Question about Ovens
Franklin chef vertisserie fr5800
Oven light
  • windsorguzzi Dec 28, 2013
    Hi Eric Bruso, I want to help you with your problem, but I need more information from you. What is the problem with the oven light? Can you please add details in the comment box?
My Chef Classic Wall mounted fan forced oven stopped working. Its grill section working. Fan and the light in the oven working well. Bot oven doesnot heat up. Please give a tip what is probably wrong?
The bake element has gone bad. They can visually look fine but still be bad. To check and replace that element you will unfortunately need to kill the power and remove it from the wall. Remove the back cover. Check for a low resistance (around 16 ohms) across the bake element. If the resistance is high the element is bad. Google the make and model for a replacement element.
Dec 26, 2014 | Magic Chef Ovens
We have a Magic Chef gas oven (model # CPL1100BDW) without electronic ignition. The oven isn't working. The oven pilot is out, can't get it to light, and the oven will not light - (obviously)....
Hello & Welcome to FixYa
If the pilot is clean and still won't light then the problem is with the safety valve that won't open and so needs replacement. Please get back to me if you have any other questions.
Kevin
Nov 14, 2011 | Magic Chef Ovens
Magic Chef range the pilot on the oven will not light.
Is this a manual lighting pilot,do you light it?
If so you may have a bad gas valve.
If this is an auto light pilot it could be the electronic spark is bad.Im guessing the popping noise is the autospark trying to light.
Jan 05, 2010 | Magic Chef Ovens
Magic chef oven, can't figure out how to light it
Hi, Remove the floor panel inside the oven. Here are both style oven pilot pictures. First one is the model with a standing pilot light7fb2e1e.gif Here is the model with an electronic ignition
I hope this helps you.
Jul 15, 2009 | Ovens
Gas smell oven does not light
you may need new coupler on pilot system
Jun 23, 2009 | Magic Chef 9122 Gas Single Oven
I just cleaned by hand by magic chef wall oven and now I can't
Pilotless ignition means that a hot surface ignitor lights the oven burner. It does take a little bit of time to light the burner. Maybe 30 seconds. If you want to make sure it lights take the bottom panel out from the oven and observe the hot surface glow and the burners light. No real danger as the gas valve will only open after the hot surface ignitor has satisfied the gas valve. Let me know how it goes. ken
Jan 02, 2009 | Magic Chef 9122 Gas Single Oven
Unable to find pilot light for m,ajic chef oven
its electronic ignighters is it plugged in and have you tried turning it to light new ones dont have piolets
Jul 13, 2008 | Magic Chef Ovens
Magic chef oven wont turn on
yes oven ignightor to confim this try broil if it lights then its bottom oven ignightor get back wit me ill outline procedure
Dec 29, 2007 | Ovens
Ovens Logo
65 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
