Question about Sony Walkman Audio Players & Recorders
Wont charge at all stays deadwont charge
Mp3 was dead plugged it in has been all day and still has no life tried connections is fine plug in works
    Master:
  • 796 Answers
Check the charger is working by using a multimeter to measure the output voltage.
Posted on Dec 28, 2013
SOURCE: Isonic Snapbox mp3 player wont turn on or charge
get a new mp3
Posted on Jan 07, 2008
M1k3z0rX
  • 4 Answers
SOURCE: SanDisk, 2 GB Sansa mp3 player won't charge
You MAY have a power glich. In which case, hold the power/menu botton down for 20 seconds or more, then connect it to the computer.It's best if you use a USB input that's NOT part of a Multi-USB base, as those DO cause power gliches.
Posted on Oct 20, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: my sansa mp3 player won't charge or connect
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Dec 28, 2008
em78
SOURCE: barbie mp3 quit working
You have to change the battery. To do that you have to take that thing off on the back of the MP3 player and unscrew it to change the battery.
Posted on Jun 10, 2009
d-ruffles
  • 65 Answers
SOURCE: My memorex touch mp3 player won't turn on.
Hi sluzenski5, I'm not a member, but I do have a solution. Please take the following steps: 1. Get a small piece of lead 2. Make sure mp3 is off hold(lock) 3. Insert lead into reset hole, press so you feel the click. 4. Hold power on switch for 3 secs, maybe 5 5. Enjoy your music! If this works or doesn't, email me at: d-ruffles@hotmail.com Good Luck
Posted on Jan 02, 2010
My acer aspire 7736G was working fine, it's about 2.5 years old, and is used mainly with the power cord plugged in. When using it the other day the computer just went dead on me. I took the batter
You have reached the end life of the battery pack. The battery must have some minimum charge to have computer function even with the AC power pack connected. So I suggest you replace the battery pack as a solution. Any local Radio Shack store can test this battery I am told free of charge.
Jun 20, 2012 | Computers & Internet
My coby mp826 mp3 wont turn on when i try to turn it on and when i plug it in to charge my cp wont decdect it and it wont charge it doesn't even turn on when i plug it in
Sorry to say it but it sounds like it is dead. You could try to leave it alone for at least a day to potentially kill off the battery in case of a firmware crash, then try charging again, or press and hold the power switch for 15-35 seconds. Other than that, I have had similar issues with rather cheaply built mp3 players, which are fragile to drops, faulty firmware, and of course, water.
Jun 01, 2011 | Coby MP826 MP3 Player
Battery wont charge
I would say leave it stay on then after its fully dead charge it up again . That should fix your problem if it doesn't leave a comment and ill try to help again.
Jan 09, 2010 | GPX Audio Players & Recorders
RCA M4304 mp3 player wont charge even when plugged in
As long as your computer can see the player, it is likely the firmware has gotten corruped.
First, connect your player and back up any important media items that are on it.
Next, download and run the firmware installer from the RCA website:
http://voxrightnow.custhelp.com/app/answers/detail/a_id/5635
Nov 08, 2009 | RCA M4304 Digital Media Player
My battery went dead. plugged it in and wont do anything
mine is doing the same. i have a SanDisk 4GB mp3 video player & mines went dead too and it will show it charging for a few seconds then it will just stop & it will just show the connected sign. try holding the power button for 15 to 20 seconds. maybe that'll work
Sep 03, 2009 | Philips Audio Players & Recorders
Sansa 1g clip wont turn on.
did you try holding the power button on for ten seconds (the reset) after trying to charge it again? does it even power up when you plug it into the usb. if it powers on when connected to the usb and then shuts off immediately when you take it off the usb (rather than "refreshing database") then your battery is either 1)disconnected inside 2)dead or there may be issues with power management. Same thing happened to me (disconnected) but I soldered the loose connection and it only worked for two days, even checking the connections again. Now I don't know what's going on. It's more likely the battery has reached the end of its life.
Nov 16, 2008 | SanDisk Sansa Clip MP3 Player
My creative zen is completely dead it doesn't power on at all also it doesn't charge there is no power what so ever please help me
I have had the problem of the completely dead player after having it for less that an day. No response to any buttons, no response when plugged into USB to charge, and Windows sees it as an "unknown device" when plugged into the PC. It tried the reset hole, and still nothing.
Then I tried connecting it to the PC to charge and then using the reset hole. Success - the player sprang back to life, fully charged. Hope this helps someone.
Jul 17, 2008 | Creative Labs Zen Stone Plus MP3 Player
My mp3 won't turn on
How do i set up a playlist
Apr 10, 2008 | SanDisk Sansa e250 MP3 Player
Completely dead
did you try plugging/charging it into your computer?
Jan 01, 2008 | SanDisk Sansa e250 MP3 Player
35 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
