Inner screen is crack on a kurio
Kurio 7 Screen Replacement
Written By: Eric Rice (and 6 other contributors)
Comments: 2 Favorites: 5 Completions: 12
Main guide photo
Difficulty
Moderate
Steps
12
Time Required
30 - 45 minutes
Sections
Back Panel
4 steps
Kurio 7 Motherboard Removal Guide
5 steps
Screen
3 steps
Flags
Grammar Police
Grammar Police
Embrace your inner English teacher and help improve this guide's grammar!
Introduction
This is an easier part to replace than many others on the Kurio 7. Most require soldering, but this one does not. However, you must exercise extreme care when taking the device apart so that none of the soldered connections are broken. In the event that they are broken, look to our other guides for repair tips.
Tools
Buy these tools
Phillips #00 Screwdriver
$6.99
Buy
iFixit Opening Tools
$1.99
Buy
Parts
Kurio 7 Replacement Screen
Available for sale on Amazon
Buy
Step 1 Back Panel
Begin by removing the rubber cover from the Kurio 7.
Add a comment
Post comment
Step 2
Remove the four 30 mm Phillips #00 screws from the outer case.
Add a comment
Post comment
Step 3
Insert the plastic opening tool in the gap between the front cover and the back cover of the device.
Slide the plastic opening tool around the edge of the device. Gently pry apart the tabs that hold the front cover and the back cover together.
Be careful not to break off the tabs that hold the front cover and the back cover together.
Add a comment
Post comment
Step 4
Once all of the tabs are removed, the back cover should come off easily.
Gently remove the back cover. There are wires inside that may get caught on the cover while removing it. These wires are soldered to their components and are difficult to reattach.
Add a comment
Post comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Buy Now
Step 5 Kurio 7 Motherboard Removal Guide
Use a plastic credit card, or other thin object, to separate the battery from the screen.
Be sure to work the card carefully and slowly around in order to not damage, break, or deform the battery.
Carefully set the battery aside.
Add a comment
Post comment
Step 6
Use a Phillips #00 screwdriver to remove the eight 40mm screws holding the motherboard in place.
Place the screws aside in a container separate from the other size screws. You will need these later.
Add a comment
Post comment
Step 7
Place the plastic opening tool on the base of the black ribbon clip and pull up, like a lever, to release the mount. This should release the clip holding the ribbon to the mount.
Pull the ribbon out of the mount.
Add a comment
Post comment
Step 8
There should be masking tape on the yellow ribbon. Pull the tape off of the motherboard and wrap it around the yellow ribbon.
Do not pull the tape completely off the motherboard, as it is used to protect components on the ribbon.
To remove the ribbon from the mount, follow the same steps in Step 3.
Add a comment
Post comment
Step 9
Pull back the ribbons and put the battery near the bottom of the Kurio.
The motherboard is now removed so that other components can be worked on.
Add a comment
Post comment
Step 10 Screen
Flip motherboard down near base of device.
Be careful not to pull out any wires when moving the motherboard.
Add a comment
Post comment
Step 11
This is tricky, and an extra pair of hands may help. Use the opening tool to pry the screen out from underneath the tabs holding it in place.
Once you have created some space between the screen and the cover, slide the opening tool under the screen.
Slide the opening tool around the outside of the screen, releasing the tabs as you go along.
Be careful not to pull too ******* the motherboard while doing this, as there are still many wires attached to the body of the device.
Add a comment
Post comment
Step 12
You have successfully removed the screen!
Pull the screen out from the casing.
