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Fridge will not adjust temp, set @ 37* will go to low of 29* what part is needed?
you will need to access and replace the "A.S.M. main control board" in the rear lower corner of the back of the unit,as this board controls all refrigerator functions,it has a cover over it, un plug refrigerator,unplug the board after removing protective cover, then reverse procedure and plug in board and re-plug in refrigerator and this will take care of the temperature problem you have
Dec 08, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezing up
sounds like it might be the defrost timer.
Jun 12, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
REFIGERATOR AND FREEZER NOT WORKING
Was the unit completly defrosted? Did the tech check to see if the compressor came on? Also, when the board is replaced, depending on the unit, there are wire to be cut so the board will work with that particular model. Check to see if the compressor is running first. then make sure the unit was defrosted. the other problem could be one of the thermistors deffrctive that control the defrost..
Aug 01, 2008 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
GE refrigerator/freezer
Need to check voltage coming from control. If no voltage you need to replace main board on the rear of ref.
May 23, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE BOARD ASM, MAIN CONTROL - WR55X11098 Logo
67 people viewed this question
Top GE Computers & Internet Experts
micky dee
mukhtar21 shaikh
mukhtar21 shaikh
Ricky Ostrom
Ricky Ostrom
Are you a GE Computer and Internet Expert? Answer questions, earn points and help others
