Question about Toys
Stinger bladez with gyro
Have had the remote plugged into helicopter for over four hours. Light has been green the entire time and hasn't shut off and the helicopter hasn't worked at all. What do I do now?
SOURCE: we have two gyros S107G remote control
Had the exact same problem. Found the solution on an Amazon posting:
1. To enable this function make sure both remotes and both helicopters are off.
2. Set the first remote's channel switch to the leftmost position (it says A, B, and C, but the s107 only supports 2 channels). Turn the remote on.?
3. Turn the helicopter that you would like to bind to the remote on and set the helicopter down on a flat stable surface for about 5 seconds. Try the throttle and the helicopter should respond to this remote.?
4. Next, to enable the second helicopter, set the second remote's channel switch to the rightmost position (it says A, B, and C, but the S107 only supports 2 channels). Turn the remote on.?
5. Turn the second helicopter on and set the helicopter down on a flat stable surface for about 5 seconds. Try the throttle and the second helicopter should respond to this remote.?
This worked for us.
Posted on Dec 26, 2010
Testimonial: "excellent help. thanks a ton. now we'll just hope for no mid-air collisions. appreciate it!"
SOURCE: The red light on the transmitter is blinking. The
Same problem here red blinking light I believe it is a problem with a lot of them
SOURCE: Bought a S108 helicopter. Charged
There should be a sticker near the helicopters "on off" switch that has an "A" "B" or "C" on it. Make sure the switch on the controller is set to correspond with that letter. If that isnt it, keep it for parts and buy another. These are VERY delicate toys and most break quite easily.
Posted on Feb 18, 2011
SOURCE: my helicopter (SO32 Gyro) having previously worked
Batteries are available online (amazon and many others) and change easily with only small screwdriver. Overcharging is not the issue. Nearly impossible with PCB (overcharge prevention circuit) hard wired into battery AND in charger. Problem is likely UNDERcharging, overDIScharging, or improper battery care. Battery MUST be allowed to cool 10 minutes after flying. Charge until light on charger doesn't get any brighter when helicopter is unplugged... light comes on (dim at first) well before full charge. 10 minute cool-down after charge also a MUST. And, most important, when flying, as soon as you are unable to maintain altitude, land helicopter and power it off. Li/Po batteries should never be fully drained. Even one full discharge can cripple or ruin entirely your helicopter's battery.
hope this helps.. let me know,
r
Posted on Sep 12, 2011
SOURCE: My new u-control helicopter is experencing spinning
I had the same problem, the helicopter would spin out of control and the trim did not help. I took a closer look and noticed that only the top rotor was turning. I took the bottom off of the round gear box to find a tiny white gear had slipped off the second motor. With a pair of needle nose tweezers I was able to reattach the gear and I was flying in no time.
Posted on Feb 02, 2012
Spins to left, will not take off/lift?
GYRO Nano Hercules Unbreakable 3.5CH Electric RTF RC ...
www.amazon.com/Hercules-Unbreakable.../B00AAOJ...
Amazon.com, Inc.GYRO Nano Hercules Unbreakable 3.5CH Electric RTF RC Helicopter (Color ... you can remove the 8 or so screws that allow you to pull the fairing off, remove .... Also we purchased our helicopter from HobbyTron.com through Amazon and .... won't spin, so the entire helicopter spins, and doesn't generate enough lift to fly.
GYRO Nano Hercules Unbreakable 3.5 CH Electric RTF RC
Amazon.com, Inc.Nano Hercules Unbreakable Glow in the Dark 3.5CH RC Helicopter ... It can go forward, backward, up, down, left, right and hover. .... It worked for a few flights and now the copter will not fly off the ground. ... and ive had it for a year now and everytime I start it up and it takes lift off it starts to fly backwards but otherwise ok toy.
Hercules Unbreakable 3.5CH RC Helicopter - HobbyTron.com
Dec 26, 2015 | HobbyTron Nano Hercules Unbreakable 3.5CH...
My Gyro s107g helicopter won't connect to the remote. It just sits there not moving or any lights turning on.
It sounds like the two are not compatable. In other words the freakwinsy of the plane is not the same as the controller. THEY MUST MATCH. You may find the numbers on the back of the controller and where the batteries go in the chopper. If the numbers do not match, take it back to the store, and get one that does. Sorry for the spelling
Jan 13, 2015 | Syma S107G 3CH RC Helicopter RTF w/ Gyro...
Fully charged won't fly. s33 2.4g 3channel with gyro
If you've verified all channel settings and you're sure the battery is charged then it sounds defective. Is it within allowable time from purchase to exchange for a different one?
Jun 01, 2014 | Syma s33 3 channel rc helicopter 2.4ghz...
Syma s031
Make sure the battery is connected and the Helicopter and remote are both turned on on the same channel. Antenna is secure and extended.
May 11, 2014 | Syma S031 Gyro Metal Frame 3.5 CH RC...
Idk if my last question posted but my son got a cheap looking Stinger Bladez with Gyro 3.5 channel r/c helicopter from a friend for Christmas. The remote has been plugged into the helicopter for four...
There are times when you need to check battery contacts on the copter itself, for at times there are plastic protectors between the batteries and the contact points that needs to be removed, these are used to prevent battery power drain while in storage or there might be an on-of power switch on the copter that you might have missed. if all else fails then this definitely is a dud but at least try to make it run ...
Dec 28, 2013 | Shuttle 9094 Emax Remote Control...
Remote will not control the helicopter
did you charge the helicopter.... you need to put the charging cable in to the copter. and charge up can use a usb power plug. when charged the light on the usb cable should light up or flash. also if you take the plastic cover off the front there is a battery in there and a board check to see what number its set on. it takes around 5 seconds for the remote to recognise the unit.
Dec 26, 2013 | HobbyTron GYRO Hercules Unbreakable 3.5CH...
My gyro s107g helicopter will not levitate
press the left button(LB(like on xbox controller spot))
Apr 28, 2013 | Syma New Green S107g 3 Channel Rc Radio...
Just got a s301g Helicopter and it won't start up
Check the wiring where you plug in the charger to the helicopter. There is a red wire with quick disconnects. If its loose (the quick disconnect) you get this problem. In my case the helicopter came out of the box with this completely disconnected. It was hard to connect because there wasn't enough slack wire but once we did it the white light on the front of the helicopter came on and we were flying.
Nov 19, 2012 | Syma S301g Rc Helicopter 18" 3 Channel Rtf...
Toys Logo
376 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
