Question about Cell Phones
Lg wont start
I can't get my phone to cut on at all. It did before but not anymore. There is no water damage or anything.
    Master:
  • 796 Answers
Remove the battery for 10 minutes. Then put it back and charge it with a charger that you can see working when it charges another phone. then try again.
Posted on Dec 28, 2013
3 Suggested Answers
Buschchris1
  • 474 Answers
SOURCE: My enV won't hold a charge
You said the new battery worked but wont charge in the phone. You had water damage to the phone before getting the new battery correct?
First remove any Mini S/D card in the phone, power it off and remove the battery. ( only do this if its out of warranty and nothing else works. ) Your need to take the phone apart and get some alcohol wipes and wipe down the circuit board and connectors and anything that may have had water on it, if you see any crude, try to rub it off, there may be water and crude built up on contacts from the water damage that may be shorting the phone. Also check the battery contacts for greas or crud on the contacts. Once you have wiped down everything the alcohole should evaporate and take any moisture with it. Leave it out for a day dis assembled so it can air dry completely.
Put phone back together and hook up the charger and see if it charges. wait to put the memory card back in as in case you screwed anything up, you dont want it to take out your memory card with it.
I have performed this task with many of my friends cell phone that have gone through washing machines or got moisture in it because they take there phones into a steamy shower and moisture ends up shorting it out.
If nothing else works and you want to try it, go for it.
remember theres 6 screws in back and 4 around the mainscreen that are covered with triangular sticky covers, then use a thin knife or something to pry from one of the corners, one it gets started you just have to pop it apart with your fingers. Everything snaps back together easily.
Be carefull on the side with the screens, you dont wanto to pop apart the front screen from the mainscreen as its a pain to keep together when putting it back, also dont get any dust or fingerprints on the screen as they will drive you nuts if you put it all back together and theres a greasy fingerprint under the plastic that protects the screen.
Good luck
Posted on Mar 25, 2008
  • 12 Answers
SOURCE: water damage??
take it back for repairs, preferably to an LG phone shop.
Posted on Sep 20, 2009
Touchscreen wont work, and it wont mount my SD card anymore. One day they both just stopped working no water damage or anything.
The SD card is probably bad, had the same thing happen to a card on my phone, the phone we just rpeatly try and mount it. You can try connecting it to a computer. Right click on computer > manage > Disk Management if the card is detected here right click on it and format it, you have a corrupted file system. If it isn't detected at all the the card is trash. As for the digitizer(touch sensor) these can be replaced although they tend to cost $100+ and you usually need to replace the front glass cover, as they are usually fused together. ifixit.com sells a lot of parts as well as full picture guides for many devices.
Dec 07, 2013 | Straight Talk LG Optimus Zip Cell Phone
Lg phone got wet and wont work
you got it went it wont work ever again to much water damage if you would of soaked it in rice after you dropped or whatever happened it would be fine
Jan 06, 2013 | LG Optimus 3D
Why wont my iPhone charge when its on?
Water or anything liquid is an enemy to anything electronics. The phone is water damaged. And needs thorough servicing with ultrasonic and rework station or hot air gun. Cos the water residue has caused a flux or short on the resistors on the motherboard and they need to be cleaned or replaced. So Sorry samantha there's nothing you can do here except to take the device to any repair centre near you.
Apr 23, 2017 | Apple iPhone 4 Black Smartphone
Water damage??
Sep 20, 2009 | LG Vu CU920 Cellular Phone
The phone is on but the screen wont cut on
Before doing anything else, I suggest removing the battery while the phone is on ---which will obviously turn it off ---wait about 10 seconds, replace battery and turn on the phone. This probably won't work, but it is worth a try for almost any problem that isn't easily resolved on a cell phone.
The phone could have a defect that is covered by a warranty or insurance (if you have one or both.) However, if this is caused by water damage or other physical damage (like the phone was obviously dropped) it will not be covered and you will probably need a new phone.
Sep 14, 2009 | Cell Phones
Phone Water Damage
im sorry but water and electronics do not mix if you have a warrente get your phone replaced and DO NOT tell them it was water damaged if your phone has a sticker on the inside below the battery and it is red peel it off and tell them you do not know what happened to it. Hopefully they will replace the phone
Aug 22, 2009 | LG Lotus Cell Phone
BATTERY UNABLE TO CHARGE, ALTHOUGH PHONE WORKS
Well, the white to pink dot is a sign of water in the phone. It is a moisture indicator and the first thing the repair fols look for so they can deny any claims.
They second thing is you can get an external battery charger for the razor. They run about 5 dollars and allow you to charge the battery seperate from the phone.
Razr V3 external battery charger
May 27, 2009 | LG VX9400 Cellular Phone
Lg keybo --water damage
please help me, i cleaned my phone with lens cleaner and it went inside my phone and it doesnt turn on anymore. i put it in rice lastnight and its not working! what do i do !
Mar 24, 2009 | Cell Phones
Good luck
Mar 21, 2008 | LG enV VX9900 Cellular Phone
Cell Phones Logo
15 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
