Trying to get rid of motion interpolation on Bush LED TV
Suffering from the soap opera effect on a Bush le-55gb2a LED TV. Can't seem to find any way of turning off or reducing the motion interpolation. Image is horrible. Any help please?
  • Gary Collinson
    Gary Collinson Dec 28, 2013
    Connections are fine. Problem is the image is way too sharp, due to the motion interpolation. It's unwatchable, and there doesn't seem to be a way to turn it off like there is on most LED TVs.
    Master:
  • 796 Answers
This is a sign of a weak signal being fed to the TV. Check the cable from your aerial/antenna is good, or your cable tv cable is good.
Posted on Dec 28, 2013
  • keshu modhwadia
    keshu modhwadia Jan 26, 2014
    i have the same tv and the same problem, its not a weak signal or a fault just a feature added in by bush, no way to switch off in menu either, only way is if bush make available a software update i guess.
3 Suggested Answers
gopakumarg43
  • 75311 Answers
SOURCE: bush tv
What is the exact model number to your Bush TV?
Posted on Apr 25, 2012
gopakumarg43
  • 75311 Answers
SOURCE: Red LED Light Blinks 7 Times Tv Wont Turn On PLEASE HELP!
Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
You must have through knowledge in electronics to proceed. This is a very skilled wor. You must have all measuring instruments, and ability to follow its schematic diagram.
Posted on Jun 13, 2012
Hiw do i connect my tv to the internet? 8ts a bush 40" full hd led smart tv
You really need to read the manual to your TV. You need to have a router connected to a high speed Internet service. If you mean connect to the Internet, your smart TV will,have to have a browser, like Opera to enable you to get online. The smart TV apps are selectable with your remote, but you have to get the connection first. If you don't have high speed Internet and a wireless router it ain't gonna work. I don't have the manual to your set, so I can't tell you the exact steps you use on your remote control.
Jan 24, 2015 | Bush Televison & Video
Tcl led hdtv won't program with comcast remote
If Comcast does not list a code for your TV, your remote probably does not have a code in its library that will work.
Jan 25, 2014 | TCL 50 Class LED HDTV - 1080p, 1920 x...
Bush tv code LE-55GB2A
0392,0399,0391,0390. Try these codes. If you wish to get more, try the following links. Both the sites linked have set-up code list & set-up procedure to many popular brand remote controls.
http://electrohelponline.blogspot.com/
http://electro-medical.blogspot.com/
Jan 21, 2014 | Televison & Video
Sky remote does not work for bush LE-32GE11E
NONE WORK CANT STAND THESE KIND OF SITES WHERE PEOPLE SEEM TO GO OFF TRACK WITH THE TV MODELS !!! PLEASE READ MODEL BEFORE POSTING OVER OTHER MODELS NUMPTIES WASTED MY F ING TIME
Feb 15, 2013 | Bush Televison & Video
Displays an LE error code - what does this mean and how do I fix it?
Codes for LG/Kenmore washers:
IE: Water level (246) was not reached in 8 minutes
UE: Imbalance: Load too, small too large
OE: Drain problem took longer than 10 minutes to drain
FE: Overflow issue drain pump running to comp
PE: pressure sensor (sensor out)
dE: door error. open door. switch is out
LE (with a a slash in the
middle of L. Upside down F) Thermistor out
CE: Over amping Too much soap wrong soap
LE: hall sensor shorted/destroyed from sudslock
bE: Ball sensor loose connection/out of order
EE: eeprom out test mode only
PF: power failure momentary interuption of shocktricity
FYI:
Nearly all brands of "HE" detergent have incorrect instructions.
The correct amount is as follows:
HE: (2) Tablespoons Per Wash load
HE 2X (double concentrated) : (1) Tablespoon
HE 3X (triple concentrated): (1) Teaspoon
This reduces/prevents:
1) Musty Odor
2) "LE" Error/Interrupted Cycle
3) L-O-N-G Cycle Times (longer than time displayed)
4) Insufficient Cleaning Results
5) Small Water Leaks from the air vent behind the washer or at the
front door gasket
6) Damaged Hall Effect Sensor (on 2007 or older LG washers)
7) Reduced Spin Speeds (laundry not spin-dried effectively)
Also:
Problem:
An occasional LE error but always a slow or no spin: Solution:
A Red wire going to the Hall sensor was intermittent. You can test this from the main board connector down to the connector on the hall sensor by checking continuity. There is an intermediate connector down by the motor/hall sensor so you can isolate the problem even more. Problem was in the short wire harness that connects directly to the motor and hall sensor. Could not find the open point of the wire so added a new red wire and integrated it into the harness.
I have service manual and more here
Jan 16, 2011 | Washing Machines
Hi, ive just bought a new samsung LE40c654 (100hz) and when watching sport the ball moves with a half moon shadow ahead and behind! My feed is from Sky HD and the shadows are mainly when the ball is moving...
I believe that you are suffering from what is called Soap Opera Effect...."SOE" The problem with newer TV's is that they try and guess what happens next as they are too fast when compared to TV shows and movies which I think are 24 ad 30 frames per second and this sometimes leads to shadows in action situations. What I did was to alter the settings for the TV by going to You Tube and searching my TV model and Soap Opera Effect and changing my settings. It worked great for me....perhaps it will wok for you as well.
Dec 22, 2017 | Samsung Televison & Video
I have a new 40" Samsung 120 tv and blu ray player. when playing movies the picture has the soap opera effect. I have turned of the auto motion plus and the picture still looks terrible. What else can I...
You didnt specify what type of samsung TV you have but the are picture presets for most of the ones i have come across, they are named in this format Dynamic, Cool, Smooth etc, they are presets so you can select the closest to the effect you want and then from there fine tune the picture with the brightness, contrast options, Hope this helps...
Oct 26, 2010 | Samsung Televison & Video
What does interpolated mean?
Interpolated means something was inserted between two points.
Oct 06, 2010 | Mitsuba DC500T Digital Camera
Vizio SV470M, picture is moving too fast
This is often called the "Soap Opera" effect...I had a similar problem and found that changing the settings helped tremendously. Here are the settings I use:
Picture Mode: Movie
Backlight: 18
Brightness: 49
Contrast: 52
Color: 42
Tint: 2
Sharpness: 3
Advanced Video
Noise Reduction: strong
Color enhancement: off
Advanced Adaptive Luma: Off
Enhanced Contrast Rato: off
Color Temperature: Normal
Red: 121
Green: 128
Blue: 118
Smooth Motion Effect: low
Real Cinema Mode: Precision
Also, there's a great thread on the Soap Opera effect here:
http://www.hometheaterforum.com/forum/thread/291611/the-soap-opera-effect-on-modern-displays
Feb 25, 2010 | Vizio SV470M LCD TV
Televison & Video Logo
117 people viewed this question
Top Televison & Video Experts
