Question about Frigidaire PLHS69EGSS Stainless Steel Side by Side Refrigerator
WATER WILL NOT STOP RUNNING
MY WIFE WAS GETTING WATER FROM THE DOOR AND THE WATER WOULD NOT STOP RUNNING. WITH THE DORR OPEN IT WOULD BUT CLOSED IT WOULD NOT
  • windsorguzzi Dec 28, 2013
    Hi Brian , I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
2 Suggested Answers
  • 39 Answers
SOURCE: stove door wont close
try shutting off power and then turn on..If this doesnt work turn on self clean again ,start it then after a few seconds cancel. This should tell the lock to release.
Posted on Apr 04, 2010
A constant tick-tocking is heard, and when passenger dorr is open for 5 minutes or so, while checking fuse panel, the clicking stops... but when I close the door, it starts again... What to do,,. Remo
First, remove the cigar lighters ans see if the noise stops.
Second, remove fuses one at a time to locate which fuse is associated with the noise.
Third, if that does not help, post the make, model, and year of the car so we can help you more.
Dec 28, 2014 | Cars & Trucks
My side door will open 3 inches then stop.i have to slide the door alittle bit before the door opens all the way...the door stops after 6 inches while closing ,I have to assist the door as before to c
Check the wiring harness for the door cable. 2004, 05, and 06s had the same issues. Over time, the dorr may catch the cable in the track, giving a slight yank, or moisture gets into the harness fouling the conection.
Feb 07, 2014 | 2007 Dodge Caravan SXT Minivan New Cars
Washer is displaying no error code however the cycle stopped in the middle. I tried to rerun the load. The dorr locked but it will only buzz. Now the door will not unlock and nothing will male it run. I...
You may have a water valve issue. (leaking water past valve, allowing water to fill to higher than normal level) To unlock, try opening the access door at the bottom left on front of machine and using small hose there, drain water out of machine. If hose is plugged, you may have to unscrew big knob (with filter attached) to drain. When the water level lowers, door should unlock. (if washer is plugged in)
Apr 12, 2011 | LG WM0642H
Garage door wont close - acts like there is an object in the way. If is detach the door from the sliding unit, the door closes easily. If I try running the slider down without the door attached, it stops...
It sounds like the sun may be shining on and causing problems with the door sensors. Try using the cardboard tube from a roll of toilet tissue on the receiving sensor.
Sep 06, 2010 | Sears Craftsman LiftMaster Chamberlain...
Open the dishwaser while still filling now keeps going to error
After reading a few of the other Haier models troubles, I pulled the unit out and tip it at 45 degrees backwards for around minute. Water pored from the back of the unit, once cleaned water up reinstalled unit and all seems to be back in working order.
May 16, 2009 | Haier Dishwashers
Fridge not cooling...tested evaporator fan
check door switches
when you open the dorr does the fan normally stop then on closing start again
could be door switch fault
Jan 26, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
Oven door stays open
Hi , the oven dorr needs ajustment , lose some attachement bolts ,then close the clearance will shut , so open gently and tightened the bolts.
Jan 06, 2008 | Whirlpool GBD307PDS Electric Double Oven
CD door
try cleaning the mode swith that opereates the dorrs it sounds like its dirty
Nov 15, 2006 | Emerson MS3100 3-Disc CD Changer
Frigidaire PLHS69EGSS Stainless Steel Side by Side Refrigerator Logo
20 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
