Question about Lucent AT&T 960 Corded Phone
Can't Read incoming call numbers in led display
Number to light to read
My LG tv model number 42LN5400-UA no picture
It is a common problem for the LG 42/47 LN series LED TV, the problem is defective LED back lights strip (strips).
You have to open the display panel to find the bad one & replace it. The part number usually is printed on the strips, read 6916L-11XXA, you may purchase it from EBay.
Aug 11, 2017 | LG Televison & Video
Control panel lights on whynter 12000 btu portable air conditioner .can't read some numbers
This is due to the detrioting condition of the display, sometimes an even lite press with fingers on the display may help. This happens due to loss of contacts inside due to poor quality of display or aging.
Oct 13, 2015 | Whynter ARC-12S ECO-FRIENDLY 12000 BTU...
How bellsouth caller id ci 43 contrast adjustments?
If the display is too light or too dark, you should adjust the contrast of the display.
Press either review button until NO CALL or the number of calls displays. Press and hold the READ button approximately 5 seconds until the display reads CONTRAST followed by a number. Release the READ button and use the review up and review down buttons to change the contrast number. When you are finished, press READ again.
From:http://users.javanet.com/u/s/use/caller_id_ci43.htm
Apr 26, 2014 | Canon Office Equipment & Supplies
When I reply to an e-mail on OUtlook 2010, the font size is very small - and I cannot read the original or what I am typing. Any ideas on how to restore the normal size
Having trouble seeing that small default font of Microsoft Outlook emails? There are three ways of making Outlook email text bigger.
The first includes increasing the text size of the outgoing email messages.
The second includes increasing the text size of messages that are replied to or forwarded.
The last includes making all the text of incoming emails larger as well.
Go to the Tools menu and select Options.
Click the Mail Formats tab and then click Stationary and Fonts.
Find the Personal Stationary tab, then find and click the Font button located under the New Mail Messages heading.
On the Font tab that appears, there will be a variety of options including changing the type of font, style, size and color.
Find the drop-down menu that is under the Size heading and select a bigger number.
Click OK and the new setting will take place the next time a message is composed.
Replies or Forwarded Mail
Find the Personal Stationary tab, then click the Font button that is located under the Replying or Forwarding Messages heading.
Click OK and the new settings will take place the next time a message is replied to or forwarded.
Incoming Email Messages
Look for the Display Font heading on the Personal Stationary tab and increase the size the size of the font by selecting a larger number.
This will increase the text size for all plain text incoming email.
However, it will not increase the text size of incoming HTML emails.
Set the option to read all incoming email as plain text if it is necessary to increase the text size of all incoming emails.
To do this, go to Tools, then click on Options, then look for the button that says Email Options and click Read all Standard Mail as Plain Text.
Create the menu tab on your homepage right click in the top toolbar you should see a number of toolbar options select the menu tab which will add File Edit View Favorites Tools and Help
May 11, 2013 | Microsoft Outlook 2010
Display is faint and to light to read
Turn the calculator on. Hold down the "C" key (just above the ON key) and press + to darken the screen. If you go too far, use the C and - keys to lighten the screen.
Jan 21, 2012 | HP 10b Calculator
My new Hp Officejet j3680 caller ID is not working... All the phones in the house display the incoming phone numbers except the j3680. I wonder why?!! it shows instead ringing!!!
The caller ID phone having the tip & ring detection circuit to detect the incoming phone number, but in this model doesn't have tip & ring detection circuit to display other phone number but after connecting the other fax it will read the information which was stored like company name & phone number of other one..
Jan 04, 2012 | HP J3680 Officejet All In One Printer
How do i reprogram my speeddial numbers on jazz 4400?
Hello.
From NorStar Support:
To Program Personal Speed Dial Numbers: (Numbers 71 - 94 only.
1. Press the Feature button, then * 4
2. Enter the 2 digit code (71 - 94). that you want to assign to that phone number
3. Enter the telephone number, then press the OK softkey
4. Display will show: "Entry xx stored"
If the above doesn't work, try:
  1. Press [Feature] [*] [4]
  2. Enter a two-digit code from 71 to 94.
  3. Specify the external line by pressing a line button, a line pool button, or the intercom button. If you don't specify the external line, the system automatically chooses a line for the call.
  4. Dial the telephone number you want to program (up to 24 digits).
  5. Press [Hold].
  6. Record the code and number you have just programmed.
Hope this helps.
Feb 02, 2011 | NorStar Jazz Plus 4400 Corded Phone
Incoming text
remove some of the stored messages from inbox , out box, ect.
Feb 10, 2008 | Nokia N93 Cellular Phone
Sharp UXB700 Fax
Below is for when you are using machine in fax mode, is that how you use it or are you also using the answering machine function? ie TAD mode
If desired, you can change the number of rings on which the fax machine
answers incoming calls in FAX mode. Any number from 2 to 5 can be
selected.
1 Press FUNCTION once and 3 times.
Display:
OPTION SETTING
To select FAX mode, press
(with no document
in the feeder) until the arrow in
the display points to FAX.
RESOLUTION/
RECEPTION MODE
RESOLUTION/
RECEPTION MODE
FAX
A.M.
TEL
Using TEL Mode
58
2 Press once and once.
3 Press once.
4 Enter the desired number of rings (any
number from 2 to 5).
Example: 3 rings
5 Press to return to the date and time display.
Note: If you are using Distinctive Ring, the fax machine will answer calls after
two rings regardless of the above setting.
Oct 16, 2007 | Office Equipment & Supplies
Lucent AT&T 960 Corded Phone Logo
15 people viewed this question
Top Lucent Lands Phones Experts
Paul C.
Computer Repairing
Computer Repairing
Michael Galve
Michael Galve
Are you a Lucent Lands Phone Expert? Answer questions, earn points and help others
