Question about Kenmore Washing Machines
Intake error kenmore elite 796
Intake error persists on Kenmore elite washing machine. I have cleaned the screens and put new hoses on. Still get IE Error during normal cycle.
  • 125 Answers
SOURCE: kenmore elite oasis he top loader
Is it an f code followed by a 51?
Posted on Jan 21, 2008
aborcass
  • 2651 Answers
SOURCE: Leaking Kenmore elite he3 washing machine
removethe lower acess panel 3 screws across the bottom , run the cycle and watch to see where exctly the leak is coming from it should be quite apparent
Posted on Mar 10, 2008
IFIXALL
  • 868 Answers
SOURCE: Kenmore Oasis HE 2708..LF error code
Replace the water valve
Posted on May 26, 2008
jimappliance
  • 42 Answers
SOURCE: Kenmore Elite Catalyst washing machine getting error F4
See if this helps.
http://www.askmehelpdesk.com/appliances/washer-kenmore-elite-catalyst-110-20092993-f3-f4-error-codes-191730.html
Posted on Aug 01, 2009
jan mczeal
  • 632 Answers
SOURCE: Kenmore Elite Oasis HE washer error code F2
The error code must be cleared first to make the machine back into operation. You have to press the PAUSE/CANCEL button twice to clear the error on the display.
The only filter the machine has is the one you removed to clean the pump. When the error is cleared, you can check the pump whether it is operating properly or not by running the diagnostic test.
Diagnostic Test Mode Procedure
  1. Close the door.
  2. Select the DRAIN/SPIN.
  3. Select NO SPIN by pressing the SPIN SELECT button.
  4. Press RINSE/HOLD or PREWASH OPTION button four times within five seconds.
  5. "C:00" will show on the display indicating that the door is locked and the diagnostic test starts.
  6. Press the button you pressed in step 4 above two times. "C:01" will show on the display and the machine starts to fill.
  7. Press PAUSE/CANCEL button two times when there's enough water inside the tub to stop the test.
  8. Observe the water level falls as the pump starts draining the water. Replace the pump if the water inside the tub does not drain. You have removed and cleaned the pump so you can easily replace it too.
Please inform me about the result of the diagnostic test and if you still need any assistance regarding this problem.
Posted on Jan 20, 2010
What does error code IE mean?
The "IE" error code indicates that there is a water inlet problem on an LG washing machine. This code appear's if the washer will not fill to the correct water level. There are 3 possible causes for the IE code.
1) partially or fully closed water supply lines
2) improperly attached supply hoses
3) clogged supply hose filters (on machine and in the hoses).
Nov 20, 2014 | Sears Kenmore Elite 4.5 cu. ft....
Kenmore elite washing machine says IE and wont drain
IE is water-inlet error. Try unplugging your machine and restarting.
If that doesn't work turn off the water, unscrew the water hoses from the machine and check for debris.
Aug 21, 2014 | Washing Machines
Kenmore Elite hf error
May I have the complete model number, so we can get started?
Feb 03, 2014 | Kenmore Washing Machines
I have a kenmore elite and I keep getting the error LF? What can i do?
LF means long fill clean your screens in your water inlet hoses also make sure the hoses are not kinked and that both hot and cold are turned on ...Good luck and if I helped you please vote...
Feb 02, 2011 | Kenmore Washing Machines
My Kenmore front loader will fill with 3 or 4 inches of water on it's own, when it is off and door is ajar??
Hi, possible your water intake valve are faulty, check back of machine where your( 2) intake water hoses are connected, shut water off, remove and clean water valve, it's possible you got high water pressure in you home (building) or your water valve maybe strain, or has a mechanical fault inside of it, you can remove back of machine, remove water solenoid valve, put valve apart and clean plunger, put valve together and see if same thing happened, if water still comes in after cleaning valve, you should replace it. before doing any repairs unplug machine, (disconnect power) good luck.
Aug 13, 2009 | Kenmore 44102 Front Load Washer
My kenmore elite HE3 washing machine has low
For low water volume - or "Trickling" effect...
1. Turn off the water supply to both hoses.
2. Remove hoses (one at a time so you don't get them confused)
3. On the washer side - look for a removeable screen inside wher you just removed the hose.
4. Using a small screwdriver - pop out the screen and reverse-flush it/clean it. It will likely be full of sediment and calcium deposits from your pipes.
5. Replace the inlet screens.
6. Re-fit the hose to the machine.
7. Turn on water supply valves.
8. re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 02, 2009 | Kenmore Washing Machines
HE Elite Smartwash quiet pac 4 front load washing machine
F32 is the pressure switch issue. Just press and hold the power switch for 5 seconds to reset this error.
Sep 02, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
24 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
