Question about Frigidaire FEX831CS Top Load Stacked Washer/Dryer
I am looking for a washer motor for an old gibson stackable washer....but they discontinued the part!
    President:
  • 272 Answers
These guys have motors for most machines, bot sure what motor your running. You need to get the model number off of the placard on the motor, give them a call if you have any other questions. Here's the link:
http://cgi.ebay.com/Washer-Motor-134172800,-131902800-fits-Gibson_W0QQitemZ280341079838QQcmdZViewItem
Posted on May 18, 2009
Ge stackable washer dryer MODEL wsm2700wbwww
3 year old GE stackable washing machine, had water coming out the top and would not drain or go through cycle, when shut off it drained a little but when turned on again it filled up and over flowed.
Apr 18, 2010 | GE Spacemaker Washer and Dryer Electric...
Buying a used Kenmore stackable washer/dryer
stackables are convenient..small but work great.....youll find what you need at lowes or home depot
Nov 04, 2009 | Kenmore 98702 Stacked Washer/Dryer
Can you buy a frigidaire stackable washer separately?
Have you had a qualified service man look at your machine? I would think that the burned rubber smell would direct you to examine the belt (found in the very bottom after removal of front cover).
If it is the belt it is a very easy fix on this machine. The not draining part wouldn't be related to the belt the pump that does the draining is driven by its own electric motor and is easily visible when the front cover is off. Its located on the bottom left side. If a sock or other small item manages to get over the side of the basket it always ends up jamming the pump.
You would have to take the pump apart to retrieve the item and restore pump function
Good Luck
Quentin
Aug 18, 2009 | Frigidaire FEX831CS Top Load Stacked...
Matag stackable My Drier Squeals loud on start up
could be motor put oil on back baring aka rollers
Jan 29, 2009 | Maytag LSE7806A Top Load Stacked...
Asko stackable dryer/Bosch stackable washer compatability
If you arer going to replace the washer with a Bosch Axxis model, it will simply plug into the back of the dryer (if it is electric) because normally the dryers are 220 VAC. Works A-OK.
Nov 23, 2008 | Bosch Axxis WTA 3510 Electric Dryer
Maytag stackable washer top loader
try replacing entire lid switch assy, come ith new fuse!
Oct 31, 2008 | LG WM2077CW Laundry XL Front Load...
Belt installation whirlpool stackable
thats funny cause they dont have belts
most have motor couplings that will break and it wont spin
if it still agitates its gotta a motor coupling
Jul 08, 2008 | Frigidaire FEX831CS Top Load Stacked...
Maytag front lead stackable
That is correct. Take the screws out of the console up top. look for a burn mark on your circuit board. If it's on R11, replaced your door lock wax motor as well at the board.
Jun 04, 2008 | Maytag Neptune MAH5500B Front Load Washer
Frigidaire Front Loader Won't Drain
if your washer is digital or with elecronic control board check the the motor control board located at the bottom difiniely you have to call a tech to confirm that. other model like wd5595 and wd 8095 has the same problem and it is the motor control unit that always fails.
Mar 21, 2008 | Frigidaire GLTF1670A Front Load Washer
Frigidaire FEX831CS Top Load Stacked Washer/Dryer Logo
265 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
