New battery, just seems to turn over ******* start up.
SOURCE: 95 F150 wont crank
the starter should be replaced. The solenoid is kikcing the pinion out but there is no contact being made to turn the starter motor. I have the exact same truck and before i changed the starter used the old starter tap trick. Tap the starter casing with a hammer and it should start turning again. hope this was helpful for you. Good luck.
SOURCE: what would cause my 1989 ford f250 to crank over slow then speed
sounds like the starter is failing
Testimonial: "thank you for the input but it is not the starter or the battery or the starter relay or the altinater i should of mentioned this"
SOURCE: 2001 f250 superduty 6.8L gas, cranks but will not start
theres a power diseribution box under your hood by the battery its in there
SOURCE: 2002 ford taurus occaisional starting problems.
check starter relay if good probly bad solenoid
SOURCE: Hard starting Hard starting Ford diesel
Hello, there are several things as likely to cause this problem, either spark or fuel.
The glowplugs are needed to make a Cold engine start. You can take a testlight to the glowplug wire of several cylinders and it should light when the engine is put to the Run position. The glowplugs get their power from a Coldstart Timer and it may have an additional relay.
The Coldstart Timer is the part which clicks and makes the lights dim when it is cycling. It also controls the dash indicator and makes the dash light work when the glowplugs are ready. The timer changes the amount of time it cycles according to outside and engine temperature. If you have noticed the "Ready" light vary its timing, the timer is working.
Say you have no spark at the glowplug wire, work backwards to the Coldstart timer and see if it is getting power. Power in, none out, bad timer. No power in, work backwards for a Relay or fuse.
Now if you have power at the glowplug, remove several and test them with Battery jumper cables. Put the NEG on the base and touch the POS to the stem. You can melt them if you overdo it. The longer it takes for the glowplug to glow, the worse it is. Once you find a good glower all tests are relative to the good one.
Fuel problem. If the glowplugs test out, check the fuel. Long start times can mean the fuel drained back to the tank and has to be pulled all the way up front. You can unscrew your fuel filter and see if it is topped off or empty. Then you need to test the lines from the fuel filter back.
It is also possible an internal Solenoid in the Injector pump is sticking. A light tap before starting can indicate this problem if it starts better after tapping the pump.
Thats about it. I hope you find my Solution useful.
