Question about Vizio 55" Class LCD 1080p 120Hz HDTV, E552VLE
Power fuse located
Won't turn on, No power indicated on front no light , just seem to stop!. did a power cycle. electric outlet fine.
Please my tv with on the standby mode when i try to put it back it couldn't the indicator now goes on and off with picture show please help
The standby light on a Sony television indicates when the television is turned on and operating, or turned off and in "standby" mode. However, this light also serves a secondary function: indicating when there is a problem with the television by flashing. When the standby light begins to flash, there are two reset options that can be performed to resolve whatever issue it's indicating -- a power reset and a factory reset
POWER RESET
1. Turn off your TV
  • 2. Unplug the television from the electrical outlet. If you're using a surge protector or power strip, disconnect the television from the strip itself. Only by disconnecting the power cord from the outlet can you ensure no power reaches the TV during the power cycle.
  • 3. Leave the television without power for at least 60 seconds. This gives the television enough time for all components to power down during the power cycle
  • 4. Plug the television back into the electrical outlet. If you're using a surge protector or power strip, plug the television directly into the wall outlet instead. The surge protector may otherwise interfere with the power-up cycle, especially if it is old or damaged.
  • 5. Turn on the television. If the blinking standby light continues, you'll need to move on to the factory reset process.
  • FACTORY RESET
  • 1. Turn on the television.
  • 2. Press and hold either the "Reset" or up arrow button on the remote control.
  • 3. Press and release the "Power" button on the front of the television, while keeping the "Reset" or up arrow button on the remote depressed.
    4. Release the "Reset" or up arrow button.
    5. Allow the television to reset after the "Reset" message appears on the screen.
    6. Make no adjustments to the television for at least one minute after the reset has completed. This is to allow the television time to finish auto-configuration and initial set up.
    7.Turn off the television and unplug the power cord from the electrical outlet.
    8. Wait ten seconds, then plug the television back into the electrical outlet and turn on the TV.
    9. Follow all on-screen instructions to complete setup. These are the instructions displayed the first time you set up the television, for configuring channels, menu language, time, display properties and more.
  • Dec 30, 2014 | Sony FD Trinitron WEGA KV-32FS120 32" TV
    MIne Whirlpool duet is having probloms please help me with it!
    see this causes and fix it. God bless you
    User Control and Display Board If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
    Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
    Line Fuse If the washer won't start the line fuse might have blown.
    Thermal Fuse If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
    Line Fuse and Holder If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
    Main Control Board If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
    Door or Lid Latch Assembly If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
    Door Lock Motor and Switch Assembly If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
    Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the home.
    Power Cord If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
    Oct 05, 2012 | Indesit W 123 Front Load Washer
    Kenmore Elite Model 110.42926 202 after setting the desired cycle will not start when you push the start button
    Oct 05, 2012 | Kenmore Elite 45986 Front Load Washer
    My Kenmore H3T washer will not start. When a specified wash cycle is chosen Time of Cycle is displayed but the light for the cycle only flashes and washer will not start. No error code is displayed.MO
    Sep 27, 2012 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
    Kenmore HE2 Won't Turn On
    1) test the power cord for open 2) test the outlet box, see for blown fuse or c.breaker put some desk lamp and see if work 3) test inside of the control board if there fuse blown or c.breaker tripped 4( test the lid switch is closed, can be faulty or open replace 5) test the input voltage 115 if there are the control board faulty.
    Jul 18, 2012 | Kenmore HE2 Plus Front Load Washer
    I have an admiral electric dryer. It stopped in the middle of a cycle and the light is out and it won't turn on. I checked the fuse box, the plug and the belt is still on, so what do I do now?
    Did you test the power outlet with another device...Sometimes a power outlet will fail under the load of a high current appliance like a drier...If the drier runs on 220 volt current...and have circuit breakers instead of fuses...make sure the 220 volt breaker for the dryer is not tripped...If it is tripped...reset it....if not...have a tech to check the outlet. oncee it is established that the drier is getting power and still not working...you may want to get it checked out by service personnel....Hope this was helpful....PEACE.....
    Jan 25, 2012 | Admiral Dryers
    The electrical outlet in the Montana SV6 is not working. Could it be a fuse? Where would we find the fuse if that is the problem.
    On our 2001 Chevrolet Venture (same vehicle under the sheet metal), both the front and rear 12v outlets are controlled by the same fuse, which is in the fuse box located next to the passenger front door. If one of these outlets blows the fuse (a portable ball/tire inflator will do the trick with us), all of them will shut down.
    I have also had the 12v outlets stop working, even when the fuse was good. I discovered that I had a bad connection at the fuse box; wiggling the fuse box assembly itself would cause the outlets to flicker on and off. Detaching and re-attaching the modular cable that connects the fuse block seems to have corrected that problem for the most part. However, sometimes, our 12v outlet will still flicker, even though power remains constant to everything else in the vehicle.
    Jun 27, 2011 | 2005 Pontiac Montana SV6
    A pulled fuse panel for a 2003 Jeep Liberty, there are 39 fuses inside a vehicle. I need to know what these fuses are and what they go to.
    The fuse box diagram is a sticker placed on the inside of the fuse box cover. This cover is located on the left end of the instrument panel (driver side). The sticker just uses numbers to indicate the fuses. I will match the fuse number with its purpose:
    1. Power Outlet, Front
    2. Rear Fog Lights
    3. Horns
    4. Headlight, Low Beam, Right
    5. Headlight, Low Beam, Left
    6. Body Control Module / Power Door Locks
    7. Spare
    8. Spare
    9. Right Park Light / Right Tail Light / Trailer Tow Lights / Cluster
    10. Spare
    11. Flasher
    12. Stop Lights
    13. Body Control Module / CMTC / Cluster
    14. Spare
    15. PDC Fuel Pump and Auto Shut Down Relays / SKIS
    16. Power Outlet Rear
    17. Rear Wiper
    18. Radio Choke
    Jun 19, 2010 | 2003 Jeep Liberty
    Burning smell (electrical) from my washing machine
    possibly the suppressor capacitor. take lid off and trace where mains input is connected and that is the suppressor. they sometimes go pop
    other possibility is the neon burnt out
    Oct 03, 2008 | Smeg WD16BA Front Load Washer / Dryer
    Vizio 55" Class LCD 1080p 120Hz HDTV, E552VLE Logo
    Top Vizio Televison & Video Experts
    Computer Repairing
    Computer Repairing
    Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
