Question about Sony STR-DE845 Receiver
The sound level from analog input is very low, good quality but low, optical connections work well. Have checked cables, tried all the analog input jacks with same result.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 148 Answers
Test analog input with another receiver ,if it comes out same low , good quality sound level ,then issue/problem is on input source not on receiver. Sometimes the way source audio was recorded causes these issue on high quality receivers...
Posted on Dec 28, 2013
Testimonial: "Sound volume is fine if I use headphones in the same output jack, so problem seems to be the amp"
smeago1
  • 136 Answers
SOURCE: optical inputs
In short yes!
If you have two optical inputs and two equipment (PS3 and HDVD) then you shouldnt have a problem at all. Just make sure you change the mode of the receiver to TV/SAT when you want to use the HDDVD. Your problem may be the video out put.
If i was you i would do the following:
1. Get rid of all your optical cables as you won't need it.
2. If your receiver support HDMI then by default HDMI will send both video and digital sound.
3. Plug the HDMI of the PS3 to the HDMI input of the receiver, plug the HDMI of the HDDVD player into the HDMI 2 of the receiver and plug 1 HDMI cable from the receiver to the tv/monitor you have.
That is the best set up so when you play PS3 you select dvd/ld and when you watch hddvd you select tv/sat.
However having said all that the fact that you have dvd/ld suggests you actually don't have HDMI at all on the receiver(...i just checked the specs of the receiver). Which means you will need to have 2 hdmi inputs for your tv and you will need to have the 2 optical connections.
But in short yes to your question.
hope this is not too confusing.
good luck
smeags.
Posted on Feb 05, 2008
welcomejee
  • 10594 Answers
SOURCE: I have low volume on two channels of my STR DE975 receiver
I been replied you in chat thread, please check and feel free to ask any question.
Posted on Aug 20, 2008
SOURCE: sony str bd-930 connected via digital input to ps3,no sound..
on the ps3 in audio options you have to set it so that the sound is going through the optical and not the hdmi. this it was I think the problem is.
Posted on Dec 30, 2008
SOURCE: NO AUDIO/set up problems
For this Sony, you have to use separate audio cable(s). Either optical in BD or Digital Audio in DVD (single coaxial cable will do the trick) I bet the display says UNLOCK. I had the same problem, very dumb.
Good day!
Posted on Jan 20, 2009
mlapres
  • 757 Answers
SOURCE: Trying to hook my Wii up using the AV audio Jacks
Connect the Wii to your television. Then connect the variable audio output from the TV to the audio in on the monitor section of the receiver. Then use the TV/SAT input selection on the receiver and dolby prologic 2 as your sound mode.
Posted on Dec 23, 2009
Testimonial: "You where right on the money, I did what you said and it worked. You are the man!"
Capture working from camera but not from movie box VCR analoge input
Check the Image source if well shielded. Weak or broken shield in cable will affect the video-sound quality. Try different cable and analog video source. Once you ensure that nothing is wrong at input side. Uninstall-Reinstall the driver and the accompanied software also update driver and the software from Pinnacles support website.
Here is the link for the latest downloads and updates
http://www.pinnaclesys.com/PublicSite/us/Products/Consumer+Products/Home+Video/Studio+Family/Studio+version+9+Support/Contact/Contact+Support/
Good Luck
Jan 21, 2008 | Pinnacle Studio MovieBox DV 9 (210100349)...
All speakers work on sound level test but i have no music coming from rear, center and sub when playing 5.1 dvd. also i am unable to use any of the surrond sound modes. richard
What cable did you hook up your dvd? The 5.1 sound works only with optical cable or HDMI. Check in the input settings wich one is selected. With the analog cable ( Stereo RCA) is not working. Good luck!
Jan 29, 2011 | NAD T762 Receiver
I have audio cables going from HD 61g887 jvc tv, to my phillips surround sound system under aux but it is not giving me sound?
hi
you didn't mentioned the model number of your surround sound system, for a better solution its important. any why try the following.
if you are connected the analog audio output of your tv to the system using RCA cable, then go to the setup of the surround sound system and change the input assignment setting from digital to analog.
If your connected the digital output of your tv to the digital input of your surround system using optical cable then, goto the setup of your surround system and change the input assignment to digital (optical) input.
if u need any further assistance fell free to contact through fixya
Jan 20, 2011 | JVC HD-61G787 61" Television
No sound when connecting optical cable from set top box to #4 optical input for cable tv on rear. The cable only works from the front input or the dvd input on the rear but that limits my sound fields. I...
Make sure your "Input Select" "Audio" portion of the main menu is set to "Auto" you may have it in analog thus only allowing audio from the front analog input. Also check your digital input select option as well. you may have it assigned to another source input. Go into the main menu of the receiver and you will find all the settings. Hope this helps. If you still have issues, post a comment and I can help you troubleshoot further.
Feb 26, 2010 | Yamaha HTR-5760 Receiver
Rx 2700 dts keeps flickering on and off causing
Your symptom sounds like a poor digital connection. The receiver is probably configured to prefer the digital feed if both digital and analog are present from a given source. That it blinks the 'analog' indicator means it thinks the digital signal is degraded.
I believe you're using HDMI. If your cable box has either optical or coaxial digital outputs, try one or both and proceed from there. You could also certify the health of the receiver input that's failing by connecting another device (your Blu-Ray?) to it to test it out, or simply borrow its cable.
If the input works with another device THAT would indicate a problem upstream and external from the receiver - cable, output of the cable box. Optical cables are more finicky than coaxial and do not tolerate being routed in tight radious bends.
DTS isn't Dolby. Read up on it here - http://en.wikipedia.org/wiki/DTS_(sound_system)
Jan 29, 2010 | Yamaha RX-V2700 Receiver
I Have just bought this reviever (Yamaha Rx-v365)and im just trying to work out how to best connect all my devises. I have Tivo, Lg DVD player with both yellow, red white cables and blue green red cable...
Hi, firstly some terminology:
yellow cable - video composite (worst quality)
white/red - stereo analog audio
blue/green/red - video component (second best quality after HDMI)
You are correct that RX-V365 doesn't do audio over HDMI. Moreover it also doesn't do any video processing, which means composite video input will go only to composite video output (and not to component); compoment input only to component output and HDMI input only to HDMI output.
If you have more devices of same video output (in your example the component blue/green/red), you can connect them to TV via the receiver. But if only one device of same video output, you can connect it directly to TV. There is no reason to go through your receiver for video.
For audio, you can use either the analog stereo white/red cables (rx365 has 5 such inputs) or better use digital SPDIF connection, which is slightly better quality and more importantly supports 5.1 sound. There are 2 types - coaxial (orange RCA plug, can use basic rca cable) and optical (square black connector). Receiver has 1x coax spdif input and 2x optical spdif inputs. Look at your other equipment to decide which cable to use.
For the analog audio inputs, I think you can assign it either to composite video or component video. So for DVD audio white/red plugs, you can choose if either Video composite yellow plug named DVD will be used, or component blue/green/red named DVD will be used.
Jan 03, 2010 | Yamaha Rx-v365 A/V Home Theater Receiver
Problems with optical input. I am having intermittent problems with the optical sound input on my Onkyo. I am using a DVR with optical output for the source. Sometimes when I turn the DVR and Onkyo on I...
sometimes with cable, satellite, or any dvr, the digital signal actually is intermittent and there is little we can do about it but add an analog audio connection for each device as a backup. per se, and put the receiver in auto input mode. the receiver will utilize the analog signal to fill in where the digital signal fails
good luck
Dec 07, 2009 | Onkyo TX-DS747
Din Unlock C71
your deck is expecting a digital signal provided by optical cable.
Hence the error message you see. If you want to record using RCA cables, you will have to set your MD recoder so to use analog input.
Press the INPUT key repeatedly to select the Analog input, then connect your RCA cable to the Analog input and start recording.
You may have to adjust the recoding level (or volume if you will).
OR you get an optical cable and then use the Digital Input 1 or 2.
See page 11 of your user manual for detailed instructions.
Cheers
Feb 21, 2009 | Sony MDS-JE470 Mini Disc Player
Kenwood vrs-6100 receivers optical digital
You want to receive the optical signal from the TV's built in decoder / receiver to play through your Kenwood? Maybe you need to select the digital input. The manual says:
Use the INPUT SELECTOR key (or Input Selector keys)
to select DVD, VIDEO or FRONT AUX.
2 Press the INPUT MODE key.
Each press switches the setting as follows:
1 "F-AUTO": Auto detect
("AUTO DETECT" indicator lights up)
2 "D-MANUAL": Fixed to digital input
("DIGITAL" indicator lights up)
3 "ANALOG": Fixed to analog input *
("AUTO DETECT", "DIGITAL" indicator goes off)
Also check your TV to make sure it is outputting to the optical jack.
Jan 11, 2008 | Samsung HTP-1200 System
Sony STR-DE845 Receiver Logo
100 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
