Question about Baby Gear
Gate opener I am trying to install new batteries in my AGS 9000 solar electric gate. However,when I try to connect the wires to the new batteries, I am creating some major sparks from the battery terminals. It doesn't matter which wire I attach to the terminals, the result is the same - lots of sparks. The wires are not colored red and black but, rather, they are colored yellow and green. There is also a white wire, which I assume to be the ground wire, so perhaps that is the problem? Does the white wire have to be attached to anything to allow the positive and negative connections to be made on the battery? Help - I am not an electronics expert, and this seemed like an easy fix to just replace the batteries. Guess not.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,727 Answers
Obviously something else is wrong causing the batteries to go bad OR there is a capacitor in there and this is normal. check with the manufacture
Posted on Dec 28, 2013
I replace the mothrboard on elite slidding gate but the batery loses power
Since you have a battery and it is a sliding gate, I will assume you have a Roboslide model by Elite. The battery has to be charged in order for the gate to work. The charging comes from a transformer or a solar panel. Check to make sure these have power coming out of them. Most gate operators use a transformer and if the two wires providing the voltage touch each other, it will blow the transformer. If you have a volt ohm meter you can check this. You might need to use the AC setting as well as the DC since some are 18 volt DC and others are 25 volt DC. You can do the same for a solar panel but only use the DC setting.
If this is not your issue, then make sure it is your battery draining and not something binding in either the motor or the gate. Finally, it could be the motor going out. Simply hook the charged up battery directly to the motor to check it. It should respond strongly. Reverse the leads to make the motor go the other way.
Good luck.
Mar 08, 2015 | Elite Sl 3000 Ul Sliding Gate Operator
Gto 2000xl
I had a similar problem. I replaced the rev counter and all was well. Now looking for the electric motor or specs for an after market replacement.
May 30, 2012 | GTO Pro Sw3000xl Control Circuit Board -...
What does AGS meen
AGS, (Annualized Geothermal Solar) heating, combining passive solar and geothermal heating techniques.
Jun 18, 2011 | Zodiac Pool & Spa
Wher to buy eurotech EWC177W parts (drain pump)?
Poor Earth Grounding
One of the biggest problems with electric gates is poor installation. In particular, many people do not properly ground the gate or fence during installation. Grounding rods must be placed under the gate in order to keep it safe for people and animals. Drier climates require more grounding rods. An improperly ground gate can cost thousands of dollars to repair.
Barbed Wire Fencing
Some farmers have tried to electrify a barbed wire fence, but this is a major safety hazard to animals. Animals can get stuck in barbs whether or not they are electrified, but the added electricity can lead to their death. Barbed wire should be avoided on farms and should never be electrified.
Interference
Occasionally, electric gates may experience technical difficulties due to interference. Local radio, television, or telephone signals or wires can cause the interference for both the media system and the gating system. Such interference can cause the gate to lose its electric charge temporarily. The interference can also cause brief spikes in electricity in the gate, which can be a safety hazard to people or animals.
Insufficient Animal Training
Since electric gates on farms are intended to keep animals in their assigned area, the animals must learn about the consequences of crossing the electric gate. Farmers or property owners must therefore train their animals to avoid the gates. To train the animals, owners must actually expose them to the electric shock. Owners who fail to shock-train their animals may find that their animals become obstinate or may get seriously injured.
Crime Target
Owners who install electric gates at the edge of their property often do so for security. Ironically, the presence of such high-tech gates may signal to would-be robbers that the owners are very rich, making the owners theft targets. Property owners may want to install an alarm system to accompany the electric gate to increase security.
Feb 23, 2011 | EuroTech EDV158 Electric Dryer
Gate (operated by push button) open by itself
could be picking up a signal that is telling it to open from somewhere else. seems the button just supplies power to it from the way you explained it
Jun 13, 2017 | Gardner Bender #GSW-22 Push Button Switch
I have an elite robo swing r900 gate opener. gate door's are not closing, battery keeps beeping and it shows low battery
first check you battery and make sure it is putting out 12v dc then if you have a solar power system check the red and black wire comming from the panel and make sure it is putting out 24volts. if you panel is not putting out the volts it caused your battery to die so replace your panel and battery and all should work fine. if your using a trickel charger do the same check power its putting out and make sure its correct and also check the 120v ac comming in to the charger. Follow the steps it deffinatly sounds like a power issue.
Nov 09, 2009 | Elite Sl 3000 Ul Sliding Gate Operator
Sealed Lead Acid Batteries: 12v 7ah; belongs in a Liftmaster LA400 gate control box. Can these batteries be charged using a trickle charger? I'm trying to find out if it's the battery not holding a charge...
A 12 volt battery needs about 13.5 volts to reach a full charge. It should stay at what ever voltage you bring it up to, with no load connected.
Most gate controls are solar charged and should be fine under normal circumstances.
Charge the battery with a regular 'automotive' type charger and then test it with a few cycles, open and closing gate.
Also check voltage from charger at gate...
Aug 05, 2009 | Electronics - Others
Baby Gear Logo
459 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Baby Gear Expert? Answer questions, earn points and help others
