Question about Motorola Mobility Bluetooth Hands Free Headset Wireless Headset
H371 Password How do I determine the password?
  • 740 Answers
Its 0000 thats the default password. Good luck and thanks for using FIX YA
Posted on May 18, 2009
Disable bios password
You cannot disable the bios password, depending on the make and model of laptop will determine if it can be removed. Go to www.ebay.com Type: bios password and go through the list of sellers carefully.
May 06, 2012 | Computers & Internet
Tip
When was the last time the SQL Server sa password changed?
With the rights that the sa login has by default in SQL Server, it is imperative to change this password on a regular basis whether it is monthly, quarterly or semi-annually. In addition, as DBAs move on to other opportunities, it is wise to change the sa password as well. Changing sa password should be a relatively easy process requiring little to no impact on the organization. Unfortunately, changing the sa password on a regular basis is not a common practice at most organizations, because the impacts of changing the password are unknown.
Solution
The first step in the process is to find out when the sa password was last changed. If this timeframe is unacceptable to your organization, then steps need to be taken to understand where the sa login is used and how the application can be modified to use another login.
SQL Server 2000 - sa password changes
In SQL Server 2000 a documented process does not exist to determine when the sa password was changed. The best means to determine if the sa password has changed is based on the value from the updatedate column in the master.dbo.syslogins table. This value seems to be the only possible column to determine if any property (default database, default language, etc.) for the sa login has changed. Since the sa properties do not change frequently, the value for this column should be a reasonable, but not an absolute indicator of when the sa password was last changed. Reference the code below to determine the value for the sa login's updatedate column.
USE Master
GO
SELECT sid, [name], createdate, updatedate
FROM master.dbo.syslogins
WHERE [name] = 'sa'
GOSQL Server 2005 - sa password changes
Unfortunately, SQL Server 2005 suffers from the same self documenting issue as SQL Server 2000 as it pertains to the last time the sa password has changed. The modify_date of the sys.sql_logins catalog view can be used as an indicator of when the last property (default database, default language, etc.) for the login has changed. Just as is the case with SQL Server 2000, this value does not guarantee the date ime stamp of the password change, but rather any property change. Since the properties do not change frequently under normal circumstances this value can serve as a reasonable, but not an absolute indicator of when the sa password was last changed. If other properties have changed, the modify_date is not a true indicator and other research/documentation is needed to determine the last sa password change date.
USE Master
GO
SELECT [name], sid, create_date, modify_date
FROM sys.sql_logins
WHERE [name] = 'sa'
GOTo address the risks of changing the sa password, stay tuned for the upcoming tips in the sa series from MSSQLTips.com.
Next Steps
  • If you are scratching your head as to the last time the sa password was changed, then it is worth taking a look at your key SQL Servers
  • If the last time the sa password has changed is unacceptable to you, then begin to work with your team on taking the necessary steps to changing the sa password
    • In addition, stay tuned for the upcoming sa series tips on how to determine who and what applications are using the sa user name and password
  • In order to prevent the sa password from becoming stale in the future, be sure to put processes in place to change the sa password on a regular basis
  • For additional information from MSSQLTips.com check out the following:
    • The first tip in the sa series - When not to use the sa password
    • Stay tuned for the upcoming tips in the sa series:
      • Determine how to find out who and what applications are using the sa user name and password
      • Password management options for the sa login
on Apr 08, 2010 | Computers & Internet
I forgot the password for my Motorola H371 bluetooth.
Try default code ,use 1 or 2 or 3or call the service provider.
Jul 31, 2011 | Motorola Cell Phones
What can i do if i forgot password for bluetooth to use with another cell phonen its asking me for a password.
You could try the bluetooth generic passwords (0000 and 1234), these usually work with most devices.
Dec 01, 2010 | Motorola Mobility H371 Bluetooth Headset
Need password to connect to my phone. Motorola bluetooth H371
Hi,it all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Hope it helps..
Thanks for using fixya...
Oct 27, 2010 | Motorola Mobility H371 Bluetooth Headset
I'm trying to pair a Motorola H371 to a Blackberry Bold 9650. I can't find the password for the pairing. Do you know what it is?
The generic PIN (Which is what I'm guessing you need) for most bluetooth devices is either 0000, or 1234. Please try those and see if that solves your problem.
Sep 29, 2010 | Motorola Mobility H371 Bluetooth Headset
I have followed the directions given to me by the seller to pair my bluetooth to my Motorola Razr V3. Twice it has found it and said it is an H371. But that is all that happens. The process usually doesn't...
try these simple steps
1.first make your bluetooth on
2.there is anothr option of visible or something (make it visible for some time)
3.then on your bluetooth device.
4.It will ask you password
5.enter the password 0000 or (given password by retailer)
6.then your mobile will be paired with bluetooth device
Jun 19, 2009 | Motorola Mobility RAZR V3c Cellular Phone
Need passcode for Motorola H371 Bluetooth device.
I have the Motorola H371 the Passcode is 0000
Apr 06, 2009 | Motorola Cell Phones
Need to change password as all neighbors are using (I gave it out
You need to determine your gateway IP address. Click on your network status to determine that. It will most likely be 192.168.1.1. You can open a web browser and go to http://192.168.1.1 to get to your router login page. Try admin for your username and leave the password blank.
That should bring you the interface where you can change the wireless security settings to "enabled" and set your password. Let me know if this works for you!
Your ex may have set a different password for the router, and you may have to do a factory "reset" on the router.
Mar 30, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
Motorola Mobility Bluetooth Hands Free Headset Wireless Headset Logo
171 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
