Question about Toshiba Computers & Internet
Keyboard laptop Hi I have a Toshiba Satellite L750 . I have recently spilled wine on the keyboard and am trying to fix it . I have removed most of the laptop frame and dried it . When I put the keyboard back , some characters / numbers dont work . How do I fix this problem please .
    Top Expert:
  • Toshiba Master
  • 23,200 Answers
Replace the keyboard. Go to flea bay and purchase a replacement.
Here is one;
http://www.ebay.co.uk/itm/Toshiba-Satellite-L750-L750D-L755-L755D-C655D-L675D-L650-L670-Laptop-keyboard-UK-/160987408149?pt=UK_Computing_Laptop_Keyboards&hash=item257b98e715
Posted on Dec 28, 2013
  • 2 more comments
  • Anish Hemachandran Dec 28, 2013
    Hi . I did test it with one of my old Keyboards in which only ESC was not working . But with that too , it is showing similar results . Will it help if I reinstall keyboard software ?
  • JonSnell Electronic
    JonSnell Electronic Dec 28, 2013
    Probably not. If the keyboard connector, (socket) got wet, that could cause it.
    So would I have to replace the socket entirely or just wait for it to dry up properly ?
    You cannot replace the socket unless you have hot air and a desoldering station. If it is wet, order areplacement keyboard and by the time it arrives, it will be dry.
CheTzu
  • 3 Answers
SOURCE: toshiba satellite touchpad & keyboard stopped working
As I understand your keyboard is now working and your usb mouse. But the touchpad does not work.
Have you or someone opened up your laptop recently? If so it is possible the touchpad was not connected properly.
Can you please post the exact name of your laptop. I'll see what else I can figure out for you.
Posted on Oct 03, 2008
yurid316
  • 283 Answers
SOURCE: How to clean coffee spill from Toshiba laptop
Have you tried to open a laptop? If not, try to go to service center it might causes more damage.But if you can, use a tissue and a ligther fluid to clean the keyboard membrane. Dry it well so that it cant causes shorted.... Thank you for using fixya....please dont rate me if you are not satisfied with my suggestions.
Posted on Nov 14, 2008
resnonverba
  • 28 Answers
SOURCE: spilled milk on toshiba satellite M505-S4940
  1. Make sure to unplug all cables and power. Remove all!
  2. If the screen can be tilted all the way back so as to lay the Laptop flat, then lay the laptop flat, keyboard down, on top of a large piece of paper towel.
  3. Watch to see that the towel absorbs excess liquid, remove the laptop.
  4. Fill a liquid sprayer with some water, remember to remove any soaps or detergents from the container. Use water only.
  5. Form a medium size paper clip into a square hook that will fit beneath the suspect keys.
  6. Place the hook under a key and pull gently upwards until the key pops out. Be careful, I have broken a few!!!
  7. As can be observed when you do this, the keyboard is visible and cleaning can be done with a cotton swap. Spray the cotton swab with the sprayer; do not spray directly onto the keyboard. The idea of the sprayer is to avoid mishaps like dropping excess water onto the keyboard!
  8. When done with all suspect keys; replace the keys always aware of the right positioning to avoid rework! Remember to clean inside, under the key etc.
  9. If this doesn't do it or are hesitant; take it to a technician.
Posted on Feb 13, 2010
SOURCE: I have to remove my Lenovo y430 keyboard so that i
1.Lift up the keyboard cover and put it in front of top case. Disconnect the LED cable and launch board cable then take the keyboard away.
2.Remove 2 screws (M2.5*3)then lift up the keyboard and lay it in fron of top case then disconnect the keyboard FPC. now take the keyboard away.
**Removing the keyboard cable.
1. Use a flexible connector tool to unlock the cable connector on both ends
2.Carefully pull out the keyboard cable with a pair of tweezers
3.Lock the connector again to avoid possible breakage
Posted on Mar 27, 2010
pcsyke
  • 152 Answers
SOURCE: Brand new Toshiba Satellite L750
Hello there,
Drivers and Manual Link
Try pressing, Function key + F9..
F1= Lock Computer Mode F2= Change Power Settings F3= Change to Sleep Mode F4= Change to Hibernation F5= Switch Active Display F6= - Brightness F7= + Brightness F8= Enable/ Disable Wifi F9= Enable/ Disable Mouse cursor
About the keyboard lock? I have no idea, because most laptops have cursor lock only. Correct me if I'm wrong. Hopefully this helps.. Thank you for posting..
Posted on Jul 12, 2011
When I type on my laptop extra letters or appear
You will possibly need a new keyboard to be fitted into your laptop. Did you spill anything on to your laptop?
Do you have a desktop keyboard you can plug into your laptop via USB? Try this and see if you can type normally
If you provide details of your exact model number I can assist you with purchasing another keyboard for your laptop
e.g. Toshiba L750-___ or Acer Aspire ____
Mar 15, 2015 | Computers & Internet
My laptop computer's webcam (Toshiba Satellite L750) is not functioning
Try reinstalling the WEBcam driver.
You can download the WEBcam and device drivers for your model laptop from the Toshiba WEB site from their download page. Make sure you enter the model of your laptop so you can get the correct drivers. Please click on this link: - http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp
Feb 28, 2013 | Toshiba Satellite Computers & Internet
Toshiba satellite l750-16l "a disk read error occurred"will a new hard drive fix
You hard drive is missing from the system. Or, just does not recognize it. The obvious - Remove any USB devices like drives and any media from disc player. Its trying to load, but can't find bootable hard drive, CD, or USB... Remove the hard drive and reseat (reconnect). Check BIOS by pressing an F key during boot. Look on the screen for correct Function key. Might be F2 key. Verify BIOS recognizes the drive. It must be listed! There is no going forward if it's not. Check boot order and make internal hard drive first. Save and restart.
Nov 06, 2012 | Toshiba Computers & Internet
Manual for Toshiba satellite L750-22z
Hi there, I just found this on google. Have a look.
Toshiba Satellite L750-ST6N01 ' User Guide - Page 22www.manualowl.com/m/Toshiba/Satellite-L750.../Manual/281805?...CachedYou +1'd this publicly. UndoToshiba Satellite L750-ST6N01 User Guide - Page 22. Toshiba Satellite L750-ST6N01 Manual. Get Toshiba Satellite L750-ST6N01 manuals and user guides ...
Jun 15, 2012 | Computers & Internet
How can i remove a toshiba satellite A500-01w keyboard?
try this first
a. turn over computer overnight and let it 'drip dry'
b. take a hair dryer on low heat and fan and GENTLY run it over the keyboard about 1 inch back and at angle
try that first and report back
you might get lucky
Jun 14, 2012 | Toshiba Computers & Internet
Toshiba L750/L755 how to unlock keyboard
Please try to clear the connector of the keyboard and fix it correctly, it may solve the problem. If you can not slove it, you may have to replace the keyboard for your toshiba laptop.
Dec 27, 2011 | Computers & Internet
Brand new Toshiba Satellite L750 series. Cursor is locked Keyboard is locked How do I unlock the cursor. I've tried switching off 10s then on and starting normally. No good
Hello there,
Jul 12, 2011 | Toshiba Computers & Internet
How do I replace the keyboard?
next to the F1 key and the windows key (2nd upper key and second to last key) are two screws, usually under some covering. unscrew and lift top edge of the keyboard towards the trackpad to lay face down. Undo the wire ribbon by lifting the grey or brown tabs and remove ribbon and keyboard. Then install the new keyboard by inserting the ribbon on the place. Lock down with the tabs and put the plastic prongs (close to the space bar) into the laptop body first, and then close keyboard onto the final position. screw back in and thats all. nboulikas@gmail.com for any additional questions.
Nov 06, 2009 | Toshiba Satellite A105-S4004 Notebook
Spill soda on my laptop keyboard
It is likely the only problem is that the soda is causing the keys to stick. There is probably no damage to any other internal components. Usually, laptop keyboards have a metal-based frame/tray that will protect the internal components from minor spills.
If you want to get rid of the cracking sound, you'll need to purchase a replacement keyboard from the laptop manufacturer or another source such as eBay, and then remove the sticky keyboard and replace it with the newly purchased one.
Mar 23, 2009 | Toshiba Satellite L305D-S5895 Notebook
Keyboard inoperative
press and hold fn and press f11.it sounds like you activated the sticky keys
Nov 22, 2007 | Toshiba Satellite A135 Notebook
Computers & Internet Logo
114 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
