Question about Shuttle 9094 Emax Remote Control Helicopter
Idk if my last question posted but my son got a cheap looking Stinger Bladez with Gyro 3.5 channel r/c helicopter from a friend for Christmas. The remote has been plugged into the helicopter for four hours. The light has been green the entire time and its not charging bcz the helicopter does nothing at all when we try it. Am i missing something? Or is this one a dud?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 148 Answers
There are times when you need to check battery contacts on the copter itself, for at times there are plastic protectors between the batteries and the contact points that needs to be removed, these are used to prevent battery power drain while in storage or there might be an on-of power switch on the copter that you might have missed. if all else fails then this definitely is a dud but at least try to make it run ...
Posted on Dec 28, 2013
2 Suggested Answers
SOURCE: My new u-control helicopter is experencing spinning
I had the same problem, the helicopter would spin out of control and the trim did not help. I took a closer look and noticed that only the top rotor was turning. I took the bottom off of the round gear box to find a tiny white gear had slipped off the second motor. With a pair of needle nose tweezers I was able to reattach the gear and I was flying in no time.
Posted on Feb 02, 2012
Rotor spins while charging
You have a bad flight control board. There may be a loose wire near 5be charge port making fontact wi5h the output circuit for the main rotors. Good luck
Feb 26, 2014 | Generic Udi u13 3 channel co-axial...
Remote will not control the helicopter
did you charge the helicopter.... you need to put the charging cable in to the copter. and charge up can use a usb power plug. when charged the light on the usb cable should light up or flash. also if you take the plastic cover off the front there is a battery in there and a board check to see what number its set on. it takes around 5 seconds for the remote to recognise the unit.
Dec 26, 2013 | HobbyTron GYRO Hercules Unbreakable 3.5CH...
My back rotor for my Hercules Helicopter's wont work need help!
Motor failure. They don't last long. Look on fleabay for a cheap replacement. If you have a soldering iron, you can unsolder them both and insert a 3v watch battery. If it runs, then it could be the control board or else the transmitter stick control.
Jun 26, 2013 | HobbyTron GYRO Hercules Unbreakable 3.5CH...
My gyro s107g helicopter will not levitate
press the left button(LB(like on xbox controller spot))
Apr 28, 2013 | Syma New Green S107g 3 Channel Rc Radio...
No power
Check the channels and make sure your on the right channel A / B usually..
give the blades a gentle turn with your fingers, they stick sometimes.
Dec 28, 2012 | FocalPrice BR6008 3.5-channel Infrared...
Just got a s301g Helicopter and it won't start up
Check the wiring where you plug in the charger to the helicopter. There is a red wire with quick disconnects. If its loose (the quick disconnect) you get this problem. In my case the helicopter came out of the box with this completely disconnected. It was hard to connect because there wasn't enough slack wire but once we did it the white light on the front of the helicopter came on and we were flying.
Nov 19, 2012 | Syma S301g Rc Helicopter 18" 3 Channel Rtf...
EB excalibur U.S. Army sky runner 3.5 channel gyro rc helicopter parts
Call EB Brands at 914 964 5200 and ask for customer service.
Feb 10, 2012 | Excalibur Electronics Toys
I just got an r/c helicopter ( gyro s032 ) i've just tried it once but then i tried charging it for second run, but when i plugged the charger cable in the helicopter. It din't want to charge,i looked,and...
couple of things possible. 1) change outlet. 2) call customer service for the helicopter (should be on manual in contact section) 3) the helicopter has a loose cable connected to the battery inside the helicopter so you probably need to sodder it.
Dec 26, 2010 | SYMA Toys industrial Syma S032 Ready to...
How to change channel/band for cyclone 5009 gyro helicopter?
1. Switch the controller to the desired channel. 2. Turn on the helicopter you want to control. 3. Move the joystick forward and back until the rotors start spinning.
Dec 21, 2010 | Toys
Need blade for world tech skyhawk helicopter
Syma DragonFly 9093 or 9083 rc heli... has the same exact size tail blade... just put one on myself... works fine..
Dec 23, 2008 | Toys
Shuttle 9094 Emax Remote Control Helicopter Logo
240 people viewed this question
Top Shuttle Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Shuttle Toy Expert? Answer questions, earn points and help others
