Question about Food Mixers
Anyone have a troubleshoot manual
Bad connection somewhere in the motor, the machine turns on then stops tapping it starts it running again but only briefly
    Master:
  • 796 Answers
You will have to strip it and check continuity of wires with a multimeter.
Posted on Dec 28, 2013
Why My Hobart A200 20 QT Mixer ML #104858 Motor Is Smoking?
I think... without knowing that motor... that the capacitor is a start capacitor, and that the start switch may be trying to "start" the motor full-time instead of switching it out of circuit after it figures that the motor has spun up. I may be wrong - that design may be a capacitor-run motor (similar to a three-phase motor) - but I'm betting it's a start-only capacitor.
If you know someone with a capacitance meter, you could check the capacitor - for both capacitance (to be sure it matches the label) and leakage. Easy way to write that one off. Alternatively, you could rig it such that after the motor's wound up you could manually disconnect the capacitor and see what happens - either the motor stops or else the smoking issue stops.
Whatever you do, don't let it smoke very long. The varnish on the windings is only so thick.
Jul 31, 2014 | Hobart A200 Stand Mixer
Hobart k45 won't run
the K45 was introduced in 1962 and ran until 1978 when the K45SS was introduced. You have an open circuit inside, you need to open the machine from the rear and look to the power cord connections. make sure that the wires are connected and none are floating loose. the next step would be to replace the speed control switch. then check your carbon brushes if either one of the brushes are down to the nubs then it would cause a short when you turned it on, if that is the case then be glad that you have breakers and not fuses because you would have fried your motor. the speed control switch has no power attached to it. ifg the problem still exist after checking power cord, speed control plate and brushes then you have a fried armature or stator either can short the system if they have a burned wire inside especially the stator.
let us know how you fare on this after you check out the first easy steps, we can help with the harder fix also.
Mar 23, 2013 | Food Mixers
KitchenAid stops working when anything other than liquid is in the bowl..
There is a non metal gear inside the motor head that is stripped and no longer engaging the worm drive. What happens when you try to assist the turning process (try it only on stir speed, sloooowwwww) if it starts to turn and then stops again then it is the gear I spoke of. It will require tearing down the machine, cleaning all old grease, to insure that you have no ground up parts in the grease, then replace the grease gasket and gear. Hope this helps
Jan 11, 2013 | KitchenAid Professional 600 Series 6-Quart...
Motor not spinning in hobart 60 qt mixer
Check manually after disconnecting the motor if this is jammed. If so the motor must be reset as the bearings are faulty and so the rotor seems to get stuck with the coil core.
Also if there is high drain with heat it is possible that the coils are faulty and might need an insulation failure test.
Nov 22, 2011 | Hobart H600 Stand Mixer
Our Hobart A200 Mixer only turns on for a few seconds. It has a lot of saftey features that were not familiar with. How do i get to work properly.
It sounds like you get a degrading or bad start capacitor (locate right behind motor cover (see fig 22, page 12 of part catalog, cost $13). Here how you can check if your machine still work properly: 1- Rotate the agitator shaft manually to check for any binding. 2- remove two wires from the capacitor. 3- Use a small jumper, connect one end jumper to one wire and touch the other end jumper to second wire 4- As soon as motor start, remove the jumper. Good luck, If your ,machine have never have preventive mainternance it is a time to do so. (atva)
Apr 19, 2010 | Hobart A200 Stand Mixer
The mixer stops running while mixing. You can hit the head on it with the palm of your hand and it would start running again for a minute or two and then stop again. It is getting harder to get running as...
It sounds as though you have a loose connection, probably either at the switch or the motor. Unplug it and look at all of the connections for looseness or signs of burning. Good luck.
Feb 27, 2010 | KitchenAid KV25G0X Stand Mixer
Panasonic Mixer/Blender not working - works only when tapped
It looks like there may be some loose wire connection. Or it may be due to carbon brush probelm. We at Inno Concepts or any of our dealers can diagnose and fix the problem for a reasonable cost. Please contact us at 770-594-1815 or send us an email with all the details to info@innoconcepts.com
For grinding hard vegetables, use thinner pieces not more than 1/2" in any dimension.
Jun 23, 2009 | Food Mixers
Hobart model a200t not working propery. Just hums when turned on
take top front cover off see if motor is spinning when turned on? hum can come when motor is running or transmision jammed or motor has issue like capsitor bad or start switch inside motor bad.
Jan 03, 2009 | Hobart A200 Stand Mixer
Food Mixers Logo
Top Food Mixers Experts
Oscar Netto
Oscar Netto
Are you a Food Mixer Expert? Answer questions, earn points and help others
