Question about Hardware & Accessories
1999 saturn 1.9 liter starts some times then yule be driveing and the car just shut off like you turn off the key was told it is the crank sensor need to know if that is it thanks
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 148 Answers
Just check all your electricals, wiring and fuses or contacts, something is definitely loose or failing on your system.
Posted on Dec 28, 2013
What is the problem on my saturn sl 1999 i changed the knock sensor and the crankshaft sensor and it still has hard time starting. In order for it to start you have to hold the gas down while turning the...
If it has a timeing sensor on a device that looks like a distributer in older cars it should be changed also. It and the crank sensor share info in order to work properly.
Sep 01, 2014 | 1999 Saturn SL
1999 dakota with a 5.2 motor.I can drive it any where from 5 min to an hour and the truck shuts down.Sometimes it starts back up and other times it just cranks over,but starts the next day.When it shuts...
It is most likely one of two issues. Either the Camshaft sensor, or the Crankshaft sensor. Neither is too expensive nor too hard to replace. Try the Cam Sensor first. The 5.2L seems to have these more often. The 2.5L has the same problem, but it's usually the Crank Sensor.
Sep 27, 2013 | 1999 Dodge Dakota
Starting disabled
try another key the one your using might have lost programming then if it starts with the other key restart it with the unprogrammed key within seconds of shutting it off with the key that works
Sep 21, 2012 | 2005 Saturn Relay 3
Engine shut off in the middle of the freeway, completely lost power.
check the crank shaft sensor ,check the timing belt . check the coil , check the fuel pump pressure
Sep 08, 2012 | 2003 Saturn VUE
Turn ignition key and motor starts up, next day turn ignition key and motor just turns over and wont start. could it be anti theft problem its a 2002 f150 4 wheel drive with 4.6 liter
This could be caused by either a faulty Crank Shaft Position Sensor or the anti-theft system. Try put key in, turn to ON position for EXACTLY 10 minutes, As SOON as anti-theft light shuts off or stops flashing, then IMMEDIATELY start the engine.
Jan 13, 2010 | 2002 Ford F150 Regular Cab
Starting for 1999 Saturn SC
I had a similar problem. My 99 Saturn SL1 would crank and crank but would not start. I'd step on the gas repeatedly when it seemed like it was about to start. I got a new battery, alternator, complete tune up and nothing helped. As an aside, my flunked the emissions test and I had to go to a shop and have it hooked up to a computer for diagnosis. They found many things wrong and I ended up changing the oxygen sensor and the catalitic converter because the mechanic said that these were the most important things to fix so that the car could pass the emissions test. My car passed the emissions test Also I no longer had problems with starting the car. Replace your oxygen sensor.
Sep 30, 2009 | 1999 Saturn SL
Key
1999 Nissan Maxima, car was running shut it off, now won't start, replaced crank sensors, cam sensor, mass air flow, and fuel pump. The security light stays on when cranking, is it possible that the key could be no good, or is their another problem
Jul 28, 2008 | 1999 Nissan Maxima
Hardware & Accessories Logo
22 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
